Fake wire gauge
  • Behemot
    • 4845
    • CZ
    Fake wire gauge
    Not that I am that surprised, but just noticed while cutting of some SATA cabling from dead crappy PSUs for making molex-to-dual-SATA adapters, they are not satisfied with using small wire gauge, they even fake it on top of that.
    Had one very thin set which made me curious if that's even gonna be enough for two drives (I'll likely use it just for SSDs I guess) but it states 20AWG on the insulation. Than another one also 20AWG but by eye-meter at least one third thicker, if not twice the gauge, this is surely genuine 20AWG.
    So if you see very thin cables next time, check if the spec on it is not faked
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Fake wire gauge
    Wow... there is no corner that they won't cut. Do you have any pictures? What brand were the PSUs with the fake gauge that you've come across so far?
    • Behemot
      • 4845
      • CZ
      Re: Fake wire gauge
      too lazy too take pictures, it's very thin so phone's out of question lol
      this particular piece was Evolve (local brand which takes whatever they can find), still some old half-bridge crap with likely faked PFC coil too
      • lti
        • May 2011
        • 2557
        Re: Fake wire gauge
        I saw this in the goofy power supply included with my Vantec CB-ISA225-U3 IDE/SATA to USB bridge. That is only for temporary use with a 12V 2A power supply and a 5V DC-DC converter with a 2A rated chip (TD1410), so it isn't a big deal.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8703
          Re: Fake wire gauge
          How low can they go...wow.
          And 20AWG wire is not that thick to begin with... that's pretty thin already. 22AWG is too thin IMHO except for single SSDs probably. For things like CPU and possibly even hard disk power cable I'd want at least 18AWG...
          But still might want to pull it through a strip gauge to make sure however, thicker insulation does sort of give an optical illusion the wire is thinner. Also stranded/solid can fool the eye as well.
          I'm surprised, thought wire was gauged with mm² instead of AWG outside of the USA. AWG, like feet and gallons is a USA thing, I thought. Unfortunately this is one of those things I can't easily convert AWG to mm² and have to look up, so nobody give me mm² wire specs and expect me to know what you're talking about right away
          • Behemot
            • 4845
            • CZ
            Re: Fake wire gauge
            never seen any ATX PSU cabling gauged otherwise than AWG, guess it has to do with ATX spec?
            I've soldered these so the difference surely is there; actually cut the true 20AWG from that maxpower or rexpower or which PoS it was, if you remember those units which had only like 2/3 of the depth of ordinary ATX PSU? The insulation is thicker sure but the copper inside is as well.
            This Evolve thing cabling made me curious even before I cut it, the wiring is very thin, you can see it right away that something is strange there. And I found the reason obviously. Would guesstimate the real gauge to be 22 AWG at the best
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8703
              Re: Fake wire gauge
              True that the ATX spec came from Intel, but I'd think everything would try to be metric-ized and not deal with weird USA units like miles or pounds...
              Ultimately have to measure voltage drop to see if something is acceptable or not...hard to do in circuit. Sigh.
              Would be nice to see photograph of printing on the jacket just for grins...
              • Behemot
                • 4845
                • CZ
                Re: Fake wire gauge
                OK, nevermind. Looks like I'm a douche
                Went to check the adapters I've soldered to maybe take a photo. I've noticed only now that the max/rex/whatever-power has 20AWG wires, but only splitting from the first SATA connector to the second. Up to the first one from the board, it is 18AWG! Totaly missed it. So that's why it felt thicker While the Evolve has only 20AWG everywhere.
                Sorry for misleading ya and time to apologise to that Evolve unit (not that it's not a gutless wonder otherwise ).
                  • 31259
                  Re: Fake wire gauge
                  they need to scrap "WG" numbers and go to mm-squared.
                  and by "WG" i mean both AWG and SWG.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8703
                    Re: Fake wire gauge
                    Then again I would not be very happy with wires that use a whole bunch of significant digits to accurately specify a wire... like if I needed to specify 0.519mm^2 I think I'd rather specify 20AWG...
                    What would one do with 0.5mm^2 wire in this case... was this supposed to be 20AWG?
                    • wnlewis
                      New wire for my RDE3340 Whirlpool electric range
                      by wnlewis
                      OK. I got the rocker switch figured out thanks to the good advice on this forum.
                      Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                      This is a Whirlpool RDE3340 electric range.
                      The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                      Where may I find parts...
                      01-08-2025, 11:21 PM
                    • emeskay
                      Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                      by emeskay
                      We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                      08-06-2024, 07:13 AM
                    • technicalspecialist
                      Vintage fan repair, copper wire question
                      by technicalspecialist
                      I currently have a customer's vintage fan on the work bench to repair.
                      It uses an induction motor with 4 poles. One of the poles is open.
                      I couldn't find the break so i cut off the original wire.
                      I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                      I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                      The enamelled copper...
                      03-16-2023, 12:54 PM
                      Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                      by sam_sam_sam
                      I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                      I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                      12-16-2023, 08:39 PM
                    • kalemaroni
                      Dell DC Brown wire
                      by kalemaroni
                      There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
                      08-26-2025, 10:10 AM
