LCD tv power supply transformer magnets broke off
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Hi
    I have a typical lcd tv poeer supply
    I dropped the board snd the magnets on the dc transformer broke off
    Is the board no good now?
    What is purpose of the magnets mounted on both sides of transformer
  • R_J
    • Jun 2012
    • 9608
    Re: LCD tv power supply transformer magnets broke off
    There are no "magnets" on a transformer, I think you are referring to the transformers ferrite core. Why not post a picture?
    • shelby5041
      • Feb 2009
      • 1505
      Cant tske a pic
      Here is stock photo
      Pieces in yellow broke off
      Will ps not operate now?
      • R_J
        • Jun 2012
        • 9608
        The power supply will likely still operate, but the transformer will not operate efficiently as the core is broken and its drive circuit will likely fail when the supply is under load.
        • shelby5041
          • Feb 2009
          • 1505
          Is there anything i can do with the broken pieces to fix it or no
          I guess ill put it back in tv and see what happens.
          • R_J
            • Jun 2012
            • 9608
            You can try fitting the pieces back but they would not be magnetically conductive like when they were originally. If used like that I suspect the transformer could run hot as well. It would be best to replace it if you can find one from another board, maybe one that the board is beyond economical repair but the transformer is good.
            • shelby5041
              • Feb 2009
              • 1505
              thank you
              this is not worth repairing as it is just a tv i found in trash
              i dont put money into tvs anynmore..not worth it
              lcd tvs are worthless nowadays
              ill just glue it together and see if tv powers on..if it does ill just leave it as is
              if it no power on ill just toss tv in trash
              • shelby5041
                • Feb 2009
                • 1505
                hi JR
                i glued the ferrite back in place as best i czn with super glue
                i did test the ps outside of tv i do get 5v standby so i assume tv ps will porb work but as you said for how long
                i really dont care for how long since the tv is just a project tv..i dont use it
                so tomorrow i will install it in the tv and see what happens
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Keep us posted what happens.
                  The glued core should work, so long as you didn't increase the gaps too much.
                  If it works, also put some silicone glue to hold the core together. Superglue does not deal that well with heat-cycling and may eventually crack. So to prevent the core from cracking, silicone glue is recommended to hold everything as a "backup".
                  • shelby5041
                    • Feb 2009
                    • 1505
                    Hi...i did superglue it and tv powered on fine as i expected
                    The unknown is how will it affect long term use...i dont usecthectv so ill never know
                    When you say silicone what area are you referring to?
                    Can i just incase the entire ferrite perimeter in silicone? And is it just 100% pure siliccone caulking or a silicone based heat resistant glue?
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Awesome, good to hear you got it working!
                      Well, RTV / heat-resistant silicone would be better, but it's not necessary.
                      I've used regular cheap silicone caulking (they type used in bathrooms) with pretty good results so far. Only thing to watch out for is to make sure to get one that is low VOC / low odor. As silicone cures, it may release acetic acid, which can sometimes corrode electrical contacts and metals. The low VOC / low odor stuff, IIRC, releases a little less of that so it's overall safer for electronics.
                      I don't suggest encasing the entire transformer / ferrite with silicone, as that may reduce its cooling ability. But adding a good layer over the areas where the cracks were should work fine.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Look for it indicating neutral cure for a non acetic acid version.
                        • shelby5041
                          • Feb 2009
                          • 1505
                          Thanks for the good info but
                          Its just a cheap lcd tv
                          Ill just use 100% silicone caulking i have on hand..
                          If it was something expensive or something i was going to keep long term i would use more appropriate silicone but its just a typical modern day crappy made lcd tv so
                          Thank you
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                            by sam_sam_sam
                            07-01-2024, 06:34 AM
                          • JimBanville
                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                            by JimBanville
                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                            09-13-2023, 07:21 AM
                          • Andreas_de
                            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                            by Andreas_de
                            Hello!
                            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                            04-12-2025, 10:38 AM
                          • shamsudeen
                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                            by shamsudeen
                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                            07-19-2025, 07:14 AM
