Help indetifying a SMPS IC BDJ7EC
  • madan1
    • Nov 2016
    • 726
    • Bulgaria
    Hello everyone, a friend brought me a dead Dell D6000 dock for repair. So it turned out one of the 5V power rails (looks like there are 2 parallel rails, but without schematics can't be sure which powers what ) has been shorted or something and the SMPS/converter IC was literally welded to the copper.
    So can anyone identify the IC? The letters on it are BDJ7EC which return no results in google.
    Thanks in advance.
    Oops, sorry, wrong section. May I ask an admin to move it the correct one. thanks
    • 22216
    Re: Help indetifying a SMPS IC BDJ7EC
    Thanks in advance.
    It could be a Silergy SY8288ARAC .Marking BDJ*** .The stars are year,week and lot code
    • madan1
      • Nov 2016
      • 726
      • Bulgaria
      Thank you SMDFlea!
      With this information, I was able to find a local supplier ( http://www.laptopserviz.bg/index.php...ac-bdj-ic.html ) and hope to have it delivered next week.
      • skwarszczow
        Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
        by skwarszczow
        This is my first post on the forum
        I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
        Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
        Before completing the purchase, we decided to erase...
        03-23-2025, 06:04 PM
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
      • dkneyle
        Onkyo DX-V500 Laser Disc Player - weird SMPS fault
        by dkneyle
        This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
        Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
        02-01-2022, 02:08 AM
      • shamsudeen
        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
        by shamsudeen
        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
        i know that in linear power supply the noise will be very low comparing to SMPS supply....
        07-19-2025, 07:14 AM
      • Cemal Odabasioglu
        MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
        by Cemal Odabasioglu
        I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
        Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
        Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
        Observations...
        01-14-2025, 03:54 PM
