Cap Identification
  • Oh-my-tv
    • Aug 2018
    • 9
    Cap Identification
    I have some caps that I am having a hard time identifying. Can anyone assist me? Thank you for your expertise. it is a cylindrical cap about 8mm dia. with 3 lines of text top line is EP middle line is 47-16 then a line across and bottom line is V1
    • 21968
    Re: Cap Identification
    Can you post a picture of it
    • Oh-my-tv
      • Aug 2018
      • 9
      Here is a pic.
        • 21968
        Here is a pic.
        What does it have written on the side of the cap
        • Oh-my-tv
          • Aug 2018
          • 9
          Nothing, just manufacturers name. Can you take a guess as to what the board coating is? Manufactured in the 80s.
            • 31259
            probably 47uf and 16v
            looking at what its in i think it needs to be 105' temp rated.
            so maybe use rubycon YXF
            • Oh-my-tv
              • Aug 2018
              • 9
              Thank you very much, It is a cruise control unit. Appreciate the help
              • PeteS in CA
                • Aug 2005
                • 3583
                • USA, Unsure of Planet
                Those Wima 2.5 mm lead space caps definitely have a 1980s vibe. I'll guess the coating may be Humiseal, a coating used to seal out moisture.
                PeteS in CA
                • Oh-my-tv
                  • Aug 2018
                  • 9
                  Thank you PeteS. I appreciate the help
                  • splash221
                    Identification of SOT89-5 component in keyboard – key line control, 5 pieces on the PCB
                    by splash221
                    Good morning,
                    Please help me identify an electronic component. The component is in an SOT89-5 package with leads as shown in the photo. It is used on a keyboard board and controls the operation of a specific key row. There are five identical components on the PCB, and whenever I swap one with another, the corresponding key row stops working — so I conclude the component is faulty.
                    The keyboard is a SteelSeries Apex Pro (US). I cannot find a boardview or schematic online. I have already searched AllTransistors, AllDatasheet, etc., and found several candidate types (voltage...
                    10-03-2025, 11:35 AM
                  • Maniackk
                    Reader PocketBook InkPad 3 – identification of a black component marked 'CT' on the microUSB line
                    by Maniackk
                    Device: PocketBook InkPad 3
                    Mainboard: XRZ_E091_PB740-VTTOA-V1.1 / 2017-10-12
                    I'm replacing the broken microUSB connector on this e-reader, and during inspection after desoldering, I noticed a loose black SMD component marked "CT". One of them was torn off along with the pad, while the other one (marked in the photo) is still in place.
                    I would appreciate help identifying this component.
                    Measuring the loose component with a multimeter gives 5.84 MΩ in both directions, while the one still on the board shows no measurable...
                    05-16-2025, 08:53 AM
                  • cubytus
                    Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                    by cubytus
                    Hi to all,
                    I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                    I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                    Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                    01-10-2024, 01:26 AM
                  • otaku_nut
                    Vizio E701i-A3 fixed but now has red vertical line
                    by otaku_nut
                    Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                    08-19-2025, 06:11 PM
                  • TrueSword88
                    Kogan - KALED65XU9220STB - Blue Vertical Line
                    by TrueSword88
                    Hi all.
                    I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                    The line just happens to coincide with the end of COF and start of the next COF (attached).
                    The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                    Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                    Hoping to fix...
                    05-05-2023, 04:28 PM
