Fluxes in Europe
  • DanFen
    • Apr 2017
    • 201
    • Malta
    Fluxes in Europe
    Simple question, cause it seems that all the flux related threads are from people in the US
    Where is everyone getting their fluxes from in the EU? Unfortunately my country is small and I can't find anyone, so the only option seems to be to buy online and get it shipped. The stores I found have ridiculous shipping costs.
    I've been using Mechanic stuff from China, however it's full of rosin and becomes a mess and a nightmare to clean.
    • 31131
    Re: Fluxes in Europe
    liquid? paste?
    flux to do what?
    • DanFen
      • Apr 2017
      • 201
      • Malta
      @stj, always to the rescue
      Paste flux for soldering. Not sure if I understood your question correctly.
      Originally posted by stj
      liquid? paste?
      flux to do what?
        • 31131
        so you want to put it ON things, not run it under large BGA's.
        then i use this:
        https://www.aliexpress.com/item/32864986454.html
        • caprider
          • Jan 2022
          • 24
          • Romania
          European provider for all things electronics: https://tme.eu/
          • DanFen
            • Apr 2017
            • 201
            • Malta
            Yes correct I don't have the right tools to fix BGAs.
            then i use this:
            • DanFen
              • Apr 2017
              • 201
              • Malta
              Thanks. I came across TME before, and it's good. It's however not worth shipping a buy a single tube from them... makes sense to order a couple of items then the shipping cost can be justified Although, the shipping doesn't seem to be high either (maybe I'm used to the super low shipping from China)
                • 31131
                TME wont ship to the u.k. anymore, and probably not malta either.
                fuckers.
                • ChaosLegionnaire
                  how do u use solid rosin flux?
                  by ChaosLegionnaire
                  i recently bought a block of solid rosin flux from aliexpress. i intend to use it for reflowing cold solder joints and cracked solder joints. but im not sure how im supposed to be using it? do i just break off bits and pieces of it with a knife and put the bits of solid rosin on the bad joint im soldering then bring on the iron?
                  i tried asking google and they pointed me to a headphone forum and eevblog? and they said to just dip the soldering iron tip into the solid block. a small piece of flux will be attached to the soldering iron tip end and im supposed to use that to reflow...
                  06-24-2020, 02:34 PM
                • chth96
                  Is it good to use chemistronic flux off es835b for flux remover?
                  by chth96
                  I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                  Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                  11-17-2023, 07:25 AM
                • evilkitty
                  Flux causing high resistance short?
                  by evilkitty
                  Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
                  Temp is on the left humidity is on the right
                  i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
                  The pin out looking down from the top is (note this is common cathode)...
                  07-17-2024, 09:38 AM
                  Multifix 425-01 and 450-01 Rework Flux Datasheet
                  REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                  - No Clean Formulations
                  - Low residue
                  - Range of activity to deal with different component solderability
                  - Halide free
                  - Suitable for dispensing
                  - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                  Both products are supplied in syringes or cartridges for application by dispensing....
                  10-07-2024, 06:02 AM
                • chth96
                  How can I remove flux with the smallest rubbing?
                  by chth96
                  I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
                  Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine​​
                  Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
                  Is there any way to remove flux with the smallest rubbing or without any rubbing?
                  Any reply would be appreciated.
                  11-24-2023, 05:22 PM
