S-10-5 power supply schematic etc. 5V 2A
  • redwire
    • Dec 2010
    • 3912
    I got a 5V 2A power supply for some hobby projects from Aliexpress store YXD Wish for about $4. S-10-5 and the build quality good, solder blob under transformer and a solder balls on the PCB top so I cleaned that up.
    Powered it up, get 5.0V but when connecting a load resistor it cratered. At 10R load which should be 0.5A, it dropped to 3.8V out and it went into hiccup mode below 5 ohms. About 1.5W output is all I can get.
    I drew out the schematic and poked around with a scope. It's running slow at 31kHz and primary current pulses are measly 30mA. So I think the IC is fake and not working, it has no markings.
    It appears to be a TX203H alternates are CR6203, RM6203, SDC603, SW2604, SL2128B. Commonly used in wall warts.
    (The bottom rung version of this same S-10-5 using phenolic PCB, uses IC DK1203 Dongke Semi and no current-sense resistor, and cheapened other stuff.)
    I asked for a refund and so far the vendor is quiet... I had another one ordered from a different Ali store but the floods took out rail and highways to the coast so it will be a while to get here and compare.
    Don't forget website comparing pinouts of SMPS IC's. Good tool to reverse-engineer the IC used when there are no markings or it popped.
    • 31248
    Re: S-10-5 power supply schematic etc. 5V 2A
    i would only buy MeanWell stuff at this point.
    they arent piss-cheap but they arent crap either
    https://meanwellonline.aliexpress.com/store/5429250
      • Jul 2011
      • 6070
      Has anyone used this type of switching power supply
      Brand : Mean Well
      Model : PSC-160A-C
      Output CH1 : 13.8V / 7.6A
      Output CH2 : 13.8V / 4A (Battery charge)
      Rated Power : 160W
        • 31248
        you probably need to ask on a cb radio forum with that output
        • redwire
          • Dec 2010
          • 3912
          The problem with these smaller power supply modules, they're always missing parts to be cheap.
          I look for: a fuse, common-mode choke/X-cap for EMC, NTC and decent sized primary cap. It's too much to ask. A name-brand AC wall-wart has all of that. But who wants to glue that down in your enclosure.
          I have another board, high quality - but the transformer runs pretty hot even at 1A load.
          In the 10W league, it's cheap chinese open-frame, or "high end" $20 potted modules like CUI PSK-S12B module. CUI VOF-10B rated 3-year life and has Teapo caps. UGH.
          Meanwell I'd looked at it was all big, 25W-50W is the smallest ,then the potted modules IRM-10-5V but who knows what's inside.
          Popular is the Hi-Link HLK-PM01 modules but no fuse, no input EMC filter.
          I'll keep looking, it seems easier to mod a cheap open-frame one.
          • lti
            • May 2011
            • 2557
            Delta also has some decent power supplies (although I saw a big fan-cooled one that appeared to adjust fan speed based on load instead of temperature), but they only go down to 15W.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8340
              I used a shitload of these Meanwell power supplies mainly wall warts. So far I had good luck with them, zero problems. I also used bigger Delta power supplies and they were also good.
              Redwire: that link doesn’t work for me.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8703
                Should there be punycode here instead of *'s?
                  • Jul 2011
                  • 6070
                  Redwire: that link doesn't work for me.
                  It does not work for me either
                  • lotas
                    • Jan 2016
                    • 4786
                    • Russia
                    "****************/ic_power/"
                    • redwire
                      • Dec 2010
                      • 3912
                      The URL for the Russian website comparing pinouts of SMPS IC's gets turned into asterisks here like this: ht tps://****************/ic_power/
                      Trying to post them, just delete the spaces to get the URL:
                      Home page: h ttps:/ / remont-aud . n e t /load
                      AC-DC SMPS IC identification: h ttps:/ / remont-aud . n e t /ic_power/
                      DC-DC SMPS IC identification: h ttps:/ / remont-aud . n e t /dc_dc/
                      Some service manuals there too, use google translate.
                      Aliexpress store YXD Wish said nothing about their dud S-10-5 power supply, sent them pics too. "Aliexpress guaranteed return shipping" means... I have to pack it up and pay probably $15 to send it back to china. UGH
                      Good news, the second power supply came in and I will post pics and schematic. At least it works.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8340
                        Thanks redwire!
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
                          by sam_sam_sam
                          07-01-2024, 06:34 AM
                        • JimBanville
                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                          by JimBanville
                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                          09-13-2023, 07:21 AM
                        • Russ1
                          Starlink GEN2 Router Internal Power Supply Chicony UTP-211C Schematic
                          by Russ1
                          Sick of seeing big numbers of these routers dead no power light underneath.....
                          Chasing Schematic of this power supply I have searched high and low....
                          Already spotted a few swollen caps, but Ac fuse ok.....
                          This is a dual output 50Vdc 2.5A and 12Vdc 1.25A psu
                          Can anyone help with any type of schematic and parts list ?
                          Thanks and Regards, Russ
                          07-10-2025, 11:01 PM
