Replacement cap for Samyoung NXB
  • CowboyFrank67
    • Jan 2022
    • 3
    Hey all, I am looking for a replacement cap for some Samyoung NXB 16v 1000uF 105°C caps from my LG monitor. I am new at this (my first cap replacement) and have no idea where to look for the right one. I have made 2 orders on ebay and received the wrong one both times. When I Google it I never get the exact thing back.
    So my question is...What should I be ordering? I am finding a bunch of different caps with the 1000uF and 105C and 16v, but none of them are listed as NXB. I found VEHT, which is what my last order came in as (and they are about half the size of the NXB in thickness.
    I have very little knowledge here so I came looking for help.
    • 30979
    Re: Replacement cap for Samyoung NXB
    https://cdn.badcaps-static.com/pdfs/...6711d201c1.pdf
    use panasonic FR series
      master hoarder
      • May 2008
      • 12170
      • Bulgaria
      Any of these cap brands and series should work for the NXB series:
      Manufacturer.......................................Series
      Nichicon ................................ PA, HE, HD, HV, HW (PW may work too, if space allows)
      Panasonic .............................. FR, FM, FS (and FC is space allows)
      United Chemicon (UCC) ............ KY, KYB, KZE, KZH, KZM (and LXV & LXY if space allows)
      Rubycon ................................ YXG, YXH, ZLJ, ZLS, ZLQ, ZLH, ZL
      Since you're in the USA, I recommend getting your caps from Digikey, Mouser, badcaps.net store... or just some reputable place that won't sell you counterfeits of the above brands and series. eBay actually has some good sellers on there too that sell genuine Japanese caps... but you'll just have to be very careful where/who you buy from on there. Generally speaking, US sellers that sell only electronic components (and caps in particular) are more likely to carry genuine parts. Avoid the China/HK/Taiwan sellers - very likely you may get a counterfeit part.
      • CowboyFrank67
        • Jan 2022
        • 3
        Thanks for the info @stj and @momaka. I will look and see what i can find. Not a pressing issue but i thought i would fix what i have before having to go out and buy a new monitor. I must be crazy right?
        • PeteS in CA
          • Aug 2005
          • 3579
          • USA, Unsure of Planet
          Also UCC LXZ series, which is less old than LXV and LXY. LXZ and Nichicon PW series are pretty much direct equivalents.
          Nichicon's PA series is less well known but is very good, very similar in impedance and ripple current to the HE series.
          PeteS in CA
          • Behemot
            • 4845
            • CZ
            forgot NCC KYA and KZN
            • pc7fan
              • Aug 2013
              • 52
              AVOID Panny FCs. They sometimes leak from the negative terminal and will damage/corrode the traces if not caught quickly.
                • Jul 2011
                • 6033
                No your are not crazy but I wish that more people would look at this way
                I will at least try to fix something once and if in a short time fails again I might think twice if I am going to fix it again
                Here is a case in point
                I have a TV set that was almost a couple of years use it would not turn off unless you pulled the power cord but it was still under warranty so I had the repair service technician come and look at and determine that it was a bad power button switching assembly that controlled other functions so just the power switch wires were disconnected but could still use the remote to turn it on and off and because the part was no longer available they refunded the money that I paid for the TV set well this work for about a year and it started doing the same thing again not turning off even with the remote so I recap all of the boards except for the main filtering capacitor and this TV set work for another couple of years ( the switch that was disconnected I reconnected it and it was working go figure) I was using it for a monitor for my computer then the VGA input started not always work correctly then it went out completely then I used the HDMI input for about another year and then it started not always working correctly then it would randomly turn off by itself self now it is headed to the recycling center because I am done with it and bought a new monitor ( but I might be crazy for doing this repair or doing the work arounds to keep it working so who knows )
                  master hoarder
                  • May 2008
                  • 12170
                  • Bulgaria
                  Same here.
                  And sometimes I will fix it, just to prove a point (that I am stubborn too. )
                  Great story about the TV set you fixed, btw! It honestly sounds like you already gave it much longer life than it could ever have from the factory and it did its job serving you well enough.
                  On a similar note, my sister has a small Samsung TV in her kitchen that stopped turning On/Off some years back. I took a quick look at it while vising her and just found that it was the front "touch" button board on the TV that was preventing it from turning On. Once I disconnected that (but left the IR receiver connected), this got the TV working again, but only with the remote (which is OK, since my sister said she never used the front buttons anyways.) This was 4 or 5 years ago and the TV is still working with this "fix".
                  Crazy? No. I'd say more like curious individuals who like to solve technical problems. But to the rest of the "normal" world, we do probably appear crazy. Not that I care about that anymore, though.
                  • Behemot
                    • 4845
                    • CZ
                    I'd say that some of those touchbuttons are notioriously unreliable.
                    And it does not end, they continue to add more funky features (like, latest TV models detect remote position so just by waving it acts like mouse cursor), which could be very bad combined with removal of old features (like, if they removed the usual way of scrolling through menus etc.) and these funky things getting bad.
                      master hoarder
                      • May 2008
                      • 12170
                      • Bulgaria
                      There are TVs like that already. In fact, I think this trend started a little over 4 years ago. First I saw it was with an LG TV that had only like 7 buttons on it's remote: On/Off, Volume Up/Down, Channel Up/Down, OK/Enter, and Back/Return/Menu... if I remember correctly. That's it! If you wanted to do anything else, it was all gestures and crap. Back then, I was working in a big electronics store, and basically I was the guy that would refurbish and repackage any returned TV sets. Resetting one of these de-nutted remote TVs was always a PITA. I think Samsung also started coming out with the same crap around the same time. But at least with Samsung, I could grab an older model's proper remote with actual full set of buttons and do the reset (or whatever else) in just a few moments vs. taking 5 minutes to try to navigate with the silly buggy cursor. Using those cursor remotes is like watching a really drunk guy (or gal) try to put his key in the key lock of his door to unlock it - basically just keeps missing... and that's what those cursor remotes feel like too, lol.
                      Oh, and worst of all, it's always the "high-end" models that have these remotes. The "lower-tier" TVs have (had?) normal remotes. Same with cheaper TV brands... which I noticed is what people are starting to buy a lot more lately.
                      • omon
                        Please help find a replacement for Rubycon A0817 6.3V 1000uF 105C MBZ
                        by omon
                        I was hoping to get some help in identifying a replacement capacitor for a PET Rubycon A0817 6.3V 1000uF rated for 105C temp, MBZ series.
                        This is to replace one bad capacitor on a DELL 530 motherboard DG33M03 (manufactured by Foxconn, DELL part # FM586).
                        I'm attaching the pictures of the bad cap.
                        Thank you so much!...
                        04-28-2021, 05:43 AM
                      • the_rem
                        Unknown transformer : how to find a good replacement part ?
                        by the_rem
                        Hello guys,
                        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                        04-23-2025, 01:48 AM
                      • ezenia
                        PS4 controller left stick potentiometer replacement issue
                        by ezenia
                        Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                        So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                        I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                        09-30-2023, 02:19 PM
                      • boosti45
                        Macbook pro logic board replacement parts quesion
                        by boosti45
                        i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                        08-21-2024, 05:23 AM
                      • r2digital
                        klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                        by r2digital
                        I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                        04-18-2024, 03:50 PM
