Damaged unknow component BenQ RL2240H
  • STaRNiGHT
    • Nov 2020
    • 3
    • Spain
    Hello Folks,
    I have a problem w a BenQ RL2240H, have a sortcircuit in HDMI zone (IC serigrafied as U5), if I lift this component the monitor works well by VGA input, of course HDMI not works ..
    Anyone can help me to idendify this??? ...
    Thanks in advance
    • 31260
    Re: Damaged unknow component BenQ RL2240H
    is that "c163h" ??
    • R_J
      • Jun 2012
      • 9607
      It could be a AZC199-04S.R7G
      • gumball
        BenQ GW2450HM - Panel is partially dimmed, works for 2 hours after replacing few caps
        by gumball
        Issue: Panel is partially dark or dimmed, left side is okay (see photos attached).
        Trial: Replaced three visibly bad capacitors on the power supply board (see photos).
        First result: Monitor worked for two hours only. Two capacitors bulged again.
        Diagnosis: After replacing those capacitors the monitor was connected via HDMI cable to a laptop. Laptop was connected to power supply and charging. Power cable was removed from the laptop end and put back. Maybe this was a coincidence but since unplugging the power cable it was noted that the panel had darkened...
        10-10-2022, 01:54 PM
      • CapLeaker
        Dell ATX PSU won’t start, but forcing it works fine?
        by CapLeaker
        Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
        Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
        10-28-2024, 06:59 PM
      • siccfix
        HP Omen 15-ek0013dx - Odd 4-Zone RGB Issue, Replacing Entire Keydeck Didn't Fix It
        by siccfix
        Replaced the keyboard+LED backlight+topdeck unit with a completely assembled aftermarket part a few months ago due to failing keys (Spacebar, X, R; seems to be a common issue for 2020 model). I thought this would also fix my RGB backlight issue but the problem remains, actually it got worse, so it has to be a failing part on the mobo itself. The middle RGB zone can no longer light up blue and is instead stuck on green, even if all kb backlight is turned off that zone stays lit..
        Does anyone know what part number the IC labeled UI3 is? Seems to be some kind of LED controller chip....
        04-24-2025, 08:54 AM
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        Hi everyone,
        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
        🛠 Original Issue
        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
        Diagnosis showed PP1V5_UPC0_LDO_CORE shorted to ground.
        I replaced U3100 (UF400) using a donor board (A2179), and the machine powers on fine now.
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • howardc64
        Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
        by howardc64
        Problem
        Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
        Model & Board Pics
        Conflicting Spec
        Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
        https://www.shopjimmy.com/vizio-gj-2k1...
        10-10-2024, 01:16 PM
