Samsung UN32N5300 SmarTV -2018
  • jason123
    • Oct 2015
    • 1083
    Hi Folks,
    Got this TV, with power / main combo board. The TV has the front LED indicator on. Indicator Seems responsive to remote and push button activity.
    No Backlight or image with flashlight at all. Optical Audio doesn't come on. First check was backlight. Checks out with tester, but still i opened it up and each LED checks out. 3 strips, 6 LEDs each.
    Second check the large cap. It never goes into full voltage (running at 160 VDC), but PFC doesn't seem to kick in. when I press power button, momentarily goes to 163, then back to 160. Any suggestion where to look?
  • neilc6
    • Nov 2015
    • 1550
    Re: Samsung UN32N5300 SmarTV -2018
    Very difficult to debug these combo boards. If TV doesn't turn on, likely issues with the processor or eeprom. I had one with a blown fuse and shorted FET. Replaced both and shorted again. Would just replace the whole board.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Check voltages on main. I think optical is on 3.3v
      • jason123
        • Oct 2015
        • 1083
        3.3 v, 5 v, 12v, 1.9 v are all present. Led voltage is about 27 V differential (not enough to turn leds on- need 54 v or so)
        • dskall
          • Oct 2016
          • 2905
          • usa
          Well worst case if rest is working is buy an inverter for your backlights.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Just a quick thought. Can you check the resistance and inductance of T9101C. There have been a few issues with inductors running hot and failing in the led circuits.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Maybe someone smarter than me will jump in. Not sure if there is pfc on this board. Is that one coil for pfc or just filtering?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Another though is...........have you measured the voltages at the led connector (with leds disconnected) and then power up and see what the voltage peaks to. If ithe peak exceeds the 57V then it's possibly faulty led(s).
                • jason123
                  • Oct 2015
                  • 1083
                  R = 1.8 Ohm
                  L= 1.216 mH
                  • jason123
                    • Oct 2015
                    • 1083
                    ÷ LEAD READS 110V NEGATIVE LEAD READS 77 V. So Differential is less than 57 v
                    • jason123
                      • Oct 2015
                      • 1083
                      No image is displayed on screen , so not just no backlight, unfortunately
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        Is your processor getting warm? Oscillator working, voltage to eeprom? Thinking you should have a 1.2v to run processor.
                        • jason123
                          • Oct 2015
                          • 1083
                          processor is getting warm, crystal has some activities (loading of a scope pretty much messes it up), and eeprom has 3.3 V. I don't see 1.2 V on the board, but I do see 0.9 (core?), 1.9, 3.3,...
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            Getting voltage to t-con? Data going out on lvds? Voltages on t-con?
                            • jason123
                              • Oct 2015
                              • 1083
                              Getting voltage to TCON - 12V on both sides of the fuse. 3.2V is on TCON also. Initial activity on the LVDS but then nothing
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                And the other t-con voltages?
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  You might want to read some part# off of 8 pin chips around your processor. Maybe multi voltage regulator chips.
                                  • jason123
                                    • Oct 2015
                                    • 1083
                                    The only thing that I could find suspicious about the board, is this 630V Cap that is swollen and the epoxy cracked as shown in photos. It's not shorted, and it has about 2.2 nF measured capacitance. Any idea where I can get a replacement if you think it might be the culprit?
                                    I do have a board installed in the TV and it's fine.. Would be nice to fix this one.
                                    • R_J
                                      • Jun 2012
                                      • 9579
                                      The cap is usually used to connect the transformer winding to ground. digikey should have them
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        Funny it didn't look bulged in first pictures. Now you have a board that you could compare voltages on. Suspect maybe bad processor or firmware.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
