Bernina control board
  • snoptel
    • Dec 2021
    • 49
    Hi everyone.
    I have a strange one here.
    The PCB in the picture is from a Bernina Artista 200 embroidery machine that was given to me.
    Plugged it in and nothing happened. Opened it up and found remains of water and a blown capacitor, (Circled in the picture).
    Replaced the cap and the screen back light came on and the screen as well, but nothing happened afterwards. Turned it off and then back on and it´s back to being dead.
    All four voltages are present, indicated by the four LED´s on the top of the board.
    The IC that's circled get extremely hot, which leads me to believe there´s a short somewhere.
    I´ve cleaned the board with alcohol as there were some areas that had water stains. I don´t see any shorts on the IC pins anywhere.
    On of the caps looks slightly bulged compared to the others, I may end up replacing it.
    Of course, no schematics online.
    Any help/ideas are greatly appreciated.
    • 31316
    Re: Bernina control board
    thats just i/o
    where's the computer? is it plugged into those strip connectors?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8354
      What are the 4 voltages? The LC14A is a Hex Schmitt Trigger inverter. If you look up the datasheet, it should be on a 3.3V rail. Check pin 14 for voltage. I know what these embroidery machines cost, those aren't cheap. I'd replace that hot IC and see what happens. For shits and giggles, remove that hot LC14A IC (either with a hot air station, or carefully cut the legs, take the casting out, then remove the leftover legs with solder and solder paste. Clean it and turn it on without that IC. See what happens...
      I wonder if the bad IC sucking the 3.3 rail down for other chips to work.
      • snoptel
        • Dec 2021
        • 49
        Originally posted by stj
        thats just i/o
        Yes Sir..
        The pc is on the back side of this board where you see those two strips.
        I removed it when I cleaned the board.
        • snoptel
          • Dec 2021
          • 49
          The voltages are 3.3v, 5v, 12v and 33v.
          When powered up, the LEDs light up indicating the voltages are present.
          I will check the voltage on pin 4 later today. As for removing the IC, if I have a spare moment tomorrow I'll tackle it
          Thanks for the help.
            master hoarder
            • May 2008
            • 12176
            • Bulgaria
            Don't trust the LEDs - they could be just tied to each of those rails with a resistor and could be lighting up even when the rails are too low. Take a multimeter instead and measure the voltage on each rail to confirm it is what it should be (give or take 5%, usually... and maybe 10% for the 33V rail.)
            Concur.
            Though a safer way to remove the IC without possibility of damaging the board by cutting the legs (at least to me, this seems a bit dangerous, but perhaps it depends on the person doing the task too) is to "flood" all of the pins on both sides with leaded solder and repeatedly heat up each side while applying very gentle lifting pressure on the IC. Once the IC gets a little off the board, you can continue the heat & lift method in bigger steps until the IC is off.
            ... or if you have TWO soldering irons, apply leaded solder on all of the pins on both sides of the IC and heat up the IC on both sides with the two irons simultaneously, then slide the IC off the board when the solder melts. I usually use this 2nd method. In fact, I'm often able to do it with a single iron, provided the IC is small enough that I can take a really big blob of solder and melt it over both sides of the IC simultaneously (hint: a big, fat, spoon or chisel or bevel -shaped tip on your iron is recommended for this.)
            • snoptel
              • Dec 2021
              • 49
              Hi guys, I apologize for the tardy reply, but I´ve been super busy plus my hot air station isn´t working - Murphy's law.
              I checked the voltages, I´m getting what's expected, 5.05vdc, 37vdc and 12,5vdc.
              I can isolate the 12vdc rail from the 5/33vdc rail via a two plugs. The aforementioned IC heats up when the 5/33vdc rail is on.
              I hope to use a friends hot air station tomorrow, hopefully removing the IC clears the short..
              One more questions, I did some probing around checking the capacitors, and there are a lot that are grounded on both sides. I know that checking components in place isn´t always the best way to go, but has anyone ever come across this before?
              Thanks.
                master hoarder
                • May 2008
                • 12176
                • Bulgaria
                Yes.
                If the capacitors in question are all in parallel, it really only takes one to be shorted for the whole lot to appear like they are shorted. Generally, this happens with ceramic capacitors more than any other kind, and typically when there are multiple of them filtering a power rail. However, it could also be a faulty IC (the one that overheats?) that has a short to ground, especially if that short-circuit is on its input power rail - in such case, any capacitors attached to that power rail will appear as shorted but may not be.
                That said, try measuring the resistance to ground on both side of the caps rather than using continuity (beep) function. Do both sides of the capacitors that appear shorted show the same exact very low resistance? (i.e. same as when multimeter probes are shorted together.) One side should clearly show a short-circuit to ground, as that would be an actual ground. The other may or may not. If not, then that's likely a power rail.
                In any case, looks like you may just have to remove the IC either way.
                Again, if you don't have hot air but do have (or can get) two soldering irons, that will work fine too. Any cheap 25-35W iron will probably do the job as the second iron. So that gives you an option if you can't get ahold of a hot air station.
                • snoptel
                  • Dec 2021
                  • 49
                  Update..no joy.
                  I removed hot IC, no change. (Plus I think I lifted a track :S)
                  As I wrote in the initial post, the cap circled in blue looked somewhat bulged, so I removed it..no change.
                  kind of bummed out. Any suggestions?
                  The other ceramic caps are still grounded on both sides. The short is somewhere else.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8354
                    Either you need something like a LeakSeeker 89 or inject power with a lab grade CC CV power supply and see what is getting hot now.
                    • snoptel
                      • Dec 2021
                      • 49
                      Hmm, a LeakSeek would be nice..they´re hard to find now a days.
                      Have to see If I can get a hold of a lab PS.
                      • snoptel
                        • Dec 2021
                        • 49
                        I´ve traced the 5v rail to in red. Goes to a component that I can´t seem to make out the number - 3Bs something. Not sure if it´s a voltage regulator or something.
                        I was thinking of removing the cap at the beginning of the 5v rail and checking the other if shorted, and going from there working my way forward..
                        Also, I noticed that the regulator circled in blue was quite hot, removed it but that just cut the 33vdc and didn´t solve anything. (This was just for some piece of mind.)
                        I left the board powered on for 5 mins and felt around.. the IC circled in yellow get quite warm, the others don´t.. model is: AHC16244
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8354
                          I could have been that transistor, since the voltage IS present. You are looking for missing voltages to identify where your problem is. The injecting power trick only works if something is shorted to ground.
                          • snoptel
                            • Dec 2021
                            • 49
                            I´m assuming your talking about the transistor at the end of the red 5v rail??
                            I may have one on some salvage PCB´s.
                            I´ll take a look and if so, swap it and hope the stars align.
                              master hoarder
                              • May 2008
                              • 12176
                              • Bulgaria
                              Even if the transistor is bad (or not), I still think the caps that show short-circuit on both sides are the ones to worry more about.
                              I don't have a LeakSeeker either, nor a good enough lab power supply... so my usual plan of attack for such boards is to keep removing components until I get to the shorted one. In the case of the shorted caps, if they are ceramic or tantalum, start removing them one by one and test each out of the board. If good, and the resistance across the other ones still shows shorted, keep removing them one by one. You can also solder them back in once each one is checked and showing OK. May seem like more work, but at least for me, removing and putting back those small caps is usually easier than removing whole ICs or looking for replacement transistors.
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8354
                                My last post should have read “couldn’t be the transistor”. I guess my iPads spell checker messed around. If you don’t have any of these devices, you have to do what momaka said. You also can break things in sections by cutting the shorted trace in specific sections. Then measure which section is still shorted to ground. That should could down the area you need to look at.
                                • kaboom
                                  "Oh, Grouchy!"
                                  • Jan 2011
                                  • 2507
                                  Re the CC/CV power supply to heat up "shorted" components:
                                  If they're well & truly shorted, they'll drop little voltage, even with a few amps through them. So you won't always find them this way.
                                  Had a shorted SM MLCC a few months ago in something unrelated.
                                  There were multiple in parallel- had to pull & measure each to find the shorted one.
                                  Backfeeding with a current-limited PS did NOT help here.
                                  "pokemon go... to hell!"
                                  EOL it...
                                  All style and no substance.
                                  guilty,guilty,guilty,guilty!
                                  guilty of being cheap-made!
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                  • m1ch43lzm
                                    by m1ch43lzm
                                    05-12-2025, 08:37 PM
                                  • Yanleb
                                    LG 60PK550 Logic Control Board EBR63450301
                                    by Yanleb
                                    Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                    C57: 3.30V
                                    C61:...
                                    07-20-2023, 12:38 AM
                                  • howardc64
                                    by howardc64
                                    07-24-2025, 05:17 PM
                                    Linear Garage Door Opener Control board took a crap install a new control board back normal
                                    by sam_sam_sam
                                    I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
                                    02-08-2025, 06:52 AM
