Failed Panasonic FL
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Failed Panasonic FL
    This is the first time that I've seen an Panasonic cap fail that wasn't installed backwards (at least that I can remember).
    It's a 1800uF 6.3V part. It's from a Dell Optiplex 780 SFF from 2010. CPU is a Core 2 Duo E8500 3.16GHz. It was a point of sales machine at a car dealership and was NEVER off! It was on a UPS, and had 82,156 hours on it when I got it. It had never been cleaned, never had the thermal paste replaced. The thing literally just worked for 10 years. It's a cool machine because it's one of the highest end Core 2 Duo CPUs with DDR3 RAM
    I got the machine in August 2020. I took it apart and saw that the board had 9 KZG caps on the board, none looked bulged. I took apart the PSU (total PITA, by the way) and saw a bulged CapXon. After taking apart the power supply, I discovered that there was only the one 2200uF 16V CapXon GF for all of the 12V rail filtering. I'm guessing after that bulged, the 12V ripple was really high. I replaced all of the KZG on the board and did a full recap on the PSU (including the primary cap!) and replaced the thermal paste on the CPU and Northbridge heatsink. I instantly started using the machine as a Plex media player in August 2020. I set it up to run 24/7.
    The original GPU fan on the ATi video card failed in December 2020 and I replaced it. At that point, the cap was still good.
    I shut down the computer to move in June 2021 and I noticed that the cap was failed. So at the minimum, it still ran for 85,0000 hours in a small low airflow case directly in line of CPU exhaust heat. Not bad! The same size/series caps next to it tested perfectly in spec. I was worried at first that the PSU didn't like my recap and was outputting high ripple but it makes more sense that it just had a long stressful life.
    Here is a picture after I recapped it so you can have a good idea of where the cap was:
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Failed Panasonic FL
    Here you can see the PSU before it was recapped or cleaned. You can see that failed CapXon in there:
    • linuxguru
      • Apr 2005
      • 1564
      The FL was near the HSF outflow side, about the hottest location in any SFF - no surprise that it failed. However, all the Rubycons (MBZ?) near it seem to be fine - as expected.
        • 31142
        those compact things are terrible, you should have gone full-polymer
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Yes the Rubycon were all okay
          Even all of the small caps? I replaced the 1800uF 6.3V Panasonic FL with 2200uF 6.3V Rubycon ZLQ.
            • 31142
            the small caps may be audio - you can use tants for that anyway.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              I replaced all the KZG with polymer at least. I think it will last a long time. If I need to replace some more caps on the board later, that's fine. I just don't want to have to work on that PSU ever again... lol
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Here is the PSU all cleaned and recapped
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Wow, you can hardly tell it is the same PSU as in the earlier pictures! Nice work!
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    Welcome back P4!
                    Excellent work like the good old days
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      I've actually seen many Dell toasters roast Panasonic caps ranging from the GX270 all the way up to GX755 era stuff and newer. Not as common as other brands frequented by Dell (Rubycon, Nichicon, and UCC)...but its certainly happened plenty.
                      Nice job on the refurb! I love seeing this versus it being scrapped!
                      <--- Badcaps.net Founder
                      Badcaps.net Services:
                      Motherboard Repair Services
                      http://folding.stanford.edu/
                      Team : 49813
                      Join in!!
                      Team Stats
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        Yeah, that's what happened most likely.
                        Even Panny FL can take only a finite amount of use/abuse before they fail.
                        Now I can't recall if this was with FJS or FL series, but I also had a Panasonic cap bulge on me after storing a machine for a while. It was actually the Pegatron M2N78-LA motherboard from an HP Pavilion p6247c PC, shown in this thread:
                        https://www.badcaps.net/forum/showthread.php?t=90727
                        ^ Basically, I haven't posted an update on that thread, but I pulled out that system in September of this year to use it for testing some hardware... and that's when I noticed I had a bulged cap next to the CPU. I last posted in that thread at the end of 2020... so looks like the cap bulged somewhere in between the 9 months or so in storage.
                        It's an HP, though, so no surprise. Notice there are only 4 of those Panasonic (FL or FJS) 1800 uF caps total filtering the CPU output... and the CPU is an Athlon II X4 - not exactly light on power usage. The board has space for 6 caps total (so 2 empty spots.) Probably HP decided to be cheap and cut some corners... which made the 4 installed ones have to work harder... and probably why one of them failed. At least that's my guess to why it failed, but I could be wrong too.
                        So yeah... high ripple current for long enough time will break down even the good Japanese brands.
                        I know, right.
                        If we didn't know Pentium4 any better, we could certainly say this was fake and he just pulled a new PSU on us.
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Thank you! Yes, it's much happier now
                          Welcome back P4!
                          Thanks! Yes, I have some things to work on and post. Maybe even some updates of past projects.
                          Oh no doubt, just the sample size alone of all the stuff you see No discredit was intended to Panasonic. It did its job and then some. Heat aside - I bet it wouldn't have popped if that CapXon was a quality brand from day one. My company was going to give this to a local company to melt down... I like that better than the dumpster, but still couldn't let it happen. It's been running like a champ ever since I replaced that cap.
                          • kevin!
                            recapping PCB.
                            • Jul 2013
                            • 195
                            • España
                            Surely it has failed due to the heat, I would add a fan to keep the chipset and the capacitors that are nearby cool.
                            How many hours does the hard drive currently have? Out of curiosity.
                            I have a 500GB Seagate 7200.14 series and it already has 78,000h XD.
                            Gaming pc:
                            nVidia RTX 3080 TI, Corsair RM750I.
                            Workshop PC:
                            Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
                            Server:
                            • ahmedtou
                              HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                              by ahmedtou
                              Hi everyone,
                              help me please
                              I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                              When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                              I will share all the details with you, including the disc information.
                              Code:
                              HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                              Current Profile: BD-R
                              Disc Information:
                              Status: Empty
                              State of Last Session: Empty
                              Erasable: No
                              Free Sectors: 12,219,392
                              Free Space: 25,025,314,816 bytes
                              Free Time: 2715:27:17 (MM:SS:FF)
                              Next
                              08-27-2025, 08:49 AM
                              ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                              This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-12-2024, 03:28 PM
                            • Andre Gilbert
                              by Andre Gilbert
                              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                              11-20-2024, 08:52 PM
                            • CG2
                              Janome DC3050 Sewing Machine Pedal Resistance
                              by CG2
                              OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                              Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                              04-14-2023, 07:53 AM
                            • Soulzink
                              Samsug washing machine. Power supply DC41-00189a board issue
                              by Soulzink
                              Hi everyone,
                              I am trying to fix a samsung washinmachine power supply main board.
                              I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                              Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                              The power supply board reference is the following: DC41-00189a
                              I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                              04-19-2025, 06:26 AM
