Old 12-03-2021, 08:33 AM   #1
Biruslapio
City & State: ST
My Country: Brasil
Line Voltage: 220V 60Hz
I'm a: Student Tech
Default Reprogram Philips 32PFL3008D Winbond EEPROM with ATMEGA328P
I've shearched before posting this, and found dozens of different ways to hook up multiple types of EEPROM to an Arduino Uno, so I do not know which one is correct.
I need to learn this so I ended up with a Philips TV 32PFL3008D which has corrupted memory, the IC is U402, 25Q64FVSIG, I have the 3MB .bin file, how to hook up an ATMEGA328P to this memory and what code do I need?
Biruslapio is offline   Reply With Quote
Old 12-03-2021, 08:50 AM   #2
lotas
City & State: Sochi
My Country: russia
Default Re: Reprogram Philips Winbond EEPROM with ATMEGA328P
The 25Q64FVSIG memory size is not 3Mb, but 8Mb should be.
lotas is online now   Reply With Quote
Old 12-03-2021, 09:24 AM   #3
Biruslapio
City & State: ST
My Country: Brasil
I'm a: Student Tech
The firmware .bin file directly from philips has the size of 3.293.184 bytes.
Old 12-03-2021, 09:57 AM   #4
lotas
City & State: Sochi
My Country: russia
If the file is from Philips, then it must be updated via USB. Or through a terminal program.
Old 12-03-2021, 10:23 AM   #5
lotas
City & State: Sochi
My Country: russia
https://www.p4c.philips.com/cgi-bin/...scy=PE&slg=LSP
Old 12-03-2021, 12:39 PM   #6
Biruslapio
City & State: ST
My Country: Brasil
I'm a: Student Tech
hm, this shows how clueless I am, I found an 8MB flash for the correct panel version, so what do I do now? It is 8MB or 8.388.608 bytes
https://www.electronica-pt.com/esque...a-flash-73876/
Old 12-03-2021, 01:41 PM   #7
lotas
City & State: Sochi
My Country: russia
25Q64FVSIG - 8 МБ = 8,388,608 bytes
Everything is correct, it should be so.
Old 12-03-2021, 02:19 PM   #8
Biruslapio
City & State: ST
My Country: Brasil
I'm a: Student Tech
Yes, but now what needs to be done for flashing with an Arduino Uno?
Old 12-03-2021, 02:42 PM   #9
lotas
City & State: Sochi
My Country: russia
I can’t help with this (I don’t have an Arduino), look on the Internet, for example here
https://forum.arduino.cc/t/read-and-...winbond/493705
It may be easier to get you a simple, cheap programmer "CH341A".
Old 12-03-2021, 03:16 PM   #10
Biruslapio
City & State: ST
My Country: Brasil
I'm a: Student Tech
It looks like it's not a simple caveman setup like "connect eeprom to board and flash", it needs resistors, diodes, and without a proper pcb it will be a flimsy mess, so I give up and will just buy a proper CH341A + tools.
The listing I'm buying from only lists compatibility to 25Q64BV and 25Q64FW, will it not work with 25Q64FV?
Old 12-03-2021, 03:43 PM   #11
lotas
City & State: Sochi
My Country: russia
There are many programs for CH341A which support your spi flash 25Q64FV
These are programs (CH341A) such as
CALIBRI, AsProgrammer, NeoProgrammer.
Old 12-04-2021, 05:09 AM   #12
cheeky2
City & State: london uk
My Country: uk
Depending on the software you have for the ch341a i would use version 1.30 just ignore the orientation of the ic in the programmer picture and use the location on pin1 on your programmer. Click on detect in software and it will give you options to identify the flash ic. Just select closest to the flash ic you have. It will programme the flash ic up correctly. If you are going to programme regularly then you will need and adapter to convert to SOP8 to DIP8 get the wide 200mil one otherwise ic will not fit in the adapter! Don't buy the clip as it gives unreliable results if you are using in circuit without removing the flash ic!
cheeky2 is offline   Reply With Quote
Old 12-06-2021, 01:48 PM   #13
Biruslapio
City & State: ST
My Country: Brasil
I'm a: Student Tech
Default Re: Reprogram Philips 32PFL3008D Winbond EEPROM with ATMEGA328P
The CH341A arrived today, took 10 minutes to figure out and program the 25Q64 using AsProgrammer. Thank you lotas and cheeky2 for pointing out the need for a proper programmer.
I was wrong about the panel version, there's two, TPVISION and ENVISION, mine was an TPVISION model but couldn't find the .bin for that (I have both now), so I used ENVISION, only problem was that the resolution was wrong and pixelated, plus the screen was upside down, using a USB flash drive .bin update for tpvision renamed to envision, it worked, TV is fine, thank you all.
Old 12-06-2021, 02:42 PM   #14
lotas
City & State: Sochi
My Country: russia
In TV Philips, you can change your panel using the remote control by code.
Old 12-06-2021, 02:48 PM   #15
Biruslapio
City & State: ST
My Country: Brasil
I'm a: Student Tech
Well, the sticker says "Option code: NA", and the universal remote I'm using doesn't emit any output using the "return" button when configured to Philips TV, I tried using menu 1 9 9 9 return.
Old 12-06-2021, 03:05 PM   #16
lotas
City & State: Sochi
My Country: russia
This is where the xxx code comes in. But you need an original remote control.
Badcaps.net Technical Forums © 2003 - 2022
