TPS65862IC Programmer & socket?
  • Richi_el
    • Nov 2013
    • 95
    • Koln
    can someone tell me which is the correct programmer & socket for TPS65862IC ?
    I saw in the datasheet of the ic, that i2c programmer is used for.
    I never used i2c programmer before, but i have RT809H prorgammer.
    Can i use that too?
    I couldnt fount that ic type in the software of rt809H progammer.
    I uploaded the image of the ic
    Thanks for support !
    • 31150
    Re: TPS65862IC Programmer & socket?
    chips like that are usually programmed on the board.
    see if the laptop - it's a laptop right?
    see if it has test-pads connected to the i²c points on the chip
    • Richi_el
      • Nov 2013
      • 95
      • Koln
      Hello, thank you for your reply.
      No its a industrial device with a pcb like a notebook.
      The problem is there are no schematics for this board available.
      I see that the TP658621C is faulty, and i have to change it.
      I also have a defective board where i can track / trace the line to the progamming pins. But i cant find the correct datasheet for the TP658621C to find out the pinout.
      In this datasheet for TP658621C there is a pinout but the imaged bga has
      11 X 11 contacs(legs)
      https://pdf1.alldatasheetru.com/data...PS658621C.html
      My TP658621C hast 13X 13 contacts (legs)
      Why ?
      It isnt possible to programm it before i do solder it?
      • Richi_el
        • Nov 2013
        • 95
        • Koln
        Ok sorry i seen that also 13 X 13 contacts on the datasheet wich i linked, but there is no pinout
        • Teeheeze
          RT809H Programmer Firmware Corrupted
          by Teeheeze
          This is a shot in the dark, but I was just using my RT809H programmer and it got stuck in a certain state so I power cycled it. Now, the device LED just flashes quickly and does not connect to the software. I've tried to update the BIOS of it and it fails. I went so far as to remove the ROM from the programmer itself but it's some weird chip (I believe ATMEL, but I can't find any datasheet on it) so I've been unable to read the BIN from it w/ my other programmer. Chip has ATMLHC4C56BM CN written on it (I think). I'll upload an image. I have the programmer's BIN ready to program it manually. Anyone...
          02-13-2025, 04:51 PM
        • sassan
          The new xgecu T76 vs rt809h programmer
          by sassan
          hello,
          i want to buy a new programmer mainly for use for laptops bios chips and i'm between the Xgecu T76 and the famous RT809H.
          i think that T76 is faster wich makes it the best choice for using Pogo pins,i asked the support if it supports Mec ships found on some Lenovo laptops i didn't get an answer yet.
          i would like some ideas and which one do you recommend?...
          03-06-2025, 05:36 AM
        • bembeno
          aquestion about RT809h programmer
          by bembeno
          dose RT809h programmer support the new Bios chips like 25q256jveq because i have minipro TL866 and icant programming these ics and if anyone can tell me about a cheaper programmer wich do the same job to buy it
          03-04-2023, 02:39 PM
        • STKR123
          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
          by STKR123
          Greetings badcaps community,
          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
          I learned that desoldering...
          10-29-2024, 06:03 AM
        • AJ847.63e
          LGA 1700 Socket Replacement Tips & Tricks
          by AJ847.63e
          Hi All,
          Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
          I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
          07-24-2025, 06:57 PM
