Technics SU-Z45 vintage amplifier repair
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Got this for free, previous owner said when he connected speakers on amplifier he heard very loud cracking noises and immediately disconnected it to avoid damaging speakers and he was going to throw it away.
    When I opened the case I didn't notice anything visibly burn/bulging.
    Then I connected some suicidal speakers and turned on amp. Nothing.
    Then played with volume control and heard noises that could be due to dry/dirty potentiometer.
    Then connected audio input and retried. Left channel was working but the right channel was dead and when cranking up volume, it would make terrible noises indeed, now I get why previous owner got scared.
    I checked every cap and found 1 cap that has gone short circuit (0uF capacitance , 5-15 ohm resistance).
    I also found some caps that have started to go high esr.
    Caps had date codes of 1982, so I proceeded to preemptively replace most of them including the bad ones, using exclusively good Japanese brands 105c and entry level low esr.
    Unfortunately the amp uses the dreaded STK IC Here it is STK2038B (not to be confused with STK2038II , they are totally incompatible!) and the right channel is dead.
    Sanyo has stopped producing them since late 90s, so it is nearly impossible to find original ones. I was lucky to find some probably fake Chinese clone. Costed me around 10 euros and when it finally arrived, checked it and found it noticeably lighter than the original broken one
    So, I replaced faylty STK with good working one and also cleaned the switches and pots with CRC contact cleaner and the amp is working again!
    I attach some pictures that I took during repair, unfortunately I forgot to take an overall photo of the amp before putting back the metal cover.
    Here are 2 photos from the internet:
    http://nvivo.free.fr/Site/Technics_SU-Z45_files/3_1.jpg
    https://www.avsite.gr/forum/proxy.ph...f9819d9d5638a6
    I also replaced the 2x 6800uF main caps with 2x 10000uF 50V Nichicon GU 105C
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: Technics SU-Z45 vintage amplifier repair
    Here is a pic that tries to include every improvement/repair that I made on this amplifier:
    https://www.badcaps.net/forum/attach...1&d=1642275924
    Any comment is welcome
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8116
      I've got the same amp in silver. On mine I have a little trouble with the display kicking in and out randomly. I've been saying for the past 8 years now that I am going to fix it, but since there is so much other toys stacked over the amp, I just left it sitting right there. Its a pretty good sounding and simple amp.
      Your first post, second link isn't working for me.
      Other than that it would be nice to attach the service manual to this thread, if you have one...
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        Originally posted by goodpsusearch
        Uploading second photo here, since link is not working
        If I remember correct it has trim-pots to adjust watts level on left and right channel. Mine, always shows one channel watts lower than the other but I didn't feel like disassembling it again.
        Another unresolved issue is that the bass level adjust trimpot is not working even though I tried to thoroughly clean with CRC Contact Cleaner. I just let it in 0 position and don't want to mess more with it.
        Ok, also uploading every pdf I have, related to the amp
        AN7060 is the preamp IC. The unit has 2 x AN7060, each one on an identical daughter-board.
          master hoarder
          • May 2008
          • 12170
          • Bulgaria
          Looks like Panasonic built this amp for Technics, judging by the many AN-- ICs and (old) Panasonic logo on the big transformer.
          I guess be careful if you try to crank this thing up. From what I've heard/read on other sites, counterfeit STK modules do work, but conk-out at much lower power output level likely due to small transistor dies for the final outputs (read: cheaper to manufacture.) Certainly better to pair it with speakers that are "easy" do drive (8-Ohms impedance and DC resistance, smaller diameter like 6.5" or 8", and preferably a light paper cone or polypropylene.)
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8116
            Mine is original... never has been apart and always used "easy" on the volume, but daily until I got it. Mine has a cold solders on the display. I tap the display, I can make it come on or off... It's been like this for a long time However I should be taking it apart and give it a nice refresh some time. At least that is what I've been telling myself. lol
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              After assembling it, I kind of stress tested it with those speakers:
              https://www.dali-speakers.com/produc...tor/spektor-2/
              DALI SPEKTOR 2 SPECS
              Product series SPEKTOR
              Frequency Range (+/-3 dB) [Hz] 54 - 26,000 Hz
              Sensitivity (2,83 V/1 m) [dB] 84.5 dB
              Nominal Impedance [ohms] 6 ohms
              Maximum SPL [dB] 105 dB
              Recommended Amplifier Power [W] 25 - 100 Watt
              Crossover Frequency [Hz] 2,600 Hz
              Crossover Principle 2-way
              High frequency driver, Quantity 1 x 25 mm
              High frequency driver, Diaphragm type Soft Textile Dome
              Low frequency driver, Quantity 1 x 5,25"
              Low frequency driver, Diaphragm type Wood Fibre Cone
              Enclosure type Bass Reflex
              Bass Reflex Tuning Frequency [Hz] 51.5 Hz
              Connection Input Single Wire
              Recommended Placement Shelf or stand
              On-Wall
              Recommended Distance From Wall [cm] 1 - 80 cm
              Dimensions (HxWxD) [mm] 292 x 170 x 238 mm
              Accessories Included Rubber Feet
              Manual
              Wall Bracket
              Weight [kg] 4.2 kg
              So, the sensitivity is just 84.5 dB and they are 6ohms speakers. I cranked the volume as high as I could stand but the system was in my bedroom that is too small, so I guess it is easier to fill with sound.
              Took a pic while testing:
              https://www.badcaps.net/forum/attach...1&d=1643660536
              The case of the amplifier just got warm during this. Maybe the 10000uF caps helped the unit, same with MX4 applied as thermal paste. Don't know, but it sounded good!
              Technics always belonged to Matsushita ,now called Panasonic.
                master hoarder
                • May 2008
                • 12170
                • Bulgaria
                Neat little speakers!
                Yeah, despite the low sensitivity, I'm sure they were plenty loud. After all, you have them very near the corners of the bedroom, so that probably helps a lot, especially with the bass output.
                They might be 6 Ohms, but the fact that they have lower efficiency and smaller cone size actually makes them "easier" to drive for the amp. Smaller and lighter cones mean less mass to accelerate and stop, which means lower transient currents for the amp. And low efficiency generally goes hand-in-hand (though not always) with lower back-EMF generation... which again means lower transient currents from the amp trying to dampen cone movement (though the low efficiency does go both ways, in that the amp also needs to provide more power to drive the speakers to the same volume as more efficient ones.) But in general, this will usually make the speakers more consistent (linear) in terms of power input.
                Cool setup!
                I see you have lots of CDs and blank optical media. The cassettes, though - awesome! I've kept all of mine as well. I even managed to save a few reel-to-reels from my dad. He had a R2R Sony deck, but randomly decided to give it away one day some 20 years back. Luckily, he forgot where all of the reels were. So when I found them 5 years later during a cleanout of my parent's old apartment, I saved all of them. I'd love to get a R2R deck one day. But the prices of those currently... yeah, it ain't gonna happen anytime soon.
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  I already knew some of the above information but it's the first time someone put it all together and explained in a simple (but not simplistic) way how they are all connected. Thank you so much!
                  Cool setup!
                  This is an ongoing project.
                  Me dream is to have a system that will have the following (working :p) parts:
                  front speakers
                  rear speakers
                  sub-woofer
                  5.1 amp
                  stereo amp
                  cassette deck of acceptable quality (doesn't need to be very high end)
                  turntable
                  VHS
                  media player PC with good quality sound card, should be at least ALC1220
                  Optional:
                  CD player deck (only if I get for free, wont pay for that)
                  separate FM tuner (same as above)
                  graphics equalizer (just to watch the lights synchronizing with the sound level)
                  DVD Player/recorder (don't really want that, I just have so many lying here!)
                  I started collecting parts to build that system on my living room. But turns out that due to terrible sound insulation and not patient neighbors I end to listen 95% of my music and watching films on my bedroom. So I started building a second system for my bedroom.
                  It feels so nice that almost every part is used/repaired and many of them saved from the landfill. I tried as far as I can to avoid buying new crap that will break after some years.
                  I am going to create new threads and ask for your help as I make progress on this.
                  BTW I have a Grundig reel to reel that my grandfather found and collected from the dump back in 90s. It has been sitting in storage since then waiting for repair. It is one of the compact, portable ones though. My grandfather passed away back in 2012.
                  I hope someday I will find the time to try to fix that one too.
                  I would send it to you without a second thought if you lived in Greece or close to Greece anyway to make it a viable option
                    master hoarder
                    • May 2008
                    • 12170
                    • Bulgaria
                    front speakers
                    rear speakers
                    sub-woofer
                    5.1 amp
                    stereo amp
                    In all honestly, I don't think I can say I've ever been impressed by home 5.1 setups, ever. In theater rooms - sure. But at home, it's just really hard to do it properly. First, you have to have a fairly "proper" room for it with good symmetry (for better acoustics.) Then comes the burden of playing with the speaker placement, since that is probably the most important thing of how the system will sound. However, trying to "balance" the sound out of 5 speakers instead of just 2 really really increases the complexity. And even then, you will likely find that no matter how much you play with the speaker placement, there will still be areas in the room with poor acoustics. This goes for a simple stereo setup too, but at least it's easier to correct it overall, since you just have to deal with only 2 speakers.
                    So IDK, I tend to shy away from those 5.1 / 7.1 setups. More speakers doesn't necessarily mean better sound. It can... but there's a reason why cinemas have professional audio engineers setup their surround sound systems.
                    Not saying you shouldn't try it, though - that can still be fun, and going through the whole process, you may even learn a lot of new things. Just making sure you don't set your expectations too high and then end up not liking it. You may get really good results... but you may not, either.
                    For cassette decks, probably better to go with something from the 80's and that only has one deck. The dual decks, IMO, is where they started making them cheaper and not as good. Of course, good dual decks do exist out there... just fewer. Only problem with getting a really old deck is you'll probably run in the same issues with any old gear - likely deteriorating pots and switches in need of deoxit... AND BELTS!
                    LOL! I'm with you on that one, though.
                    Same here.
                    The only thing I buy new (sometimes!) are parts to fix/refurbish old, well-made stuff.
                    Sorry to hear that. Hope you do indeed get it fixed one day. Would be just another nice thing to remember your grandfather with.
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      Totally agree with you on this.
                      It is next to impossible to balance volume levels, early reflections, height of each speaker, etc.
                      I think that the modern Audio Video Receivers solve many of those issues with the automatic calibration software with the use of microphone, such as audyssey multeq-x and Yamaha ypao.
                      I am "lucky" that my room doesn't allow a center speaker so I have to deal with only 4 speakers and a sub.
                      Here is another pic of my bedroom:
                      https://www.badcaps.net/forum/attach...1&d=1646516894
                      You can see the ghetto stand of the rear left speaker, the speaker is a cute little Dali Spektor 1, they are perfectly capable as surround speakers.
                      I watched this horror movie recently https://www.imdb.com/title/tt5140878/
                      with the now repaired Roister sub and I could hear the sound of pieces smashing from the evil spirit coming from back left.
                      I don't care about perfection, it's just fan to watch movies like this, especially action scenes like helicopter scenes or bullet scenes. I want to have the same setup on my living room too but I need to fix the other Sony AVR that I have first.
                      I am now a happy owner of 3 cassette decks:
                      1)very old rack type single deck, totally dead. Got it for free, will start a thread some day for troubleshooting
                      edit: found pic of it online:
                      https://i.ebayimg.com/d/w1600/pict/1...Deck-Mc-11.jpg
                      but my unit is of black color
                      2) Marantz SD4050 dual cassette deck, from late 90s. I am quite sure this was not made from Marantz, must be an OEM product that they just slap the name such as Marantz, Pyle, Ion, Pioneer, Teac etc. Seems to be working, might need new belts. Of course the cassette mechanisms are plastic. Supports Dolby B and C. Costed 30 euros
                      3) Just one week ago, I got a Fisher CR-W345 dual cassette deck along with Fisher MT-345 linear type turntable. Paid 10 euros for both, so I couldn't resist buying them. They were made in the 80s and they were typical Fisher products, made in Japan but relatively cheap. The linear tracking mechanism of the Turntable needs service and the cassette deck needs new belts because the original ones have perished. Will create threads about them too when I find time.
                      Me too
                        master hoarder
                        • May 2008
                        • 12170
                        • Bulgaria
                        You also have to deal with cats, I see.
                        But I approve! ... and looks like they do as well.
                        Nice, I like that setup.
                        Your bedroom actually looks fairly trivial for a speaker setup, due to its shape and where your listening position tends to be.
                        In my bedroom / computer room, my listening position (when on my computers) is right in the middle between the speakers on the front and where the back wall is. So I get nice balanced reflections and the stereo image is as good as it can get from a stereo setup. However, the bass is really weak in that position, likely due to canceling waves. I've even tried adding a subwoofer at various positions, but it helps very little. Plus, the few positions where it did, I'd have to trip over it, lol. Also, at that point, the bass in other places in the rest of the room get obnoxiously loud and the decorative PCBs I have on my walls start to make noise from vibration. Pretty sure the neighbor can hear that. So unfortunately I have to make due with reduced bass output. But if I sit back in my bed, which is close to the wall opposite of the speakers, the bass is great.
                        But again, yours just being a smaller and more symmetrical room, I think you'll always get great acoustics. And I don't even want to imagine what will happen if your turn all the way up that Roister sub in there with the door closed. Well, actually I can imagine what will happen - the door probably won't stay closed for long!
                        Oh I hear ya.
                        I did the same downstairs in the living room - moved the table in front of the couches and put a single armchair just a few feet away from the TV, where it's equal distance from all of the surround speakers. Then I played The Last of Us (on PlayStation 3) with the sub volume cranked up and... WOW, that game is a total trip when you get into it. If you have or ever get a PS3/PS4, it's definitely my #1 recommended game for it. And with that setup in the living room, it was exactly like you describe - I could really hear everything going on in every scene. Without giving too many spoilers here, there is one level where you go into a leaning downtown building, and the creaking that building makes while you're in it is absolutely chilling. Granted the sub/surround system I have is nothing special... but it still works well. Just have to crank it up a bit. This is one reason I can never watch a movie over at my sister's place - they always turn it way down and I can't hear anything most of the time. I don't want to read subtitles if there is audio! So I always crank up the sound when watching movies.
                        Cool!
                        Looking forward to seeing these when you get the time.
                        • Francesc V.
                          Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
                          by Francesc V.
                          Hi:
                          I've realized that one of the channels of this amplifier has no proper sound.
                          This is the signal at the speakers output.
                          As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
                          Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
                          07-15-2025, 01:33 AM
                        • Sik_6ty_Sixx
                          HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                          by Sik_6ty_Sixx
                          So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                          02-18-2025, 05:06 AM
                        • eccerr0r
                          old X58 triple channel board... memtest86 memory speed?
                          by eccerr0r
                          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                          06-28-2025, 09:06 AM
                        • shelby5041
                          Vintage Fisher Studio Standard CA-39 amplifier R channel bad?
                          by shelby5041
                          hi
                          ill try to explain best i can
                          i have this old fisher studio standard home stereo system that has CA-39 Amplifier
                          it has worked fine ever since i bought it back in early 1980s
                          however, i have had it my garage as a garage sound system for about 15years...last time i used was about 5 years ago..today i decided to change out the speakers with some better speakers so i connected the speakers. left side works fine but for some reason the right side speaker was not working and was making a loud humming sound..then stopped....found out a fuse on amplifier...
                          04-14-2020, 06:10 PM
                        • AudioGuy88
                          How to bias a Plinius Odeon 6 channel amplifier
                          by AudioGuy88
                          Hi everyone,
                          I am working on a Plinius Odeon 6 channel amplifier. Not much wrong with it, but I replaced some caps (20 years old) and decided to check the bias current.
                          The manual says
                          1.
                          Code:
                          [1] Check the right DC servo is set within its operating window.
                          Use VR2 to set TP5 to within –3.0 to +3.0 volts.
                          [2] Check the bias current is correct once the amplifier has warmed up, typically 15 minutes.
                          Use VR1 to adjust the rail current to 140mA or 52.5mV across any emitter resistor (35mA per
                          device).
                          I am assuming...
                          01-28-2023, 09:30 PM
