820-4924 - No Power - Gets Green Then Orange Light
  • grimacelord
    • Jan 2017
    • 383
    Board had previous liquid damage. It was initially ultrasonic cleaned. Keyboard, battery, and trackpad flex cable were all replaced and it worked fine. Board is back for no power. Hoping someone can help me out here. Voltages taken with board, DCIN board, and original 85W charger only, no battery.
    PPPBUS_G3H - 12.54V
    PP3V42_G3H - 3.42V
    ALL_SYS_PWRGD - 0V (No pulse when triggering SMC_ONOFF_L )
    PM_SLP_Sx_L - Pulses when triggering SMC_ONOFF_L
    PM_RSMRST_L - 3.28V
    PM_PWRBTN_L - 3.42V
    PCH_DSWVRMEN - 3.18V
    PM_DSW_PWRGD - 3.43V
    PPVCC_S0_CPU - 0V, No pulse
    PLT_RESET_L - 0V, No Pulse
    PP3V3_S0 - 1.69 - 1.75V fluctuating.
    PP3V3_SUS - 3.33V
    L7520 0v
    L7430 0V
    L7560 3.33V
    L7710 0v
    L3095 11.6v
    L7130 12.54
    L7320 0V
    L7310 0V
    L7630 26mV
    U1950 PIN 5 - 0.8mV - 0.9mV seems to change (pulse?) between these two measurements.
    U1950 PIN 6- 0V, no pulse
    Board DOES start in SMC Bypass Mode with high fan spin.
    I'm really not sure what to do here. I'm still new to board level repair so I was hoping someone can look at this and help me figure out what is wrong. Thank you.
  • reformatt
    • Feb 2020
    • 1536
    Re: 820-4924 - No Power - Gets Green Then Orange Light
    With liquid damage, corrosion is often an ongoing process, especially if it's gotten under a BGA or two. Don't rush to ultrasonic clean a board; the original corrosion spots are your biggest clues in fixing the fault(s). Once you clean the board, all those pointers are washed away. If you have an iffy track/pad/via, they can be very difficult to find without those hints.
    Take photos of the affected areas before rework so you know where to check if the job bounces. A good eye is very important when dealing with corrosion. Sometimes you can get crap under a BGA (like SMC etc) so this can cause all manner of issues.
    Having said that, PP3V3_S0 being low is where I'd start.
    • grimacelord
      • Jan 2017
      • 383
      Thanks for the tips.
      I went back and sort of studied the schematic. That lead me to U8030. I pulled it and a couple of it's pads looked kinda crappy, so I cleaned them and reballed U8030. Not only did it restore PP3V3_S0, but the computer boots now.
      Thanks again.
