Op-amp preamp discussion
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. In another one of my "sonic projects", I got myself a couple of these little pre-made pre-amp boards off Ali (photo 1), mostly to experiment with them and learn something in the process by hopefully combining my modest electronics knowledge and my passion for audio, although I don't claim to be an audiophile who likes to spend thousands on pro audio gear....which itself is often regarded as just snake oil and marketing BS from what I've read. I'll try to keep the wall of text to a minimum so:
    The op-amp they came with is an AD828, which the datasheet calls a "video" op-amp, which is pretty ironic and is much the polar opposite of "audio". It doesn't matter, because I can swap this out with another one, which leads me to point #1: would changing the op-amp to one that costs more than these 3 boards together, like an OPA1612 really have an noticeable effect ? I'm talking something you can feel with your ears and not something you can pick up on a piece of laboratory equipment which I don't have anyway...I looked at what others have to say about "upgrading" op-amps in general and it ranges from "must-do" to "useless and mostly psychological" as long as the op-amp is not 30 years old...
    Point #2: frequency response and how to calculate it. It was really easy for me to draw a schematic and even simulate the circuit here, since it's only a handful of components. Not knowing what this configuration is called, I just browsed around until I found something that looked similar here. It obviously has to be some sort of amplifier configuration and there's clearly a feedback resistor there, but it wasn't clear what that voltage divider+cap is doing on the + input. The chap had the same question and that is what values the cap and resistor on the Inverting input should have. Someone replied, mentioning the high-pass filter, but I can't possibly figure out how he got those values in the reply: Fc = 0.16/Rc =1.6kHz. Hence C = 0.16/(8Hz * 1k) = 22uF.
    In my case it's 10u for the cap and 2.2k for the resistor (I THINK that's what 10 stands for on the cans there). I tried figuring out how to calculate this and I DID find something about high-pass filters here. The formula appears to be fC=1/(2pi RC). There's an example there which demonstrates how to calculate for 82pF and 240kOhms, and indeed I was able to get to that example result myself, but I'm not sure how and IF this applies to my circuit as well.
    Point #3: gain. Does a 2.2k resistor and a 20k feedback one result in a gain of 10 there ? I found the formula to be Av = Rf/R1 (thank you Dave from EEV ) The simulator seems to confirm this: I get 10mv output for a 1mV input...unless the input frequency is very low, like 10hZ, at which point the output starts to drop too, to like 7mV instead of 10mV, unless I increase the value of the cap too. I'm not interested in filtering anything - just passing the amplified signal to the downstream "power" amp. I'm aware it cannot drive a low-impedance load like a speaker or headphones directly - you know me - not that stupid Decreasing the value of R1 obviously increases the gain, on paper at least, because I'm not sure it can be done in practice, otherwise the boards would've come like that from the factory...
    While audio quality is strictly subjective and not quantifiable, aspects such as frequencies and gain at least have some calculations and formulae behind them which we can all agree upon, regardless of what our ears say
    Wattevah...
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Op-amp preamp discussion
    This one has resistors you can change to increase the gain. https://www.aliexpress.com/item/1005001703051433.html
    Whether you'd be able to tell a difference depends on the source audio and what it's driving and how good your ears/brain are.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Tell that to the tube-o-philes. They love distortion.
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Originally posted by diif
        This one has resistors you can change to increase the gain. [url]https://www.aliexpress.com/item/1005001703051433.html[/url
        Well, yeah - that's the one I got - see the attached pic
        Wattevah...
        • diif
          • Feb 2014
          • 6978
          • England
          I was showing it to you not as a better purchase but to confirm what I think you were saying about increasing gain.
            • 31137
            i would replace the caps with tantalum - lower esr and probably more linear response.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              True. I too was thinking about that - better caps. I guess I'd keep the existing values. Should I bother replacing the power caps as well, or just the signal ones ?
              I think you're looking at those holes where a thru-hole resistor can go. I just noticed those ) It's where the feedback resistor goes if I'm not mistaken.
              Wattevah...
                • 31137
                i would normally not change power caps to opamps - it's not like they are subjected to high frequencies.
                that said, i dont trust smd electrolytics.
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  Especially from obviously questionable sources
                  Wattevah...
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Just to pedantic, you can increase the gain of an op amp circuit, but can't increase gain of an operational amplifier, you can only reduce it...
                    And the two boards/pictures are eversoslightly different... dang those bits of rice.
                    TBH it looks like the OPA1612 was specially designed for audio and would be guaranteed to be better for audio usage. The AD828 is a faster op amp and hence better for video and other high speed stuff.
                    Someday it might be worth it for me to "hear" a LM741, LM358, TL082, LF353, LM6142, etc., etc. in my junkpile, and if I ever get my hands on a OPA1612 and AD828 too, but I don't think I really can tell the difference at a fixed, reasonable gain. I'm no audiophile. Heard a lot of hearsay about LM358's XO distortion but I'll have to be the judge of that.
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      Ok, I was curious about the gain of the op-amp CIRCUIT then
                      Also, yes the board in the link has polarized caps, while mine seem to be non-polarized. Also, the resistors are arranged slightly differently, but overall I'd say it's the same circuit...
                      Wattevah...
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Are they really bipolar capacitors or are they just missing paint ?
                          • 31137
                          i would say they are far too large to be polarised caps
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            If I were to replace them with polarized ones, where would the positive go ? Looking at the other board which appears to use polarized caps, I can see the inputs go to the negative side, while the outputs come OUT of the negative side....
                            Wattevah...
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Orient them the same way as the other board which does come with polarized capacitors
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                That aside, I'm mostly interested in the "electronic" reason why signals go "in"/come "out" of the negative/positive leg of caps in audio circuits
                                It's true that most schematics I've seen use non-polarized symbols for the caps....
                                Wattevah...
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Generally a bipolar cap should be used when unsure. A polarized cap can be used if the circuit charges it the right way.
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    • Romania
                                    I ordered some low ESR caps, though they ARE still electrolytic, not knowing what I should go with...mostly to replace the original ones with something *supposedly* better quality. I went over plenty of sources and discussions trying to work out what the best choice would be and came to the conclusion that the minimalist nature of this circuit probably outweighs the quality of the caps (unless they're complete trash), even if they cost 2-3 times as much ! Poly film caps seem to be the most popular for this application, but they are too expensive and too large to be worth the effort, especially since, as previously mentioned, there are probably other things which outweigh the caps...
                                    Wattevah...
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      • Romania
                                      I finally got around to actually running these things to see how they sound out of the box, with no alterations. Again, only having my ears as my primary test instrument at my disposal, I can say they exceeded my expectations: I was worried I'd run into all sorts of issues like buzzing/humming, all of that BS, but everything went really well. The amp is also really quiet when idling, even with the Aliexpress pre-amps hooked on its input. Often times, amps like to hiss when nothing is playing through them ! I managed to achieve decent loudness, with no noticeable distortion. I was afraid I may damage the speakers I used, so I didn't go all the way to the max on both the amp and the PRE-amp, which would be just silly.
                                      Since this is a Sony car amp I scored for cheap, it's got a gain control which ranges from 6v to 0.3v. This corresponds to the sort of output your headunit is expected to put out, so if it's got a higher output, you turn it towards the higher value and the gain actually DECREASES to compensate and vice-versa. I set it to right about when that hissing was just starting to come through at idle, which in in this case is a little over the half-way point, which is 2v.
                                      Not sure whether I should even bother to replace the AD828 amps or even the caps for that matter
                                      Wattevah...
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        I wouldn't have thought it would have been necessary for most people... on the other hand I'm curious about people who could tell the difference between op amps and whether or not they can tell with a double blind test.
                                        • Omron
                                          I want to dim light bulb by 50% I want to learn how to calculate it on my own
                                          by Omron
                                          I have a 5W lamp on 12Volts battery, I want it to be half as bright, so I will add a resistor. What resistor should I supply?
                                          A = W = 5 = 0.416mA
                                          _ _
                                          V 12
                                          R = V = 12 = 28.84 Ohms (R) this is resistance of lamp
                                          _ _____
                                          I 0.416
                                          So I will add one resistor 28.84 Ohms
                                          I will have 28.84 + 28.84 = 57.6 Ohms
                                          Or 28.84 + 28.84 = 14.42 Ohms
                                          I don't know if it will work in series or in parallel
                                          voltage would be 6V and amp current mA = 0.208mA We divide everything by two
                                          W= V * I...
                                          06-04-2024, 01:58 AM
                                          LM358 LM358S-13 Datasheet
                                          The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
                                          Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
                                          10-07-2024, 04:12 AM
                                        • Kesson
                                          Repairing dbx 1066 compressor/gate/limiter
                                          by Kesson
                                          Hi! Hope you're fine! (:
                                          So a friend gave me this unit which had faulty pushbuttons. Sadly I messed things a little up while doing the job.
                                          Here's the schematic hosted:
                                          https://elektrotanya.com/dbx_1066_sch.pdf/download.html
                                          I managed to repair a vias connecting bottom and top with a bridge. After this sound is back on channel 1.
                                          More saddly I managed to destroy channel 2 by an overload occured while testing (too much volume). Now channel 2 is dead and I'm left with channel 1 who seems to work fine.
                                          As I am...
                                          11-16-2019, 06:38 AM
                                        • Curious.George
                                          Adding gain to antenna distribution
                                          by Curious.George
                                          I'd like to drive LOTS of RG6 drops (i.e., 20?) without having to rewire splitters (they are highly inaccessible).
                                          I can't locate anything mains-powered near the splitters so any power has to come via an injector(s).
                                          So, is it better to put ALL the gain between the antenna and splitter; some gain on each drop AFTER the splitter; or a combination of the two? (Or, a multi-tiered splitter with gain between tiers?)
                                          [This is for CATV, OTA TV & FM]
                                          07-07-2019, 12:46 AM
                                        • EasyGoing1
                                          How to calculate current in R2 with an LM317
                                          by EasyGoing1
                                          Given this circuit:
                                          How can I calculate IR2?...
                                          05-20-2021, 01:31 PM
