lg 47LB585V help to identify ic please
  • jimbofz
    • Apr 2013
    • 539
    • uk
    Hi this lg has a rediculously small 16 pin ic on mainboard cooking
    causing brief flash of sby led then dead its the one next to a coil 2r2
    reference ic2403 i cant make it out looks like:
    5419
    0rAA
    A36X
    this tv had bad b/l leds and i replaced all the strips with new
    they tested fine with led tester ,ifound the b/l controller ic s/c bl0202b and q803 s/c these were replaced but leds just flashed on for one second .
    to save time (big mistake) i ordered replacement psu from e bay
    when fitted it caused the mainboard problem grrr!
    now even my original psu wont start up
    ive tried to find cct for main board i can only find psu cct
    if someone can help me identify the ic or suggest why the rogue psu has caused the problem it would be a great help
    the rogue psu is:EAX65423801(2.1)REV 2.0
    the original psu is:EAX65423801(2.2)REV 2.1
  • lotas
    • Jan 2016
    • 4785
    • Russia
    Re: lg 47LB585V help to identify ic please
    ic2403 - TPS54319
    • jimbofz
      • Apr 2013
      • 539
      • uk
      Originally posted by lotas
      ic2403 - TPS54319
      many thanks ,now i have somewhere to start ,
      i suspect ,as it gets hot.
      something external to it is drawing current through it
      • lotas
        • Jan 2016
        • 4785
        • Russia
        service manual
        • jimbofz
          • Apr 2013
          • 539
          • uk
          service manual
          thanks ,i have s/c on pins 1 and 2 to ground.
          im going to try to replace ,removal no problem with s station but fitting new will be a chalenge,
          im going to force on the psu without connecting main board and see if 3.3v supply is high ,do you think this could be the reason the ic failed?
          • lotas
            • Jan 2016
            • 4785
            • Russia
            If it exceeded more than 7v, then the IC could burn out.
            • jimbofz
              • Apr 2013
              • 539
              • uk
              not looking good .pin 10,11,and12 .the 1.5v o/p s/c
              so protection zener zd2401 was never fitted
              so any number of components could be s/c
              • lotas
                • Jan 2016
                • 4785
                • Russia
                1.5v for power supply of random access memory (DDR).
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  If you lift L2411 are pins 10, 11 & 12 still short and if not is the other end of L2411 showing the short.
                  • jimbofz
                    • Apr 2013
                    • 539
                    • uk
                    thanks for joining in the party mr b
                    when L2411 Lifted it measures 240 ohm .so not short but still a bit lower than i would expect ,what do you think?
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Are you saying L2411 has a resistance of 240 ohms or the output of the IC (1.5V ) to ground measured 240 ohms.
                      What is the resitance with the meter on one pad of L2411 to ground and again what is the reistance from the other pad of L2411 to ground both checked with L2411 lifted.
                      If the resistance of the IC2403, pIns 10, 11 & 12 is 240 ohms to ground then that would appear to be OK.
                      • jimbofz
                        • Apr 2013
                        • 539
                        • uk
                        the o/p of the coil when lifted is 240 ohm to deck ie the 1,5v supply 240 ohm
                        the other side is dead short to deck i know the tps54319 is duff
                        but i would expect a much higher value on the 1.5v o/p side
                        the coil itself is fine very low ohms
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          The 240 ohm reading would appear to be fine and is not a high load on the 1.5V supply
                          • jimbofz
                            • Apr 2013
                            • 539
                            • uk
                            ok thats reassuring .ive found a scrap pana main board with similar ic so im going to practice removing and refitting on this .what is interesting is on the pana main board the o/p pins 10,11,12 read 3.9k to deck
                            i know all ccts differ so best not to read into this too much ,
                            i think the board came from a pana TX-L 32C5B
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              You may well be correct. Just looking at the application note show there are two mosfets connected in totem pole so the 240 ohms could well mean that one of the internal mosets is damaged.
                              Good luck with your repair. Use plenty of flux with the solder and be patient.
                              • jimbofz
                                • Apr 2013
                                • 539
                                • uk
                                ic2403 - TPS54319
                                a question for lotas
                                do you know if:
                                0101
                                5173
                                is same device ?
                                ive found one on a panasonic tx-l32c5b main board
                                • lotas
                                  • Jan 2016
                                  • 4785
                                  • Russia
                                  do you know if:
                                  0101
                                  5173
                                  is same device ?
                                  "5173" - This is your G5173.
                                  Check datasheets. Your family should be marked "54319".
                                  • jimbofz
                                    • Apr 2013
                                    • 539
                                    • uk
                                    wow thanks for quick reply
                                    it looks the same BUT its o/p is: 1.8v not 1,5v
                                    its markings are :0101
                                    5173
                                    • lotas
                                      • Jan 2016
                                      • 4785
                                      • Russia
                                      5173
                                      Their output voltage is set by a resistor divider.
                                      • lotas
                                        • Jan 2016
                                        • 4785
                                        • Russia
                                        To test the mainboard, you need to dismantle the TPS54319 and connect an external laboratory power supply (+) to the L2411 with 1.5V - 2A.
                                        • thesame
                                          DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                                          by thesame
                                          Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                                          The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                                          02-27-2024, 04:31 AM
                                        • silver60618
                                          Lenovo Legion 7 - Help Identify IC
                                          by silver60618
                                          Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                                          I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                                          Any help would be appreciated...
                                          07-02-2025, 12:16 PM
                                        • chth96
                                          How can I identify varistor which have been blew up?
                                          by chth96
                                          I mistakely pluged 100v japanese retro game console to 220v outlet.
                                          So It seems that glass fuse and varistor have been blew up.
                                          I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                                          Is there any way to identify varistor type in my sega saturn PSU?
                                          Any reply would be appreciated.
                                          EDIT:
                                          It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                                          11-26-2023, 08:52 AM
                                          BL0202C BL0202B BL0200C Datasheet
                                          The BL0202C BL0202B BL0200C are 2ch output LED driver IC for LED backlight, and it can do dimming to 0.02% by external PWM signal.
                                          This IC realizes a high efficiency by the boost convertor control that absorbs variability on VF.
                                          The product easily achieves high cost-performance LED drive system with few external components and enhanced protection functions.
                                          Features and Benefit
                                          Boost Convertor
                                          ● Current-Mode type PWM Control
                                          ● PWM frequency is 100 kHz or 200 kHz
                                          ● Maximum On Duty is 90%
                                          LED current...
                                          10-07-2024, 04:48 AM
                                        • freakorio
                                          Need Help To Identify Component on Ymain LJ41-05120A
                                          by freakorio
                                          Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                                          05-21-2024, 02:32 AM
