Frying amplifier finals... audio, not rf...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Well for RF transmitters, transmitting without an impedance matched antenna and if the transmitter doesn't have automatic limiting... kiss the final transistor goodbye and chalk one up to something you killed.
    But that's not the same way with audio amps for the most part, well, at least the wavelength of audio on copper is so long that you get all of it back anyway but the transistor is fine with it...
    So how are people destroying finals in their audio amplifiers then? Heh.
    Are people shorting their outputs or something, overdriving output to a too big speaker? Or are these amps just frying on their own due to being in an overly compact enclosure and simply got too hot over time?
    Anyone actually kill their audio amplifier output or witness it leaking the magic smoke?
    TBH at least as of right now, knock on wood, I have yet to blow an audio amplifier output. Just wondering what it takes to blow an output?
    (I haven't blown an RF final/amplifier output yet either yet, likewise knock on wood, but I've gotten both audio and RF amplifiers that had bad finals that need repair... And also honestly I think I envision myself killing an RF final well before killing an audio final...)
    • 31254
    Re: Frying amplifier finals... audio, not rf...
    i often help a guy fixing amps - dont get them myself.
    the most common cause of final destruction is faulty bits in the pre-drive either overdriving the finals or turning both parts of a push/pull pair on together or overlapped!
    it can be anything - last one was just an out-of-value resistor shifting the bias enough to make one transistor drive against the other!!!
    • petehall347
      • Jan 2015
      • 4440
      • United Kingdom
      shorted speaker wires . mismatched speakers to amp ..too low ohms . having amp turned up to clipping for too long . then there is faults like idle bias set too high . bad ventilation causing overheating .
      i have had amps blow up for no apparent reason . and also for obvious reasons .
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8703
        Interesting... but nothing self observed?
        Self inflicted wounds is the most frequent cause of failure?
        Was wonderring hiw often bias shifts cause enough leakage to self destruct...if cooling is sufficient it should be able to handle it at least for several mA...
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          I've killed a few back in the days trying to see if that 2ohm stable car audio amp could give up just one more ohm. A few didn't end well.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8703
            Yow...so I suspect a lot of amps that end up on the repair bench were self inflicted wounds?
            I'm surprised that a lot of pre-drivers go bad... or were they too self inflicted?
            I guess I did get one amp that failed due to poor QC/assembly. One of the leads on the STK chip broke. I didn't notice it broke until after I debugged down to the STK chip, bought a new STK chip, and I removed the old one. I think there was enough of a stub that I could have wired a jumper and reinstalled the old one, ha...
              • 31254
              it depends on age.
              i see a lot of 70's and 80's stuff - drifted values on resistors and caps is common.
              there is a french guy who is reverse engineering a lot of stk stuff to create clones btw.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8703
                drift happens ...but enough to cause it to leak too much and meltdown? Still if you have a bias current of 20mA and it goes to 50mA, it should still be able to tolerate the heat as it's still lower than RMS draw at high volume...
                I suppose it's best when someone designs the amp using semiconductor voltages like diode drop voltages to regulate against drift.
                  • 31254
                  it's not heat, if the bias goes out of balance on a push/pull output circuit the transistors drive into each other and create a dead short
                  if your lucky the amp has seperate internal fuses on the + and - rails.
                  but a lot dont
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8703
                    it is most definitely generating heat when both are turned on... Not a dead short but most definitely is drawing power that way. Crossover dissipation to an extreme.
                    It would just be the rectifier diodes on the power supply that'd die if it was a true short. Which very well may happen if the transistors meltdown... but do they? It'd have to leak a lot to generate that much heat I'd think.
                    Let's say you have 100mA crossover, at 100V across. That'd only be 10W (actually 5W per) which should be very doable if your transistors are well heatsinked. I'd say you'd need near 300+mA crossover to start getting worrysome, and how much component drifting would be needed to get that when the setpoint was 20mA to begin with?
                      • 31254
                      the output transistors often go open internally - probably melted bond wires.
                      and sometimes they crack or shatter the resin casing
                      • Hondaman
                        • Sep 2008
                        • 1089
                        I'm not sure if this belongs here, but here goes......
                        When I was growing up in the 1970s, my parents bought a LOWREY brand home organ and made me (or convinced me to) take music lessons. If you wanted to practice the organ while people were sleeping, there were headphones and a headphone jack that you could use that would silence the room-filling speakers.
                        You can guess what happened. One of the wires in the jack was not soldered properly, or it came loose (there was not a generous amount of wire between the jack and the headphones, quality was lacking in many products in the early 1970s). When I heard sound in only one of my ears, I did not realize anything was wrong. Later, after I unplugged the headphones, suddenly the speaker on the left side of the organ's cabinet did not produce any sound.
                        We had an electronics repair guy (who maybe specialized in organs?) come to the house and fix a few things, including the transistor that fixed our speaker. The organ could achieve pretty much its full potential again.
                        Guess what happened next? Someone (probably me) blew that same circuit AGAIN by plugging in the headphones with the bad soldering ! I guess I didn't realize that was the cause of the problem.
                        I tried to get my parents to fix it when we were giving it away to a church several years ago, but my parents wanted me to be quiet -- they didn't want the church to have any doubts. In the end, the church did take it and put it to good use. I don't know if they ever realized the left speaker was dead and the amplifier really could have been repaired (if you could still get the parts/transistors/ICs for it).
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8703
                          yay for design defects and shorts when you plug in phone plugs! As much as I like phone plugs for being generic and ubiquitous, if not designed properly they do short (notwithstanding as that organ demonstrates - even poorer design that even allow the solder lugs to short together while plugging it in...booo!!!).
                          Kind of funny too, like the Baofeng amateur radio HTs that when you plug in the ⅛" and 3/32" phone plugs for headset, it will trigger the PTT and transmit as you plug it in... talk about overloading the plug pins and designing it such that you must turn off the HT when plugging the headset in.
                            • 31254
                            i dont blame baofeng for that, it's called a "kenwood" connector for a reason.
                            jack plugs are shit though, i killed some small psu's in the past that used a 3.5mm jack to connect to the device because of the shorting problem.
                            the u.k. used to use a big 4pin version for telephones too!!!
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8703
                              Wonder if that's better or what was used in the US - four real prongs instead of a single prong with 4 contacts ... https://www.oldphoneworks.com/4-prong-plug-male.html
                              Forgot the last time I saw one of these and whether the prongs matched banana jack/plugs. Figure they do match just like SO-239 and MC4 ...
                                • 31254
                                that 4pin is o.k. because you wont short the contacts by hot-plugging one.
                                it's not quite as good as the old french plugs though.
                                • petehall347
                                  • Jan 2015
                                  • 4440
                                  • United Kingdom
                                  shorting amplifier headphone jacks by simply using headphones as intended should be fine because they have resistors . well any i have seen have .
                                  • samson7point1@yahoo.com
                                    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                    by samson7point1@yahoo.com
                                    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                    The player processes the audio signal using two different reference frequencies. The "R"...
                                    04-30-2024, 11:22 AM
                                  • silver60618
                                    Macbook M3 A2991 Speaker Audio Amplifier IC
                                    by silver60618
                                    Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
                                    I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
                                    09-26-2025, 12:25 PM
                                  • Babbar
                                    by Babbar
                                    04-12-2024, 01:12 AM
                                  • MrCommunistGen
                                    Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                    by MrCommunistGen
                                    My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                    I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                    07-12-2021, 05:11 PM
                                  • RetroComputingGrotto
                                    TDA2030A Audio Power Amplifier Question
                                    by RetroComputingGrotto
                                    My boss always says "the only stupid question is the one not asked" so at the risk of asking a stupid/obvious question I'm going to one any way...
                                    I've got a pair of speakers with an amp built in to them in for repair and on inspection I can see the TDA2030A amplifier ICs have blown (so I've ordered some spares which should arrive soon):
                                    My quesion is with regards to the white paste you can see on the TDA2030A and heatsink, I'm assuming this is just some thermal paste and if so is it a special kind or will the grey thermal compound that I have...
                                    10-29-2024, 08:25 AM
