Learning to repair monitor's PSU
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    Hello guys,
    I'm learning to repair monitors. I don't have much experience, but I managed to repair a few monitors by changing bad caps.
    However, I'd like to learn how the PSU is working since, most of the time, there is a fault on PSU board.
    Attached, there leis a picture of board PSU (Samsung SyncMaster), There is no problem on the board. I'd like to learn what some components is doing.
    First of all, there is a AC power input (230 VAC), and after input EMI filter, there is a bridge rectifier (1) and a big cap (2). On this cap (2), there is DC voltage about 300 V. Ehat is the purpose of MOSFET (3) and transformer (4). I know that from this rectified input voltage, lower part of the board with its components produce 5V and 12 V (this can be 14 or even 16V).
    I also know there is a high voltage transformer needed to supply backlight
    Ca you please tell me, what is the purpose of transformer (4) and element (5).
    I guess diodes (6) are used to rectify output from transformer (4) which is AC to DC voltage 12 V?
    What caps (7) are doing? DO they filter this rectified voltage?
    Thank you for your time.
    I'm looking forward to your explanations.
    master hoarder
    • May 2008
    • 12170
    • Bulgaria
    Re: Learning to repair monitor's PSU
    LCD monitor power supplies operate the same as any other Switch Mode Power Supply (SMPS.)
    Component (1) [bridge rectifier]: turns wall AC voltage to DC voltage
    Component (2) [capacitor]: stores DC charge from (1) above
    Component (3) [MOSFET (or other transistor)]: takes charge from capacitor in (2) above and pulses On and Off with high frequency, creating a high-frequency square wave AC voltage.
    Component (4) [transformer]: is fed the high-frequency square wave AC voltage from (3) above on its primary side. On its secondary side, the transformer produces high-frequency, but low voltage... again, square wave AC.
    Component (6) [output diodes / rectifier]: changes the low-voltage high-frequency AC voltage from the transformer (4) above and turns it into a "raw" DC voltage again (not smooth.)
    Component (7) [output filter capacitors]: take DC voltage from the output diodes / rectifier in (6) above and produce a smooth DC voltage --> this is what generates the 5V and 12V/15V/16V/etc. DC for the monitor to use.
    Component (5) [optocoupler]; used for sending feedback from the secondary side of the PSU to the primary side's controller. Basically, it tells the primary side (MOSFET) if it needs to switch more or less in order to maintain those 5V/12V/15V/etc. outputs constant.
    And that's about it, in terms of basics.
    Most monitor SMPSes tend to be of the discontinuous type, i.e. "flyback".
    See page 20 of this technical seminar:
    • Adenitz
      • Jan 2021
      • 122
      • Congo
      Thank you very much momaka, this is the explanation I was looking for.
      Just one more question regarding the Component (6) output diodes / rectifier. On the attached image, on the left side there are also two diodes. I suspect that one pair of diodes produces rectified DC voltage 12V, while other pair produce 5V. I 'm pretty sure this transformer (4) has two separate secondary circuits.
      • Adenitz
        • Jan 2021
        • 122
        • Congo
        Hello guys,
        I have found a schematics of LG monitor power board and I'm currently analyzing what different parts of the board are doing.
        The schematics is attached. I can understand what is the function of most of components, except for the BJT Q901 on the 12 V line. Such transistor doesn't exist on 5 V line. It seems to me that this is additional control element, because if the voltage on this 12V line is high enough, it will turn ON the Q901, and there will be additional current path via 4 resistors in parallel to the ground. This also sound like some kind of protection.
        Can someone please clarify this?
        Thank you.
          master hoarder
          • May 2008
          • 12170
          • Bulgaria
          Correct.
          Most monitor power supplies indeed usually have a 5V power supply and then also a 12-16V supply (varies with monitors.) Some will also have a 24V supply, in addition to 5V and 12V.
          Correct again.
          The whole point of Q901 and the 4 resistors in this case is to present additional load to the 12V rail if it goes too high. It's not so much for protection, but for voltage regulation when the monitor is in standby mode. Because in standby mode, the back lights will be off, and generally the back lights are the ones that use power from the 12V rail. But with them off, there will be little to no load on the 12V rail, and that can make it go high. Since the 5V and the 12V rails come from the same transformer, the power supply control circuitry has to keep a balance between voltage regulation on both the 5V and the 12V rail at the same time. So this circuit will basically help the control circuit by loading down the 12V a little when it is too high. That way, the 5V rail won't dip too low.
          Of course, I will note here that generally you don't often see a circuit like that on most monitor boards. In fact, I've rarely seen it. So don't worry too much about this circuit.
          • Adenitz
            • Jan 2021
            • 122
            • Congo
            Thank you for the help momaka, much appreciated.
            • rddube
              Lenovo L490 Ram voltage circuit malfunction
              by rddube
              Hello friends,
              Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
              I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
              07-15-2025, 04:41 PM
            • Fernon@Repair
              Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
              by Fernon@Repair
              i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
              VCCIO voltage ok
              VCCSA Voltage OK
              VCCPLL Voltage OK
              Ram Voltage ok
              RamVTT OK
              VPP 2.5 OK
              But No Core Voltage
              and i want to this vrm ic datasheet or pinout (ISL69269)
              anyone have this ic pinout voltages?...
              06-25-2025, 07:19 AM
            • electron_jj
              Panasonic TH-L42D25A checking the PSU output voltage
              by electron_jj
              Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
              I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
              08-29-2021, 08:13 AM
              ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
              3+1 Voltage Regulator for IMVP-7/VR12 CPUs
              Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
              core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
              configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
              serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
              Based on Intersil's Robust Ripple Regulator...
              11-05-2024, 03:24 PM
            • ruletero
              Acer a515-43 low battery charge voltage
              by ruletero
              Hi
              Acer A515-43
              LA-H801P
              Fail: Does not charge battery, has low voltaje on connector.
              Laptop didn't want to turn on, only charge led blinked.
              I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
              I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
              Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
              10-24-2022, 02:31 PM
