Telefunken D43F287N4CWII - Vestel 17MB110S - Recovery Firmware
  • Tommes
    • Jan 2022
    • 7
    Hey Folks,
    I'm searching for a Full Flash Recovery Software
    for my Telefunken D43F287N4CWII
    Mainboard Vestel 17MB110S
    Panel: VES430UNDB-2D-N12
    Productcode: 10119394
    Does anyone know, where I can get it ?
    Or is it possible, to extract it from a working mainboard ?
    The Support Telefunken/Vestel GER couldn't help me.
    The Vestel TR Support didn't answer my email.
    History:
    The main problem with my Telefunken D43F287N4CWII was,
    it just goes out after a while, sometimes after a few minutes,
    sometimes after a few hours.
    Then I've swapped the mainboard for an identical model, all numbers
    on the exchange board are identical. At first, the new mainboard
    worked, but the colors weren't okay and neither the gamma values.
    Apparently the panel data in the new mainboard doesn't match
    my existing panel. Then, after a few "boot" processes, suddenly
    the new mainboard no longer started, only the red LED flashes.
    Then dismantled the old mainboard for a cross-check, it boots up
    correctly. Presumably the new mainboard now has to be completely
    reflashed with a recovery full flash software including the correctly
    panel software file
    Thk you vry much
  • Tommes
    • Jan 2022
    • 7
    Re: Telefunken D43F287N4CWII - Vestel 17MB110S - Recovery Firmware
    Oh, is there no recovery firmware available für the Vestel 110S ?
    For the 110 and 110P i could find a '4-files-recovery' archive
    • Diah
      • Feb 2013
      • 6615
      yours old one work.. so dump the eeprom of it ( round 2.5mb ) and flash it on the stop working one.. if my memory correct it should IC U81
      cheap programmer CH341 can do the job.
      • Tommes
        • Jan 2022
        • 7
        I did it some days ago, I cloned the SPI with CH341 & the Clip.
        Writing worked well, but it didn't help, the board still didn't work.
        I think, the TSOP48 Flash should be cloned/flashed, but I think
        there is not Clip for TSOP48 to flash it.
        I think. it must be unsoldered for flashing oder with some luck
        with the recovery files and these files are my hope
        • arizanotlari
          • Nov 2014
          • 158
          • Turkiye
          Hi.
          Try these files ; https://disk.yandex.com.tr/d/1R-5fZtgh2fX6Q
          https://disk.yandex.com.tr/d/d3fnc5ghGrbx3A
          https://www.badcaps.net
          • Tommes
            • Jan 2022
            • 7
            Thank you very much for your files
            I've tried to flash them.
            The TV didn't flash the files
            Press & hold OK -> Plug Power Cable in -> Power LED lights up 8x and USB Stick LED lights on too ...
            Then the Power LED lights on permanently, the USB Stick LED light off
            Not flashed
            I think the mainboard is still not recoverable
            (2 USB Sticks (FAT32), both USB Ports, both file archives tested)
            • lotas
              • Jan 2016
              • 4924
              • Russia
              Not all USB sticks will work, try old sticks up to 2Gb.
              • Tommes
                • Jan 2022
                • 7
                The usb stick are 2GB and 8GB
                I mean, i took one of them for core update on an other Vestel Telefunken TV
                But I'll try it with another one
                • Tommes
                  • Jan 2022
                  • 7
                  Thank you very much for your help all.
                  It has worked now
                  The problem was, I swapped 2 Telefunken remote controls and
                  the OK button on the other remote did not appear to be the correct signal
                  It has flashed it, but the TV goes on briefly and then goes off again.
                  I just connected it to a damaged panel for testing,
                  I will test again on a healthy panel and see what it shows.
                  Maybe the board is lost for ever
                  • arizanotlari
                    • Nov 2014
                    • 158
                    • Turkiye
                    don't plug lvds cable. mb must be working without panel. if mb goes standby again firmware not fit to tv.
                    send me a pm for more firmware.
                    • the_thug
                      • Feb 2016
                      • 2
                      • Bulagaria
                      Hello and sorry for the wrong topick, but i am trying to reach your website, and it shows error that it is unreachable. I have tried multiple devices and computers and even vpn but no good. Again i am very sorry, i know that this is not the place to ask, but i dot know where to find you.
                      • arizanotlari
                        • Nov 2014
                        • 158
                        • Turkiye
                        Hi, thanks for asking.
                        I closed site due to low traffic (daily 500 visitor).
                        Plus the selfishness of my colleagues began to piss me off.
                        Anyone can contact me here, electroda.pl and ****************
                        • the_thug
                          • Feb 2016
                          • 2
                          • Bulagaria
                          Thank you ! I will know where to find you now.
                          • ducky29
                            • Dec 2015
                            • 369
                            • Europe
                            What about the old tips and links for firmwares that you had on the site? Is there any way we can get them back?
                            • arizanotlari
                              • Nov 2014
                              • 158
                              • Turkiye
                              Of course, I will continue to share the files, but I will keep the tips to myself for now
                              • ducky29
                                • Dec 2015
                                • 369
                                • Europe
                                I don't know why I had a feeling that this day would come. Too bad I didnt download your website
                                • cheeky2
                                  • Dec 2012
                                  • 339
                                  • uk
                                  I must also say arizanotlari thank you for providing the files you have in the past it has been a great help in getting old TV's back to life and saving them from the landfill It is appreciated and I have learnt a lot from reading and browsing your website.
                                  Take care Regards Anthony
                                  • FlailingEngineer
                                    Help with Bush Tv (Vestel 17mb95m Mainboard)
                                    by FlailingEngineer
                                    Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                    Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                    05-31-2023, 06:52 AM
                                  • porfyriadhs
                                    Vestel 17mb230 mainboard.No Sound
                                    by porfyriadhs
                                    Hello to everyone . I have a vestel mainboard 17mb230 with no sound on the speakers only on the headphones . I think that hotel mode is on but I cant find a way to fix .. Any help will be good thanks
                                    03-19-2024, 01:12 AM
                                  • Unimatrix
                                    (Vestel) Telefunken XF43G511 - Thermal problem
                                    by Unimatrix
                                    I came across this forum because I need some advice about my Telefunken XF43G511 TV. It is originally a Vestel device. For some time now I have had the problem that the TV gets a black screen when the electronics are heated up. The backlight is still there and the sound still works. It's just the screen itself that goes off. When I switch off the TV and it cools down, the TV works again after a while. Could you please give me some advice on what could be causing this problem? I have also attached some photos of the electronics.
                                    Kind regards
                                    Thomas...
                                    11-19-2023, 08:39 AM
                                  • classypenguin
                                    TV Telefunken (Vestel) D50U660R2CW - on the tv screen but every 3-4 seconds lines appear on the screen flickering
                                    by classypenguin
                                    Hey, I got an Telefunken 4K D50U TV in for repair. Since the problem is t-con flex related, I isolated the problem to one side (right flex of the t-con). I taped the flex a bit, but i couldnt get any further. I attached the pictures of the t-con board in zoom in perspective. I would appreciate help for this TV. Please note that I came from Germany, so it is a bit difficult with the time zones. Greeting Tobi...
                                    08-29-2024, 03:47 PM
                                  • KevinWysocki
                                    Aya A39FHD3901/2 - Vestel 17MB82 mainboard - LED blinking
                                    by KevinWysocki
                                    Hi there,
                                    My mother in law gave me an Aya TV, to take a look if I could do something to repair it.
                                    At startup, LED constantly blinks and no image is shown (even if I light the screen, broken backlight is not the problem), also +12V power rail is fine.
                                    After some research, it seems that NOR flash often fails on this mainboard, I have found the procedure to force flash upgrading with a USB key connected to mainboard USB port, pressing "OK" button on the remote and plugging the TV power cord.
                                    Flash upgrade didn't seem to work,...
                                    08-20-2023, 09:45 AM
