Vestel 17IPS71 + 17MB82S - no standby
  • cruiser_
    • Nov 2019
    • 124
    • Ireland
    hello there,
    I am trying to fix a Walker 40 TV - it has Vestel 17IPS71 3R3 as PSU and 17MB82S for logic.
    How I got here...
    The TV had shorted USB connector, which I fixed. TV turned on. Ran for a few hours on HDMI input. Started to see some dark dots/patterns on the screen as seen on the photo.
    I restored to factory setting. The TV has rebooted only to a blinking standby LED. It sat there for a number of minutes after which I disconnected it.
    Now, after plugging it back in - there is not even a standby LED.
    My 17IPS71 provides 12V, no standby though. There is no Q1 or surrounding elements at all - as per the diagram it should provide 5V standby. I must have some variant of the board?
    However, the logic board provides 5V STANDBY at U46.
    I checked power to ICs on the logic board, they have steady 12/5/3.3V.
    What gives? I'm at loss here... Next step would probably be to hook up UART to SCART, but something tells me I should be getting standby LED in first place?
    Any help greatly appreciated
  • CityZen
    • May 2014
    • 40
    Re: Vestel 17IPS71 + 17MB82S - no standby
    Some TVs remember when they were on before being unplugged. Seems like your TV is on, which is why there's no standby LED.
    • cruiser_
      • Nov 2019
      • 124
      • Ireland
      sure... but then where's my backlight, display and audio?
      I checked SCART pins 10,12 with scope, signal stays low all the time. Shouldn't it be high ? - pulled up by 3v3_stby...
      • cruiser_
        • Nov 2019
        • 124
        • Ireland
        ok this is super weird.
        multimeter on scart uart pins shows 2.78V on both, as expected.
        the scope however, hovers around 0V. what the heck...?
        anyways, i measured all the test points listed under 'board voltages' and they all check out.
        • cheeky2
          • Dec 2012
          • 339
          • uk
          Check the sb5100 in psu as they go short and give no standby. Possibly you also have faulty leds inside the screen which will give you black areas on the screen. I cannot tell from your picture of dark areas.
          • cruiser_
            • Nov 2019
            • 124
            • Ireland
            hi cheeky2, the diodes all seem ok, provided 12V/24V is stable, this variant of PSU doesn't seem to provide 5v at all, nor 24V to the connector. It seems to be generated by the logic board.
            re the picture - notice hundreds of tiny dark spots/lines, it's not band-like areas darkened.
            i checked 11 test points on the logic board, all provided good voltage.
            however, TP26 (which is a protect) is pulled low; my board has no Q10/Q43/D39 at all. That leaves 3.3, 5, 12 and 24V.
            By examining voltages around D40 it seems that this line is pulled low since 24V_VCC is not there. Where would that possibly come from is beyond my understanding.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              A photo of your power supply may be useful. It should provide 24V and the 5V is probably derived from the 12V at the mainboard.
              What revision 17IPS71 is the power supply.
              • cruiser_
                • Nov 2019
                • 124
                • Ireland
                The 24v (actually higher) is present at C30/C31. I don't find any connection to the socket with that voltage.
                • CityZen
                  • May 2014
                  • 40
                  Are you measuring socket voltages with cables attached or disconnected? The power supply might behave differently with no load.
                  According to
                  pin 1 of CN4 might be 24V (it's a bit unclear to me), while pin 3 is the signal to turn on the power supply, and pins 10,11,12 are 12V (other even pins are ground). Pins 5,7 control the backlight, and pin 9 is the 5V standby that isn't populated.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Do you have +24V on L5 which is a link on your board?
                    You have D11, D13 & D15 on board which rectify the voltage feeding to L5 (24V)
                    • cruiser_
                      • Nov 2019
                      • 124
                      • Ireland
                      According to
                      hi,
                      I've had lvds disconnected from the logic board during the measurements.
                      PIN1 on both the PSU board and logic board is not connected anywhere.
                      What's more, I traced the alleged 24V_vcc_a line that is shown on the protector circuit. It goes to two places, both with a jumper disconnected. What the heck... :|
                      • cruiser_
                        • Nov 2019
                        • 124
                        • Ireland
                        The schematic isn't that great. The whole section around q5 is not present on the board. L5 has 26/27V on it.
                        • CityZen
                          • May 2014
                          • 40
                          It seems 24V is only used on the PS board to supply the LED driver.
                          If all voltages on PSU check out, then you should focus on the main board.
                          Perhaps check for 3V3_STBY, which seems critical. You can probe the right-side (emitter) pads for Q1/Q3 (not present). Probe the upper (collector) pads for 5V_STBY.
                          It looks like Q61 switches power through FS2. If it's on, you should see voltage on FS2.
                          Everything goes through the main chip, the MT5820L. By "everything", I mean the standby LED and the standby power control.
                          • cruiser_
                            • Nov 2019
                            • 124
                            • Ireland
                            Testpoints that I have checked out (with exception of TP26 which is pulled low)
                            TP 1,3,4,10,12,13,15,18,21,26,222
                            1V2_MT58280 is at TP1, check
                            3V3_STDBY is at TP4, check
                            3V3_VCC is at TP222, check
                            5V_STDBY / TV_VCC is at TP2, check
                            12V_VCC is at TP12, check
                            not sure about 12V_STDBY
                            I'm thinking of removing Q9, which is the one pulling PROTECT down; however, from the manual it seems that if PROTECT is kicking in, I should be getting a blinking LED - and I'm not getting any.
                            • lotas
                              • Jan 2016
                              • 4920
                              • Russia
                              Most likely, the firmware has flown into U10-25Q16, U12-25Q64.
                              • cruiser_
                                • Nov 2019
                                • 124
                                • Ireland
                                I'm not getting clk signal for them at all. Shouldn't I be getting anything at all there during startup?
                                • lotas
                                  • Jan 2016
                                  • 4920
                                  • Russia
                                  Have you checked spi flash 6pin. (sclk) on them?
                                  • lotas
                                    • Jan 2016
                                    • 4920
                                    • Russia
                                    On this chassis, the firmware flies and the LED does not light up completely, but it happens that they blink.
                                    • CityZen
                                      • May 2014
                                      • 40
                                      This might be useful:
                                      https://www.manualslib.com/manual/13...tel-Mb82s.html
                                      • cruiser_
                                        • Nov 2019
                                        • 124
                                        • Ireland
                                        The clk is a single spike or a long pull up. Similar with Cs. Nothing that would look like data reading
                                        • pcbmaniac
                                          VESTEL 17MB82S not working only red led working
                                          by pcbmaniac
                                          Dear friends,
                                          i do have a VESTEL 17MB82S not working. Here is the story:
                                          First, when i give power on tv, red led lights after some blinkings and i've noticed that picture apears but no backligt at all (i use a small light to see it).
                                          Then i do flash with a FAT32 USB stick, the upgrade_loader.pkg file with the known OK button method. After that, the TV stops and when i press the ON-OFF button from remote control, the red led goes on but no backlight no picture at all.
                                          I do took off the 2 flash IC's U10,U12 try to read them with flash programmer, but i get "Error...
                                          10-15-2023, 03:01 PM
                                        • Aivar1988
                                          JVC LT65VU83K Vestel 17MB130P no standby light
                                          by Aivar1988
                                          Hello!
                                          Bought a used TV last weekend and everything was fine when I tested it. Back home I tried to connect it with my PC via HDMI. I noticed that the picture didn't quite fit in the TV's picture and so I tried to change the output resolution on my PC and then changed the picture formats on the TV. I still didn't get the picture right and stopped to google the problem and then it happened - the TV died on me after I got to use it for 30min.
                                          JVC LT65VU83K Serial nr. 7975101 800044
                                          Panel: VESTEL VES650QNTS-2D-U11 Manufactured 18/04 23443739
                                          Power board: VESTEL...
                                          08-31-2021, 05:47 PM
                                        • Adenitz
                                          Troubleshooting Vestel TV, has standby, but cannot turn ON
                                          by Adenitz
                                          I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                                          Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                                          Both boards are shown in the attached photos.
                                          What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                                          12-27-2023, 03:43 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • Askic
                                          Hitachi (Vestel) TV is not turning on
                                          by Askic
                                          Hello guys,
                                          I have 32 inch Hitachi TV with Vestel PSU board 17IPS71. Tv was working normally and I shut it down normally via remote control.
                                          The next morning it couldn't turn ON neither with remote controller or via button on the logic board.
                                          There is a red standby LED ON, so it is not dead totally.
                                          I have examined the PSU board and I cannot find find any traces of blown components or bulged caps. Electrolytic caps are manufactured by Elite.
                                          I also check diodes and big MOSFET (with cooler/heatsink). It seems OK.
                                          Can you tell me based on...
                                          01-11-2023, 12:34 PM
