THOMSON 32lb120s4 no sound
  • jimbofz
    • Apr 2013
    • 539
    • uk
    Hi can anyone help please with cct diagram ,ive looked for hours
    this tv has no sound but the o/p stage is fine ,so suspect main board ,poss corrupt f/w?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: THOMSON 32lb120s4 no sound
    The THOMSON Chassis LCD12B 20LB120S4 may give you some insight into the audio section
    https://www.electronica-pt.com/esque...ileinfo/11059/
    • jimbofz
      • Apr 2013
      • 539
      • uk
      thanks for taking time to help .sadly this version you posted is different to mine the version i have has a TDA7490L for its sound o/p stage ,pin 6 of which is mute/on off .
      now when you press mute the osg shows on screen.
      the transistor q1 is used to switch mute on off
      there are 2 supplies -16v and +16v both present
      • dskall
        • Oct 2016
        • 2905
        • usa
        The osg displays? OSD? Are you you using remote or tv buttons? Do you get any mute message on screen?
        • jimbofz
          • Apr 2013
          • 539
          • uk
          yes mute osg as normal
          vol graphic as normal but not a peep of sound ,
          headphone socket also eliminated ,
          no sound with headphones
          • lotas
            • Jan 2016
            • 4935
            • Russia
            Service menu : menu+info+103
            • jimbofz
              • Apr 2013
              • 539
              • uk
              had a good look in s/menu
              sadly nothing in there to do with sound
              • dskall
                • Oct 2016
                • 2905
                • usa
                How did you verify the chip is good?
                • jimbofz
                  • Apr 2013
                  • 539
                  • uk
                  supplies to chip ok slight buzz left and right on both i/p pins
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    So you need 4-5vdc on pin 6 to make active. 0 to 2.5vdc to mute and standby.
                    • jimbofz
                      • Apr 2013
                      • 539
                      • uk
                      finally found cct .page 17 is audio o/p ,
                      strange theres no 5v supply shown on cct
                      it seems that the chip works without ?
                      please have a look
                      the cct is same even though the model number is 125 not 120
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        So what voltage do you have on pin6?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          please have a look
                          The +5V and -5V are internally generated by the TDA7490L and available on pin 12 (+5V) and pin 16 (-5V).
                          The +5V (+VA5) then goes off to supply Q1 which controls the ON/OFF and Mute function.
                          https://cdn.badcaps-static.com/pdfs/...08f432f49f.pdf
                          • jimbofz
                            • Apr 2013
                            • 539
                            • uk
                            so that explaines where the 5v comes from .
                            its not clear from the cct .
                            i now understand its from within the ic
                            • jimbofz
                              • Apr 2013
                              • 539
                              • uk
                              the voltage is .05v ,so ill try to get replacement ic thanks
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                You may have a faulty Q1 or the +5V from the TDA7490L may be missing or either the ON/OFF or MUTE signal may be stuck at +5V.
                                • jimbofz
                                  • Apr 2013
                                  • 539
                                  • uk
                                  i will check as soon as i get my hands on the tv .the owner has taken it back and for the time being is using external audio out phonos from his sat box to his stereo system ,as he only uses scart on his tv ,uses the sound vol control on sat box. i will post update asap
                                  • ChaosLegionnaire
                                    by ChaosLegionnaire
                                    09-13-2022, 09:02 AM
                                  • LEECH666
                                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                    by LEECH666
                                    Good day ladies and gentleman!
                                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                    01-19-2024, 05:46 PM
                                  • Christos Tsiligiannis
                                    Marian Trace Alpha sound card repair help
                                    by Christos Tsiligiannis
                                    Hello to the forum.
                                    My name is Christos, I am new to the forum here and i am posting from Greece.
                                    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                    So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                    11-18-2024, 05:26 AM
                                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                    This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-12-2024, 02:30 PM
                                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
