Hi all, I have 15 capacitors to replace of varying voltage and uF I looked on RS Online but I can only buy them in the least of a 5 pack when I only need one or two or three of a type, so far I'm trying to get the price down from $47.10 and thats without postage so where online is a good place to buy caps in 1,2,3 or 4 at a time. They are all electrolytic caps and I'm choosing Nippon Chemi-Con or Rubycon or Nichicon etc. as long as they are good quality. I need the capacitors in a power supply for a friends DVD/VCR combo player so another question I have is, would all the capacitors be DC and not AC? Its for an LG RC689D I have a pic of the power supply below but all the capacitors are removed already and its had work done beforehand so I dont know if I should increase the voltage on all the caps in case this was done already. The highest value cap is 450V 68uF 85c from Samwha Im going to use all 105c instead.
Help to bring cost down for 15 Caps
Tags: None
Re: Help to bring cost down for 15 Caps
here lies the dilemma, yes buying small quantities are expensive, especially those high voltage units. Electrolytic capacitors are generally for DC and PSU boards are for the most part using DC so that's not an issue. Question is why you're replacing the capacitors in the first place? -
Thanks Mockingbird but I'll buy them from my country to save time and holding delay, eccerrOr I have to replace the caps as the output voltages from the power supply are under and its stuck in a loop of the welcome message on the display and wont play DVD'sComment
Don't forget to clean the PCB under the cap next to D127 & L127.
Looks like you've got dried electrolyte residue there.
Also check the traces on the back/bottom.
Isopropyl alcohol & a cotton swab should take care of it."pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!
If you are doing small quantities your best bet is to find a local brick and mortar place. You can probably save a few bucks and skip replacing c103, those large caps tend to not go bad.
If you see yourself doing repairs going forward, it's much cheaper if you just start stocking the common vaules. Increase the voltage if feasible (price and physical size) so you don't end up stocking multiple voltage values.Comment
I would add one more thing to this is if you are going to buy 1uf to 100uf I would recommend either 50 volt to 63 volts the lower voltage ones do not make sense to buy because most switching power supply requirements are 50 volts on rare occasions I have seen 63 volts or 100 volts
Most common UF are 1 , 2.2 , 4.7* , 10 , 22 , 33* , 39* , 47 , 56* , 100*
The ones that have an (*) are not very common but I have seen them on occasion have seen them being used
When I buy these capacitors I buy 100 at a time from Digikey because you get a price break on this quality and I will end up using them and buying another 100 when I order them again the only one that I do not do this is with the 100uf because they are more expensive I might 10 or 25 depending on the priceLast edited by sam_sam_sam; 11-06-2021, 10:52 AM.Comment
Ok, thanks guys my friend said he doesn't mind paying more for the good caps but now I have one query about ripple current, some are low about 920mA and another is high 2.48A unfortunately when I read about AC ripple current it didn't mention if low or high is better as an example one capacitor I need is 16V 2200uf 105c and the two links below are the ones I'm looking at they are basically the same except the ripple current:
https://au.rs-online.com/web/p/alumi...citors/0374433
and
https://au.rs-online.com/web/p/alumi...citors/7037501
here is the list I need to get:
16 volt, 2200uf, 105c
12.5mm diameter x 21mm high x 5mm leg spacing
(I need 3)
450 volt, 68uf, 105c
18mm diameter x32mm high x 7mm leg spacing
(I need 1)
25 volt, 1000uf, 105c
10mm diameter x 21mm high x 5mm leg spacing
(I need 2)
10 volt, 1000uf, 105c
10mm diameter x 13mm high x 5mm leg spacing
(I need 2)
16 volt, 100uf, 105c
5mm diameter x 11mm high x 5mm leg spacing
(I need 1)
10 volt, 220uf, 105c
(I need 2)
25 volt, 100uf, 105c
6mm diameter x 12mm high x 5mm leg spacing
(I need 1)
25 volt, 470uf, 105c
10mm diameter x 17mm high x 5mm leg spacing
(I need 1)
35 volt, 33uf, 105c
(I need 1)
50 volt, 47uf, 105c
6mm diameter x 11mm high x 5mm leg spacing
(I need 1)
So Sam I have 4 between the range of 1-100uf I'll use 50 voltComment
You want the second link, which is Rubycon ZLH, as opposed to the first, which is NCC KMG. KMG is a general purpose series.Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
https://www.badcaps.net/filedata/fetch?id=3591771
https://www.badcaps.net/filedata/fetch?id=3591772
It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
Channel: General Capacitor Questions & Issues
by Green Probe(TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
Disclaimer: I'm an amateur hobbyist and will get things wrong.
Always use caution when working around mains power and high voltage capacitors!
Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
SYMPTOMS:
-No display...-
Channel: Troubleshooting Audio Equipment
by Paxman_SwedeHello!
I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
- Loading...
- No more items.
