Help diagnosing PWO1025 SMPS
  • snoptel
    • Dec 2021
    • 49
    Wondering if anyone can offer some insight into solving the problem with this SMPS.
    Model is - PWO1025
    Manufacturer - Power-Win Technology Corp.
    So, it was working unit I accidentally shorted one voltage rail to ground while troubleshooting one of the logic boards power by this PS.
    I replaced a blown fuse and a fried bi-polar transistor and now I have 33VDC, 12VDC but 5VDC and 3,3VDC are missing.
    A schematic would be nice, but the manufacturer doesn´t make them available - I asked.
    Anyone know what I could check, I really don´t want to reverse engineer the thing.
    FYI - Some components have been removed in the last picture, that's not the source of the problem
  • R_J
    • Jun 2012
    • 9607
    Re: Help diagnosing SMPS
    Is the 5v and 3.3 v supplied by the same transformer as the 33v and 12v? Sometimes there are low value resistors between the transformer and the supply diode, it may be open.
    You could provide a high quality, in focus picture of the trace side of the power supply and we may be able to trace the problem
      • 31259
      do those voltages get switched by the blue relay?
      • snoptel
        • Dec 2021
        • 49
        Re: Help diagnosing PWO1025 SMPS
        Thanks for the reply guys.
        I´ve uploaded some more pictures.
        R J - I traced the 5V supply from the end of the board all the way to the IC circled in blue. Seems like that's where it comes from. As for the 3.3VDC, I have no idea - it isn't even labeled on the board´s output pins.
        stj - I haven´t followed the circuit leading up to or from the blue relay.
        Keep´em coming
        • R_J
          • Jun 2012
          • 9607
          The 12v is not supplied by this board, P160 connects to P164 only. What makes you think there is a 3.3 volts on this board?
          The +5 volts is derived from the voltage (10~40v) which will be on the 3 amp fuse, U2 is the 5 volt controller which drives the base of Q2, (10~40v) is supplied to the emitter and the +5volts will be on the collector, which finds its way through the coil L9, through R52/R59 through L13? to the plug. The +5v is monitored (via pin1 of u2) and may not be there unless there is a load on the 5 volt line.
          Which transistor was blown? and was it shorted ? if it was Q2 that was blown, U2 may also be damaged.
          • snoptel
            • Dec 2021
            • 49
            Hmm, not sure. The board powers a Bernina embroidery machine. On this board there are only two cables connected, one on pins 164 and the other on the yellow pins labeled with 33v, GND, and 5v.
            Prior to my bad luck of shorting 5V to GND, I had all four voltages on a second control board powered from this PS, connected via de aforementioned two cables.
            I´m starting to think that the 3.3VDC come from the control board powered from this board.
            I have 33VDC and 12VDC from this board, if I can only figure out what's faulty with the 5VDC rail I think the 3.3VDC will also be resolved.
            • R_J
              • Jun 2012
              • 9607
              There is a diode near C35 and the yellow plug, this could be a zener diode and may be shorted or damaged killing the 5 volts.
              • snoptel
                • Dec 2021
                • 49
                I actually measured that zener in place and reads shorted on the multi meter in diode mode, however it was in place.
                If I get a moment today I´ll remove it and check.
                I will revert back ASAP.
                • snoptel
                  • Dec 2021
                  • 49
                  Sorry, I didn´t see this reply.
                  Yes, the bi-polar transistor Q2 and the fuse directly above it were blown. Once I replaced the fuse and transistor I got 33 and 12VDC connected to load.
                  I did follow the 5v rail and found my way to U2 and to the bi-polar Q2 and you are right on what you say regarding the circuitry.
                  I suspect U2 may be damaged.
                  Once I check the zener, I may just order another U2 and replace it..
                  • snoptel
                    • Dec 2021
                    • 49
                    Ok, checked the zener, reading is 0v on both forward and reverse bias.
                    Monday I´ll swap it with a new one and go from there.
                    Thanks for the help!!
                    • R_J
                      • Jun 2012
                      • 9607
                      I take it you are using diode test (0v) then it is indeed shorted, remove it and check it's resistance out of circuit to be sure it is the diode that is shorted and not something else on the 5v line.
                      • snoptel
                        • Dec 2021
                        • 49
                        Yes, diode test. The reading of 0v is with the zener removed from the circuit.
                        Resistance value is around 1 ohm both ways, forward\reverse.
                        Tomorrow I´ll swap it and see.
                        • R_J
                          • Jun 2012
                          • 9607
                          If the protection zener is shorted, that would definitely kill the 5 volt supply. hopefully that is all that is left that is wrong.
                          • snoptel
                            • Dec 2021
                            • 49
                            fingers crossed.
                            • snoptel
                              • Dec 2021
                              • 49
                              Hi R J, it's alive!!
                              Swapped the zener and now all four voltages are present.
                              Thank you and everyone else for the help.
                              SOLVED!!
                                • Jul 2011
                                • 6070
                                One more item that did not end up in the landfill
                                Good work repairing it
                                • UglyBetty
                                  • Jan 2022
                                  • 20
                                  Great to hear you had a positive outcome. I need to learn more about zener diodes.
                                  • dkneyle
                                    Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                                    by dkneyle
                                    This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                                    Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                                    02-01-2022, 02:08 AM
                                  • shamsudeen
                                    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                    by shamsudeen
                                    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                    i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                    07-19-2025, 07:14 AM
                                  • abhishekkumar1902
                                    Huntkey HK340-72FP SMPS shut on load above 2 amps
                                    by abhishekkumar1902
                                    I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
                                    I have checked the following:
                                    1. All output caps are OK, and all output rails read correct voltages at no load
                                    2. All output diodes are OK
                                    3. NTC is ok
                                    4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
                                    5. No short in main switching MOSFET
                                    6. All other components...
                                    12-18-2022, 09:52 AM
                                  • madan1
                                    Mackie Th15 SMPS low Vout
                                    by madan1
                                    I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
                                    It is basically a smps with amp and some dsp.
                                    The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
                                    Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
                                    By the way, the ferrite core of L10 is broken,...
                                    02-16-2025, 04:15 PM
                                  • rewease
                                    Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                                    by rewease
                                    Hi everyone,
                                    There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                                    Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                                    Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                                    09-17-2023, 12:53 AM
