Is there a manufacturers tolerance for ripple?
  • Ady2017
    • Dec 2017
    • 50
    Hi all
    I need to replace a 680uF 35V SamYoung NXB cap which has got a ripple of 1820. Whilst passing my local little electronics shop I picked up what they had in stock which was a 680uF 35V Panasonic FC with a ripple of 1655.
    As the ripple rating is only 9% below what the original was I am wondering whether to risk it and fit it.
    The catalogues specify a capacitance tolerance of +/-20% but state nothing about the ripple. If there is a similar tolerance for ripple then I might be worrying about nothing. Does anybody know?
    • 31139
    Re: Is there a manufacturers tolerance for ripple?
    where did you buy them?
    i didnt know london had any electronic parts shops left - other than cricklewood electronics.
    • TheLaw
      • Jan 2011
      • 477
      The ripple current rating is generally used as a point of guidance in selecting a capacitor. It's not a hard limit, unlike the voltage rating, for instance.
      Each switch-mode topology has a set of equations which govern the (theoretical) RMS ripple current in the input or output capacitors. It is generally good practice to select a capacitor with ripple current rating higher than the actual RMS ripple current. But, it is not strictly necessary.
      You can run a capacitor at 2x its ripple current rating (for instance), and even get good reliability, as long as you can keep it cool enough. When you operate near or above the ripple current rating of a capacitor, you can expect a somewhat significant temperature rise at the center-most part of the capacitor (a.ka. "the core"). At 2x the ripple current rating, you might expect a 20-30C rise compared to the capacitor's case temperature. But, if you can keep the case temperature at 30-40C (with a fan for instance), then you might be okay!
      The ripple current rating goes together with the endurance rating. The endurance rating: 2,000; 6,000; 10,000 hours (for instance) is the expected life when the capacitor is run "fully maxed out". That is: At it's max temperature rating (105C, usually), max ripple current, and max DC voltage.
      In this case, if everything else was equal, 9% lower ripple current rating doesn't mean the thing will explode, just means it may have slightly shorter life. But then again, it appears SamYoung has a 4,000 hour rating and Panasonic has a 3,000 hour rating, so it might just even out.
        • 31139
        thats not true,
        if the ripple is higher than the cap can handle then it wont smooth it out.
        • TheLaw
          • Jan 2011
          • 477
          No. A capacitor's ability to smooth out voltage ripple is related to its capacitance and ESR. Whether a given capacitor can "smooth out voltage ripple" is totally dependent on the requirements of the application. I've designed power supplies running polymer caps at 1.5-1.8x the rated ripple current rating (with forced air cooling) and the voltage ripple is plenty acceptable.
          The ripple current rating is derived from the temperature rise of the capacitor core, that is the self-heating due to I(ripple-rms)^2 * ESR. It's important to remember that the ripple current rating is defined as:
          "...the RMS ripple current which, when operated at the maximum category temperature (i.e. 85 or 105C) will result in the stated capacitor life (i.e. 1,000 or 10,000 hours)."
          Ripple current rating is good to gauge at a capacitor at first glance. And it is useful to understand the ripple current ratio (Ia/Ir), where Ia = actual ripple current, and Ir = ripple current rating @ max temperature. Ia/Ir helps you determine the extent of the self-heating of the capacitor, which helps you understand what temperature the case of the capacitor needs to be to meet the product lifetime requirement.
          https://cdn.badcaps-static.com/pdfs/...b1de7f999a.pdf
          • AleXis6
            • Feb 2021
            • 69
            • Belarus
            thank you!
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Thanks for posting this, Law! Really useful information there.
              In regards to the OP's question (which the above info probably answered already), I think that Panny FC will do the job just fine, if not better. It may be rated at slightly lower RC (ripple current) than the SamYoung NXB, but I think the Panny FC will actually hold true to its specs... whereas the NXB was probably a bit over-rated, just like most non-Japanese capacitors are (though probably nowhere near as bad as the cheap Chinese/Taiwanese crap brands.) So I think the FC will do fine and probably outlive the NXB by many years.
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
              • quickname
                Cyberpower 1500AVR UPS repair
                by quickname
                I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                I decided to verify that the batteries were...
                11-12-2023, 09:57 AM
              • JohnsonJ
                Allen&Heath XONE92 DJ mixer repair
                by JohnsonJ
                Hello everyone.
                I'm having issues with my DJ mixer, and after taking it apart and checking everything out, it seems that I need to replace 2 rotary potentiometers for the filter, and that the PSU has some caps burned. Hopefully these 2 fixes will solve my issues.
                The potentiometers I will just replace (hopefully the repairman I spoke with will indeed send me the spares, in case he doesn't, I'll update here if we can find a suitable replacement), but for the PSU caps I'd kindly ask you forum members, if anyone could help guide me in the right direction. I'm having difficulty...
                12-12-2020, 11:19 AM
                Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                by sam_sam_sam
                I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                I tested the battery cells there are installed right now and they are testing good with no issues that I...
                02-04-2025, 08:08 PM
              • Junkrepair
                Seeking "Ripple Current Confusion" paper by Kemet
                by Junkrepair
                Hey everybody.
                Trying to understand the meaning of ripple-current specs for capacitors, I've seen references to a paper apparently entitled "Ripple Current Confusion", by Kemet. I've found that the links to the paper are broken, and that it doesn't seem to be on Kemet's site.
                Can you post that paper or a good link to it?
                Thanks.
                04-07-2022, 04:28 PM
