Honda generator inverter 230v 1900uf caps
  • JFA
    • May 2011
    • 12
    I have a Honda generator with a faulty inverter. The inverter is encased in black resin with just the tops of a dozen small electrolytic caps and four 230v 1900uf electrolytic caps poking out of the top of the resin. The plastic cover of one of the 230v caps was burned off but there was no sign of bulging and the capacitor can was in good condition. The heat source looks likely to be from the outside rather than from the component itself but since the inverter is basically unrepairable, I chiseled away and removed the capacitor. I had to destroy the capacitor so had no chance to test it but it was still wet inside, not dried out or swelled. I now have the terminals exposed and can replace the cap if I consider it worth it; my dilemma. A replacement cap is around $100 and I have no way of determining positive from negative connection but a replacement inverter is $1500.
    So, if I try a new capacitor but connected it backwards, will it be destroyed?
    What is the general consensus, should I risk $100 to save $1500?
    Thanks for any suggestions or ideas.
  • petehall347
    • Jan 2015
    • 4431
    • United Kingdom
    Re: Honda generator inverter 230v 1900uf caps
    i can find those much cheaper than that
      • 31151
      if you removed the cap, isnt the polarity marked on the board?
        • Jul 2011
        • 6057
        Do not count on that being the case because I have seen a lot of boards not marked or it might not be correct ( this is rare but happens) and it is even worse when they are potted
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8289
          To tell you the truth, the odds don't look good that just this capacitor is the sole problem unless it is shorted inside. I would expect at least 2 of them 4 caps to be screwed, not just a single one.
          However, look at the bright side:
          Everything is covered in epoxy, makes it a very difficult and time consuming repair to start with.
          A cap isn't that bad to fix even it is epoxied. Cut the top lid and "unwind" the capacitor. DO NOT SNIP the old two legs that go from the cap into the main board. You need them later to solder carefully your new cap to, either with or without wires.
          • JFA
            • May 2011
            • 12
            The board is not exposed, just the two tags that were part of the capacitor. The inverter just makes that squealing sound that inverters seem to make to indicate a fault. Removing the cap made no difference to the faulty inverter.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8289
              I figured it wouldn’t be the problem.
              • JFA
                • May 2011
                • 12
                I've decided not to waste money on the off chance that this one capacitor is the problem.
                • PM5K
                  Inverter Generator Repair
                  by PM5K
                  I have an inverter generator that has two bad caps. One blew and the other was swollen.
                  My main issue is that the power supply
                  is encased in some type of epoxy.
                  My main concerns are regarding the epoxy and its purpose. I can imagine that it helps with vibration should I also be concerned with sparks since it's a gasoline generator?
                  The plan is to break off the old caps, cut the old legs off, clear out the solder points, then solder from the top since I cant get to the backside of the board.
                  This means that the legs of the caps...
                  01-13-2023, 03:15 PM
                • Gentian
                  APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                  by Gentian
                  I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                  It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                  03-06-2023, 07:07 AM
                • x_orange90_x
                  Vizio E55-E1 bad backlights or bad inverter?
                  by x_orange90_x
                  I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                  I don't know how exactly to test the inverter itself. Is it...
                  01-29-2025, 09:24 PM
                • valvashon
                  Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                  by valvashon
                  For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                  History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                  01-04-2024, 01:44 PM
                • eccerr0r
                  A modified sine wave inverter + a grid tie inverter?
                  by eccerr0r
                  If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                  Next thing is trying to charge the batteries using solar power, but that's another issue ...
                  08-31-2023, 09:14 PM
