Recommendations of quality soldering station and (separate) hot air station
  • caprider
    • Jan 2022
    • 24
    • Romania
    Hey,
    I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
    I now have a TS100 and some soldering irons and looking for some better tools.
    1. Soldering station, budget around 200-240€
    JBC BT-2BWA seems to be a good product in the budget.
    2. Hot air station, budget around 200€
    Up to now I've found ATTEN ST-862D to be a good option.
    What do you think about these products? Do you have some other recommendations in about the same budget, or lower budget if you think I get about the same quality.
    Thanks.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Recommendations of quality soldering station and (separate) hot air station
    I have the Atten, it's an awesome piece of kit.
    Have a a look at the PACE ADS200, there's a big thread over on eevblog about it
      • 30979
      get a JBC or a clone,
      you will save a fortune in tip cost compared to the pace crap.
      • diif
        • Feb 2014
        • 6978
        • England
        The price is around the same for the tips for the Pace or JBC.
        If the fake stations are like the one Northridgefix tried out the firmware is absolute garbage and the station was unusable.
          • 30979
          there are lots of JBC compatable stations now - some have great reviews.
          unlike a review i saw for the pace
          • caprider
            • Jan 2022
            • 24
            • Romania
            Why a knock off when you can get an original JBC at about the same price?
            • ZeuzzTN
              • Nov 2021
              • 7
              • TUNISIA
              I have a cheap ZD 8908 hot air station using it i found :
              It is good for small cms components that have exposed pads...
              It is really bad for chips and IC's especially in multi-layer PCBs
              • caprider
                • Jan 2022
                • 24
                • Romania
                What are “cms components”?
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Yes, I was looking at the i2c stations which seem garbage, the Aixun stations look good though, so good I bought the T3B. Half tempted to the the T3A also.
                  They are about a third of the price caprider.
                    • 30979
                    Aixun reviews
                    https://www.youtube.com/c/Sdgelectronics/videos
                    • Eddy the Mad
                      • Feb 2022
                      • 2
                      • Nederland
                      Im looking for an update on my KSGER T12 also, T3A T245 clone, Pace ADS200 or save up for the real deal? (JBC)
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        The T3B beats the KSGER on power and doesn't have an iffy power supply. I've also bought a T3A after being impressed with the T3B. Watch the review stj links.
                        • Eddy the Mad
                          • Feb 2022
                          • 2
                          • Nederland
                          Thanks, indeed looks half decent to me!
                          • itsaquestion
                            • May 2023
                            • 3
                            • China
                            Indeed AiXun T3B is first option for nano and precise components.
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8118
                              Aixun T3A for me. And I am very happy with mine.
                                • 30979
                                here is a question, can a T3a base run the smaller handle with micro-tips or is the cartridge voltage/sensor different?
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8118
                                  No you can't run a T12 cartridge in the T245 pen using the T3A base station. You need the T12 pen to run T12 cartridges. I've got one and it works fine.
                                    • 30979
                                    i didnt mean that,
                                    i meant can a T3A base run a JBC micro-pencil intended for a T3B ?
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8118
                                      AFAIK no. The plugs are different between the T3A and the T3B
                                        • 30979
                                        just the plugs?
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • chth96
                                          What soldering station should I purchase for 900M-TJ-I tip?
                                          by chth96
                                          hello.
                                          A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
                                          https://ko.aliexpress.com/item/4001275635593.html
                                          Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
                                          Any reply would be appreciated.
                                          11-24-2023, 05:08 PM
                                        • mkbehbeh
                                          KSGER C245 Soldering station PSU 220V only?
                                          by mkbehbeh
                                          I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
                                          I am...
                                          04-17-2023, 03:11 PM
                                        • Peter_1402
                                          Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                                          by Peter_1402
                                          Hi Everyone,
                                          I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                                          1. Soldering iron works great
                                          2. There is a burnt mark on the hot air gun handle.
                                          I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                                          Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                                          Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                                          Reed switch tested ok with a magnet.
                                          From the above test, I can conclude...
                                          07-12-2025, 11:50 AM
                                        • nbdy
                                          QUICKO soldering station
                                          by nbdy
                                          HI,
                                          Have a QUICKO soldering station with no numbers for the model ... (think it's a KSGER or similar copy)
                                          All worked nice, till some day it heats the iron till it was RED (HOT) ...
                                          Turned it off, and tryed today again, and all the same, even with a second iron ...
                                          The display shows that the iron is not connected, like not inserted in the handle ...
                                          The second thing is that it has 6 pins connector and can't find a handle that is similar for my station ...
                                          Has someone some advice what to do, where to look, even how to...
                                          01-07-2024, 05:44 PM
