removing glued s/mount chips lg lb series
  • jimbofz
    • Apr 2013
    • 539
    • uk
    recently struggled to remove BL0202 backlight chip
    which had red residue of glue underneath
    as well as annoying laquer over the top and surrounding area.
    i had to use more heat than i like to remove it
    which can cause bubbling of the bcb
    i used two different types of flux,but it was the glue causing the problem .
    just wondered if anyone has had this problem ,and if there is any solvent that may loosen the glue before desoldering?
    (some vestel fets are also glued the same way)
    this was on a LG47 LB585V,
    I had replaced the led strips which were badly discoloured only to find q806 mdhd 4n20y s/c
    r840 burnt
    and bl0202b s/c
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8288
    Re: removing glued s/mount chips lg lb series
    Cut the legs of with a knife, remove the chip, then desolder the rest of the legs on the pads.
    • jimbofz
      • Apr 2013
      • 539
      • uk
      thanks at least someone reads my posts
      thats a good idea
      but when salvaging a chip from a scrap board obvious wont work
      so any thaughts on solvent to loosen the bond ?
      this repair has caused me grief as the availibility of MDHT4N20Y fet
      i could order from china but waiting 2 months is the problem
      even the chip BL0202B are scarce in uk
      • diif
        • Feb 2014
        • 6978
        • England
        Plenty of people read the posts, photos always help get a response.
        I'm guessing the red glue is adhesive not underfil so a bit of heat and one of the BGA blades to cut it.
        I'm not sure where you're ordering from but my stuff takes around 2 weeks from Aliexpress.
          • 31151
          philips use the red glue, you just heat the chip with hot air till the solder melts - then twist it with tweezers and the glue breaks.
          it's weakened by the heat
          • jimbofz
            • Apr 2013
            • 539
            • uk
            what max temp would you suggest ? i normally use 250 degrees
            i had to turn up to max to budge it which is not good for the pcb
            • jimbofz
              • Apr 2013
              • 539
              • uk
              i must just be unlucky
              aliexpress varies so much with del times
              and quality of product is sometimes poor
              • cheeky2
                • Dec 2012
                • 337
                • uk
                When you order on Aliexpress the cheapest option of postage is always the longest. You can select a quicker speed of postage more expensive that gets delivery within a couple of weeks.
                It is not intuitive to select the higher postage costs but it's generally available on all listings, as I recall you use a dropdown menu to select different options within your basket. Look and use sellers by the quantity of the orders and there feedback of the quality of the goods. Don't just buy product only on the basis of the price, which I am guessing you have done previously. You may pay a little extra but at least you will get it quicker and better quality.
                  • 31151
                  heat needs to be 300-350 really
                  as for ali, dont use "super cainiao" shipping, stick with ali standard or saver
                  • jimbofz
                    • Apr 2013
                    • 539
                    • uk
                    ive always tried to remove s/m components with the minimum temp
                    and then increase temp if the item is stubborn
                    and use the smallest nozzle on my s station
                    to prevent other close components flying off .
                    i will try 300-350 thanks
                    • jimbofz
                      • Apr 2013
                      • 539
                      • uk
                      thanks thats good advice
                      i will follow it on next order
                      • acedogblast
                        by acedogblast
                        11-02-2024, 05:13 PM
                      • ugamazing
                        Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                        by ugamazing
                        I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                        08-31-2022, 07:34 AM
                      • harp
                        Metod for removing glued heatsink from fragile component
                        by harp
                        I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                        06-23-2025, 02:01 PM
                      • ktmmotocross
                        how to remove black glue in edges of chips in Lenovo laptops?
                        by ktmmotocross
                        hello.
                        That black glue in edges of chips on Lenovo laptops always lift me pads so i stop reworking them. Is there anyway how to get rid of it gently?
                        11-16-2023, 01:17 AM
                        Surface Mount Fuses Fundamentals Datasheet
                        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                        10-07-2024, 06:07 AM
