Samsung UN65MU8000FXZA Dead NO power NO standby light won't turn on
  • rgla
    • Nov 2021
    • 23
    Hi. First time post. I've scoured the previous forums looking for info - there isn't much for my model
    UN65MU8000FXZA
    We had a power outage. Everything plugged into the Monster surge protector seems to be fine except my Samsung TV. It was dead when the power came back to the house.
    Here's what I've looked at:
    Unplugged main board from power supply - BACKLIGHTS COME ON.
    Ordered new main board - still didn't work. Not sure if used MB was DOA
    MAIN BOARD = BN94-12295K
    PSB= BN44-00912 L65E8NR_MHS
    There doesn't seem to be a pin for Standby like on other boards
    The value on pin 16. power on/off seems high but what do I know.
    Please help me diagnose - is the power supply board done?
    Here are the values I tested for VOLTS. I didn't have the needle tips for multimeter so made my own but here are the values
    WITH = with MB connected
    WO = without MB connected
    CNM803 WITH WO
    1. GND 0 0
    2. GND 0 0
    3. GND 0 0
    4. GND 0 0
    5. VAMP 9 12.85
    6. GND 0 0
    7. VAMP 9 12.85
    8. OD_LEVL 0 3.2
    9. VAMP 9 12.85
    10 FAIL COUNT 0 13
    11 A13V 9 12.85
    12 OD ON OFF 0 3.2
    13 A13V 9 12.85
    14 BLU 0 3.2
    15 A13V 9 12.5
    16 POWER ON/OFF 96 4.5
    17 A13V 9 12.85
    18 GND 0 0
    19 GND 0 0
    20 GND 0 0
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung 65 Dead NO power NO standby light won't turn on
    16 POWER ON/OFF 96 4.5? 96vdc?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Maybe 96mV?
      • dskall
        • Oct 2016
        • 2905
        • usa
        What voltages does the old mainboard have? Seems the mainboard is pulling down your 13v line.
        • rgla
          • Nov 2021
          • 23
          Yes the 96 is VDC. I didn't move the Meter to another setting.
          It seemed high to me. This was only when the cable from PB to MB was disconnected. There's actually 2 cables running from PB to MB.
          I got another mainboard today but it was one letter off
          BN94-12295K (original board) BN94-12295J - new board. The backlights started flashing and I think the standby light was flashing. The repair shop said it must be the MB but I'm not convinced. He wasted to solder a part from the J board to my K board and said it would probably work.
          I don't want to buy a new MB and have the PB fry it.
          This did happen after a power outage so maybe it was a one time surge?
          Thanks for the help
          • rgla
            • Nov 2021
            • 23
            I'm pretty new to this so excuse this question.
            I did find a "pin" in the middle of the power board that says "stndby" 7.5 ON 11
            Not sure what this is called - a pin? it looks almost like a staple that's about an inch long. How do I test this? set meter to VDC, Ground the black meter probe to the body of the TV and touch the red probe to the staple/pin (it's in the middle of the board and doesn't have a cable or anything near it.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Need some pictures of connectors and boards.
              • rgla
                • Nov 2021
                • 23
                Here are the images.
                Thanks for the help.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  You can measure the voltage on that link and see if it is at 7.V volts when in standby and 11.8V when out of standby. Meter set to dc voltage and can use the chassis as ground.
                  • rgla
                    • Nov 2021
                    • 23
                    Thanks for the follow up help. Here are the voltages I got on the standby link (jumper?) (HOT side of board)
                    The TV was not ON. It was just plugged in. It won't turn on so I'm not sure how to assess the info from the board:
                    According to the board it should be 7.5 standby and 11.8 on.
                    With the main board connected the voltage was 9v
                    Withe the main board DISCONNECTED the voltage was 12.85
                    somewhat similar to what I was getting at the cable connection pins.
                    Still not sure if the power on/off connection cable pin is supposed to be 96 and then down to 4.5
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      That does not appear to be hot side. All voltages on that side taken from cold side ground as on pads for screw holes.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        This maybe worth a read
                        https://masterelectronicsrepair.blog...amsung_98.html
                        • rgla
                          • Nov 2021
                          • 23
                          Sorry. You are correct. This is on the COLD side.
                          I put the black probe in a screw hole on the chassis of the tv.
                          Does any of that matter for the reading?
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            Hot side ground and cold side ground are 2 different things. Your voltage readings are odd. As in 96v doesn't seem valid. Are your batteries good in your voltmeter?
                            • rgla
                              • Nov 2021
                              • 23
                              All the voltage readings I took were on the cold side. I grounded to a screw hole / chassis in the back of the TV.
                              New batteries, new multimeter.
                              It seems like the other readings were fine so I suspect the 96 is a correct reading. As soon as I disconnect the main board it goes down to 4.5
                              Why would the standby jumper pin not measure 7.5 or 11.8?
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                Are those voltages with old mainboard or new? Are you sure pin 16 was not .96vdc.
                                • rgla
                                  • Nov 2021
                                  • 23
                                  Old mainboard. I don't have the new one yet. Hard to find and even harder to find someone who wants to look into the problem with the board and fix it.
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    Seems you have a bad mainboard.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      This is the only site i can see who has any in stock not cheap though
                                      https://www.tvpartstoday.com/BN94-12...n94-12295k.htm
                                      • lotas
                                        • Jan 2016
                                        • 4708
                                        • Russia
                                        Most likely, the firmware of the standby mode IC1604 25Q40 flew off, as always in the "MU" series. Do you have main BN41-02570B?
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • piposarcade
                                          Samsung UN50KU6300 dead no standby led
                                          by piposarcade
                                          01-04-2024, 01:33 PM
                                          Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                                          05-22-2024, 02:07 PM
                                          09-07-2024, 05:50 AM
                                        • piposarcade
                                          by piposarcade
                                          Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it doesn't turn on.
                                          01-04-2024, 12:03 PM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
