lg 32LC46 backlight inverter board fault
  • jimbofz
    • Apr 2013
    • 539
    • uk
    Hi this oldie had no backlight .after replacing caps on 24v rail ,
    still no b/l this uses inverter type:1315 B1-16A,
    im sure ive come across the same inverter in a samsung possibly le32r88bd ?
    all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
    this allows protect to be temporary overridden.
    b/l now comes on
    but the left hand side of pic is gradually darker than the right side
    i have the cct for the tv
    but it does not have inverter cct.
    i opened it up to inspect the ccfl tubes
    and they dont have any black marks at the end
    and the light produced is the same gradual light to dark,
    in the past ive had individual ccfl s fail
    but never had this shading effect
    i suspect something on the earthy end of the ccfl s ,
    possibly a component on the inverter board
    can anyone help with a cct
  • jimbofz
    • Apr 2013
    • 539
    • uk
    Re: lg 32LC46 backlight inverter board fault
    heres some pics
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Have you checked the underside of the inverter board for hot spots ie browning of the board.
      Is the PFC voltage measured as given in the manual?
      • jimbofz
        • Apr 2013
        • 539
        • uk
        yes the PCF is fine 380v
        ,and theres no sign of overheating on underside of pcb
        .on the earthy end of the ccfl,s theres 2 fine connections to inverter board,
        these go to diodes d15 ,d16 they check ok just wondered what they are for?
        any ideas
        • R_J
          • Jun 2012
          • 9633
          are the 4 fuses on the inverter board ok? Check the secondary resistance of each transformer winding and compare them to see if one ore more has a different reading, I thing they should be around 600~900Ω
          • jimbofz
            • Apr 2013
            • 539
            • uk
            all fuses ok and all tx windings measure same . which is good
            when prot override b/l on
            all tx run cool none are hotter than the others
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              It may be worth checking the electrolytic capacitors around the OZ964 for increased ESR or capacitance value.
              • jimbofz
                • Apr 2013
                • 539
                • uk
                thanks ,there fine on my esr meter and cap meter
                • lotas
                  • Jan 2016
                  • 4935
                  • Russia
                  Inverter circuit.
                  • jimbofz
                    • Apr 2013
                    • 539
                    • uk
                    Originally posted by lotas
                    Inverter circuit.
                    many thanks Lotas
                    • jimbofz
                      • Apr 2013
                      • 539
                      • uk
                      the voltage shown on cct for return end of ccfl,s is 1.8v this is only .2v
                      the 5v supplied via q2 is ok at 4,9v
                      pin 14 of u2 should be 4.4v its 3.7v
                      this goes to u3 pin 14 shown as dim
                      this is fed via 100k r50 which measures fine
                      any ideas please
                      • Biruslapio
                        • Nov 2013
                        • 552
                        • Brasil
                        Are the voltages across the fuses the same?
                        I undestood that there's a gradient effect in the CCFLs, from top to bottom or the opposite, is that it?
                        • jimbofz
                          • Apr 2013
                          • 539
                          • uk
                          all fuses 24v supply fine pic dark on left then gradual increase to perfect pic on right
                          • Biruslapio
                            • Nov 2013
                            • 552
                            • Brasil
                            is the LCD darker or the lamps themselves? If the lamps + polarization sheets are ok then it's a t-con or panel problem.
                            • jimbofz
                              • Apr 2013
                              • 539
                              • uk
                              thanks
                              i see where you are going with this
                              but i cant get inverter to start without overriding the protection, as posted earlier.this is why i was focusing on the inverter board
                              when i opened it up to examine ccfl,s they looked fine just darker at left side than the right ,
                              i did expect to see one that was out ,
                              causing prot to cut out b/l but no they were fine
                              i also checked the foils to see if they were causing the shading
                              but they all looked fine when i gently flexed them
                              if fault was t con or panel ,i dont think it would kill the b/l
                              would you agree?
                              its a head scratcher
                              • Biruslapio
                                • Nov 2013
                                • 552
                                • Brasil
                                Post a picture of the issue.
                                Are these lamps U shaped or do they end up fitting into at a long vertical metal on the opposite side of the chassi? If they are darker might be too low voltage, or bad connection in one of the sides.
                                • jimbofz
                                  • Apr 2013
                                  • 539
                                  • uk
                                  yes i suspect low voltage.
                                  the ccfl,s are not u shaped
                                  all connections to each end of them were checked
                                  the "earthy" end should have return voltage on cct shown as AA 1,8v
                                  but its only .2v
                                  here are some pics
                                  i dont understand why pics are upside down ,i check their orientation before upload and they are correct ?
                                  • jimbofz
                                    • Apr 2013
                                    • 539
                                    • uk
                                    i will try again
                                    spin them then upload again
                                    nope that didnt work im confused?
                                    • Biruslapio
                                      • Nov 2013
                                      • 552
                                      • Brasil
                                      That's probably the forum's auto resizer.
                                      So you must have an inverter fault, there is no way all the lamps aged uniformly and got darker on one side.
                                      What's the voltage on ERROR, ON/OFF, I-PWM and E-PWM?
                                      One of these PWM voltages controls the lamp brightness, if this is the same as other old LG LCDs, 3.3V should be maximum brightness, and less than 0.8V it doesn't even turn on.
                                      These wires that you used for bypassing the error pin, they're too long, try using the least amount of wire you can, if nothing changes, I suggest replacing the inverter board, it's cheap at least.
                                      • lotas
                                        • Jan 2016
                                        • 4935
                                        • Russia
                                        This inverter suffers from poor soldering of smd components (resistors, capacitors ...) try to solder the whole board well.
                                        • ttmi100x
                                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                          by ttmi100x
                                          Greetings everyone,
                                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                          Upon closer inspection...
                                          07-31-2024, 06:36 PM
                                        • Rictech
                                          Panasonic SA-MAX770PU SMPSU board fault....
                                          by Rictech
                                          Hello everyone. 😀
                                          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                          There are no devices that have exploded or otherwise show signs...
                                          08-26-2024, 01:05 AM
                                        • spleenharvester
                                          Tower T548006 battery, fault on BMS board
                                          by spleenharvester
                                          I have two of these spotwash machines. They are portable systems that use a 12V power tool battery consisting of three 18650 cells. One of the batteries recently failed. 12V appears at the terminals but there appears to be a fault condition - machine flashes LEDs when you attempt to power up. When you plug in the battery directly (the machine charges through a USB-C port, but there is a second USB-C port on the battery itself for some reason that can also be used for charging), the green LED lights and a dim red LED lights next to it solid. By comparison, a working battery will flash green only....
                                          10-04-2025, 06:33 AM
                                        • tony359
                                          2007 Macbook logic board fault
                                          by tony359
                                          Good day all,
                                          I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
                                          Once the fan was swapped, I installed an OS and it worked fine.
                                          The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
                                          Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
                                          If I see that right, I have missed VCORE on L7100 (page 59)....
                                          01-23-2025, 06:59 AM
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
