Is it ok to use a capacitor with a much higher ripple?
  • Ady2017
    • Dec 2017
    • 55
    Hi all
    I am trying to source some new caps for the power board on my LG TV. The one I am currently struggling to find a replacement for has the specs:
    Sam Young KMG 680uf 50V with a rated ripple current of 973. According to the catalogue these seem to be a general purpose capacitor and it is not clear why LG have used them on the power board.
    I like to use Panasonic capacitors but most of these have got a ripple voltage of 2-3 times the figure of the original capacitor. My preferred FR capacitors are 3160 while the FC ones are 2215. Would going from 973 to 3160 be way too over-kill and cause other problems? Are the FC series ok to use for a power supply board?
  • petehall347
    • Jan 2015
    • 4450
    • United Kingdom
    Re: Is it ok to use a capacitor with a much higher ripple?
    higher ripple current is fine in my book .
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      Replacing a GP cap with a low impedance, high ripple current rating cap is usually OK. Unless it was a GP cap in a circuit needing low impedance, etc., the original part would not have been a misuse.
      PeteS in CA
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • MORETTIGIAN
        Capacitor detached from PCB – RTX 2070 Super Founders Edition
        by MORETTIGIAN
        Title:
        Description:
        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
        I did not notice it detaching, so I am unsure of its original location on the PCB.
        Procedure performed:
        - Removed backplate
        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
        - Reapplied thermal compound
        - Reassembled card
        Observed behavior after reassembly:
        - GPU powers on and operates normally under...
        09-18-2025, 12:14 PM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
      • Prolog
        RTX 3080 FE Identifying capacitor
        by Prolog
        Hi people, I hope this is the correct spot to post this, I'm new to the forum.
        I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
        I hope these photos make it clear which component I am referring to:
        (yes, the soldering is a bit botched from removing the blown one, I know)
        I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
        12-01-2024, 08:27 PM
      • samoelec
        Trying to understand how to find best replacement cap for old parts.
        by samoelec
        Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
        Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
        The power supply board is exactly the same from this post so I'll just steal it for now.
        I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
        04-01-2024, 03:39 AM
