EXC3188-FG31 Touch Controller Eegalaxy
  • Richi_el
    • Nov 2013
    • 95
    • Koln
    i have a question. I have a fault by a device were the touch controller is faulty.
    So i orderd the Controller EXC3188-FG31 and mounted it on the PCB and the device is starting (without the contoller it does not start) but the positioning of the fingerprint is not correct on some points i have the correct position but und the downside of the touch i get no reaction.
    i think the contoller is well mounted on pcb and dont have any contac error, but i had the same issue on 2 devices.
    Note : there is no possibility to make a touch screen calibrating, my infomartion is that a calibration is not needed by this models.
    Is it possible that EXC3188-FG31 are also in different types...
    I uploaded a picture of the original IC and of the spare part wich i orderd....
    Can somebody tell me on the second pic (yellow marked codes) are also important or not?
    • 21889
    Re: EXC3188-FG31 Touch Controller Eegalaxy
    The replacement part looks like its printed rather than etched,it could be a fake
      • 31248
      you always need to calibrate touchscreens.
      on large screens you may have an eeprom on the cable itself,
      but usually it's in the software - your problem is going to be finding out if the calibration software is hidden inside the unit or external.
      also - clean all the flux off - specially under the chip between the balls.
      • Richi_el
        • Nov 2013
        • 95
        • Koln
        thanks for reply.
        the flux issue can be right, i will check this tommorow
        Its a 18,5" Screen (widescreen) mounted to the controller.
        I had some cases with the old version of that controller type EX5440-CG11
        (not balled IC,same devices) but by this type also it was not need to recalibrate the touch.
        Note: i orderd the EXC3188-FG31 by same supplier were i also bought the EX5440-CG11 and they was perfectly working.
        But the flux theory is a really possible thing, i will try tommorow and repost result
        • Richi_el
          • Nov 2013
          • 95
          • Koln
          i have some updates in this case:
          I got a mail from the service of eeti and they told me :
          EXC3188 is a PCAP (Projective Capacitive) touch control IC, it can only works properly with corresponding firmware.
          For different project, it needs individual firmware, not be able to mix between projects, also there is NO common firmware for PCAP touch IC.
          So, unless you have the original corresponding firmware with the device you are trying to fix, or it will not work correctly anyway.We are not be able to help you on this, you need to contact to the original supplier of those devices.
          The firmware is written into the IC. The datasheet can only to be provided with valid NDA.
          So i asked them for reflash/write the EXC3188-FG31 with the original file readed/downloaded from a working device.
          I am not sure if the IC can be re-flashed with the way you mentioned, or it will cause any damage.Normally our customers can only use software tool which was attached within the firmware package after the IC connects to the Host.
          My question now is:
          Is it possible to download/ read out the data from a working device and wich software and cable i need for this?
          I uploaded the picture of the connector board wich is wired by usb to the pcb of the device. On that board i can see some connection points wich can be usefull but i never programmed a IC like this before.
          I programmed EMMC and ..... but i dont have any idea how i can read out this ic and write back......
          Thanks for help
          • lotas
            • Jan 2016
            • 4786
            • Russia
            Instructions
            • Richi_el
              • Nov 2013
              • 95
              • Koln
              thanks for reply.
              But this User manual is for directly connect the controller board to the PC via usb?? right ?? afterwardsu can calibrate it by that sofwarte in user manual ??right ?. But on the devices i dont have a windows installed, it works by andorid and the parameters are saved in the IC as eeti told me.
              is there no method to read the chip and flash/copy it ?
              • lotas
                • Jan 2016
                • 4786
                • Russia
                Look here
                https://www.eeti.com/documentation.html
                • trepachka
                  Converting HP EliteBook 840 G7 non-touch to touch if possible
                  by trepachka
                  I am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
                  The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
                  I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
                  04-27-2024, 11:15 PM
                • jtomes123
                  Any info on PWB-C847 touch controller board (Dell 5289)?
                  by jtomes123
                  Hey guys, i’ve bought a screen from Dell 7280 with a usb touch controller, but I have received one from Dell 5289. This one uses the Wacom PWB-C847 (pic below) , I am looking to gather as much info as possible before I start poking at it.
                  What I found so far is that it uses I2C-HID and USB for communication and those should be available through the testpoints on the board.
                  Goal is to get the screen working with my Framework 13 motherboard through eDP (that part is relatively easy). And get touch and pen support, in order to build a nice and powerful tablet.
                  03-01-2024, 03:23 AM
                • Prott
                  Surface Pro 4/5 - no touch after LCD change
                  by Prott
                  I have a question that's driving me a bit nuts recently.
                  Is the touch board on Surface Pro 4/5 somehow married to the motherboard? I have a few Surfaces that, after the touch board change, lost all touch functionality.
                  - I tried flashing the bios (simple ME clean from a known good bios, previous bios didn't have an intergrated hub enabled), reinstalling firmware, reinstalling windows and even new touch boards.
                  - In one instance, after I tried to troubleshoot by using a known good screen + touch pcb combo on a Surface that lost touch, the touch board...
                  01-25-2023, 12:42 PM
                • master3112
                  ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                  by master3112
                  I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                  When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                  10-29-2024, 09:32 PM
                  ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook Specification for Upgrade or Repair
                  This specification for the ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To boardview and 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard...
                  09-07-2024, 02:50 AM
