samsung LE32A558p3f bn44-00208a
  • Phil289
    • Nov 2021
    • 42
    Hi
    Could someone tell me the differance between the 2 types of caps in the attachment - i have repaired the power supply board by replacing 6 caps and tv is now working but it has a low level buzz/whistle which can't be heard when tv is being used normally but can be heard slightly when theres nothing going on on screen.
    In the kit i recieved it had all 3 of the 25v 1000uf the same as the smaller caps in the picture and the taller one was not included - when i asked i was told it would be ok to use the ones supplied.
    I've checked online and all these boards appear to definately have one cap a differant physical size so i assume there must be a reason for it but being a newbie to electronics i don't know why or what for.
    Could anyone shed some light on this for me please.
    Thank you.
    • Jul 2011
    • 6070
    Re: bn44-00208a
    What brand of capacitors did you use if can post a picture of the replacement capacitors that you used
    • R_J
      • Jun 2012
      • 9607
      Re: bn44-00208a
      The taller cap may be slightly better quality cap that was installed at the factory, That cap is for the +5v standby supply and that supply is always on that could be why they did it, installing a good quality cap in that location will be fine.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Re: bn44-00208a
        Physical size could be that it may be better at reducing the ripple current on that supply.
        • Phil289
          • Nov 2021
          • 42
          Re: bn44-00208a
          Thanks very much for your comments
          I have attached pictures of the caps fitted and after taking a closer look i feel the noise is not coming from the power supply.
          The noise doesn't alter with the sound being turned up or down (its right down in the attached video)its not noisey in standby but only when tv is 'on' and does
          seem to get lower the longer the tv is on for but doesn't disappear totally.
          I don't know the history of the tv as only recieved it last week after it was being thrown out because it just went off and the owners bought a new one.
          It is a samsung LE32A558p3f.
          I'm not sure if i should have started a new thread for this problem or ok to continue with this one.
          Thanks for any input
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4500
            • Italy - Milan
            Re: samsung LE32A558p3f bn44-00208a
            Your replacement caps are a unkown brand probably low quality, swap them with Panasonic or Nichicon ones and you probably have solved, after replacement post also picture of soldering job, if you're a novice on that side.. also that Jwco are suspective, myabe changed by someone else, but good to be changed now that your're on the track.. place an order by reputable seller, preferably not Amazon/ebay..
            • cheeky2
              • Dec 2012
              • 337
              • uk
              +1 Change the capacitors to Panasonic FR range of the same value. I guess you bought a kit off ebay as there are quite a few sellers selling no name capacitors of poor quality. Anyone buying these are liable to changing them in a couple of years if your lucky that they last that long!
              If you buy a kit always ask what capacitors are they supplying and the range as well. If they don't answer or fob you off with an answer 'like all suitable for the TV' then definitely look elsewhere
              • Phil289
                • Nov 2021
                • 42
                Can anyone recommend where to get genuine Panasonic FR caps in uk?
                Are all ebay sellers risky to buy genuine Panasonic caps from or can someone recommend a genuine seller?
                Ive checked some of the bigger uk websites and the postage cost for 6 caps is very high (dearer than the caps).
                I don’t have anywhere local to buy the items over the counter.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4500
                  • Italy - Milan
                  In the truth i have in the past bought Panasonic caps from an uk ebay seller after long searching in its feebacks, i don't know if its truly ok but you can try, don't ask me the name, unless you suggest it to me, Not only FR series are suitable i guess, for that near zero value tv especially, Also FM series, Rubycon and Nichicon brands, always better than Chinese parts, Real Panasonic have black label , gold writes, and a tiny red mark in pressure..
                  • CityZen
                    • May 2014
                    • 40
                    In reference to your original question, the taller cap has a temperature rating on it, whereas the others don't, implying that they have a lower rating.
                    You might pick up a cheap LCR-T4 component tester from Ebay and use it to test some of the caps you got and verify that they're within spec.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      in the uk i use rs components or cpc mainly there used to be a ebay seller called h.m.comp who sold genuine panasonic capacitors very resonable priced but ebay shops closed now i have also used this ebay seller to prices not too bad for panasonic caps https://www.ebay.co.uk/itm/161890283...IAAOSw3WZgFU6R
                      • Phil289
                        • Nov 2021
                        • 42
                        Yes i'm definately going to try some good quality caps -Panasonic if i can locate some - its a lesson learnt and i won't make the same mistake again.
                        • Phil289
                          • Nov 2021
                          • 42
                          I was looking at those testers on ebay and for around £15 with a case looked good value and at least i could verify what's good and what's not instead of guessing - are they all the same or is there good and bad in what's available?
                          • Phil289
                            • Nov 2021
                            • 42
                            Thanks for the link - he has good feedback but when i checked he doesn't have all the values i need so will keep looking for someone that has all of them.
                            • CityZen
                              • May 2014
                              • 40
                              They're mostly the same as far as I can tell. Some are more bare bones, some have nice cases and such. There could be variations in the firmware version they're running, but that might not matter much. I think they're quite an amazing value for what they can do.
                              • Phil289
                                • Nov 2021
                                • 42
                                Have ordered one and should be here middle of next week - i can then test the old ones and the new ones and hopefully see what's going on 🙂
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Capacitors I also buy from CPC who have a massive range to choose from. You can also look at the specifications to ensure what you buy has the correct width, height and leg pinout so as to fit the pcb.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    I actually prefer cpc as you say great range of parts and tools etc, at good prices.
                                      09-07-2024, 05:50 AM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
                                      Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 06:20 PM
