My grandma's Vintage Speakers Winson SB 300 A (1979)
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Anyone knows anything about these?
    According to the label they are rated for 60W, but when I disassembled them I was fairly disappointed with the size of the magnets of the speakers.
    The tweeter seems to be rated for just 0.4W (!) and made in Poland from Tonsil brand.
    The woofer and the mid-range driver have no markings on them.
    The crossover is just 2 electrolytic caps in series with the tweeter and the midrange driver and also a potentiometer that is just a variable resistor.
    Pics attached
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: My grandma's Vintage Speakers Winson SB 300 A (1979)
    3 more pics
    • R_J
      • Jun 2012
      • 9535
      The power going to the tweeter and midrange will be limited by the crossover caps. The woofer is likely rated for a maximum of 60 watts, but this could also be 60 watts peak music power, not 60 watts RMS
      They are a low cost set of speakers and were likely paired with a low power amp.
      They look similar to the Technics SB-X300A
      • redwire
        • Dec 2010
        • 3906
        It looks like a low cost china or taiwan speaker. These were sold out of vans by guys in parking lots... or sometimes just fake that everyone thought was a real hifi speaker because they had the look.
        But weird to have Polish drivers, "Product kit for asemply", "Precision Crafted in USA" and a fake Kansas city address. Notice the rheostat aluminum faceplate has a signal generator front-panel exposed on the backside. As if they recycled some parts.
        The electrolytic capacitors are wrong, they should be non-polarized and without any inductors- the speaker's x-over is a rip-off and I would say anthing over 30W would damage the drivers.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8116
          definitely not 60W RMS. I second RJ and redwire's post.
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            The amplifier is a Philips stereo cassette turntable receiver.
            Unfortunately I cannot find the model name, the unit is made back in 1980 and the paper label on the rear that stated model and other stuff is unreadable.
            The turntable is plastic and it uses the idler wheel type mechanism, no belts, no direct drive. Lately the rubber has totally decomposed, so it needs new rubber wheel like the other Brawnig Mony turntable I posted on the free scores thread.
            Do you think it is worth restoring? I have limited experience with vintage equipment don't want to do any harm.
            But it is really beautiful and the casing is real wood.
            FM radio seems to be working OK.
            Tape makes a loud hum on the right channel. The belts are the original ones from 1980 so probably need replacement anyway.
            I attach some pics of the unreadable label and pics of the stereo cassette turntable receiver mainboard/amp board
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              You are totally right, it's highly possible that everything in the back label of the speakers is lies. Does it also include the impedance / distortion diagram on the front of the speakers?
              Yeap, I also noticed the weird markings on the backside of the metal of the rheostat.
              OH, how did I miss that? The caps should be bipolar/nonpolar... This is Stupid!
              I also noticed that there was no dumping material (but maybe it was not used back then) and that the bass reflex port has no tube, it's just a hole with grilles.
              • R_J
                • Jun 2012
                • 9535
                They are cheap, low cost speakers, likely sold for $49.95 back then, If they had everything you think they should, they would have been $349.00.
                They are perfectly fine for the amp that is driving them. The whole system including stand was low cost, and did it's job and didn't cost $1000.00, likely under $200.00 including the stand.
                The markings on the metal were likely silkscreened for something else and the metal was just re used and there was no need to clean off the original markings, again saving cost.
                As for the hum from the cassette unit, try cleaning the record/playback switch, it should be a long narrow switch that is activated when the record button is pressed.
                And look, another stupid thing, no VU meters on the receiver, and no record level adjustments for recording. And the turntable ....
                • redwire
                  • Dec 2010
                  • 3906
                  From pics of the board, audio amplifier IC HA1338 is rated 6W at 24VDC power and 8R load. So the power level is not enough for a party Grandma need to dance
                  For modifications I would add a low cost Bluetooth module or stuff in an LM3886 amplifier board. There's lots of room under the turntable. The power transformer looks strong.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    List of things missing from that sound system:
                    1)Most annoying : An aux input
                    2) Vu meters. I have a soft spot for VU meters, since I was a child. Too bad this thing doesn't have ones...
                    I had a boombox from my cousin that had vu meters, used to watch them move and feel so nice, his family threw it away, couldn't save it. Tried to buy used but the prices are crazy high...
                    This is it:
                    https://www.badcaps.net/forum/attach...1&d=1642362061
                    the boombox I grew up with when I visited my other grandparents on weekends
                    3) More power. Seriously, when I opened datasheet, I though I had mispelled the IC codenames. 6W per channel is too low even for those days standards.. Need to pair this with very efficient speakers to be able to output some juice.
                    4) Bigger transformer. I think the pics are deceiving, it is not very big, I have some mini hifi systems from late 90s that have much bigger transformers.
                    5) Better turntable mechanism. If my online research is correct, Philips chose to use a cheap plastic BSR mechanism, any input on this?
                    Things I don't care at all:
                    1) Bluetooth capabilities. I like to stream my music through cable. But it doen't even give me this option, since it has no AUX input / option on source selector
                    2) Recording level adjustment
                    3) Dolby noise reduction system etc
                    But, wouldn't this change the sound signature of the amp? Sure, it's not a tube amplifier, but it's a vintage amplifier made in 1980
                    • redwire
                      • Dec 2010
                      • 3906
                      It depends on what you want to keep vintage. It's in a nice stand. For all the room it takes up, why not have it be able to play mp3 from bluetooth? Or just add a box outside if the unit has AUX or TAPE IN at the back RCA connectors.
                      The cassette problems are almost always a dirty rec/play switch. Very hard to clean them because they are so long.
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        That's the problem, it only has 2 RCA speaker outputs, 1 stereo headphone jack output and antenna connectors for the 3 band radio.
                        No input at all!
                          master hoarder
                          • May 2008
                          • 12170
                          • Bulgaria
                          Most cheap speakers almost always include a frequency response and/or distortion diagram. So if you see one on a set of speakers, they are likely cheap speakers (or at best, the low end of mid-fi. )
                          Damping material goes a long way back before these speakers were made... and still is used. The reason these speakers probably don't have any is because they are cheap.
                          But that's actually not a bad thing that there is no damping material / baffle. While having it would help to reduce some cabinet and speaker self-resonances (especially at higher output power... which these speaker drivers aren't really capable of), it can also hurt (attenuate) the low-end of the bass on ported systems. Given the sub-par woofers, they really can use all the help they can get - and that means a ported box with no dampening / baffle is probably better here.
                          In regards to the tube-less port - play a bass sweep through the speakers and try to hear approximately how low the bass goes. Also, listen for any "booming" notes in the mid-to-upper range of the bass (70-90 Hz) that sound much louder than the rest of the bass range. If you hear any, roll a piece of paper like a tube and stick it in the port temporarily. Then have another listen to a bass sweep. With any luck, you might extend the low end of the bass a little and reduce any booming notes. The paper port won't be ideal, but should still show some results. Start with a port length of about maybe 5 cm, then go up. If the port is too long, it will make the speaker act like a "closed" box... and given the weak woofers, you'll probably get even less bass. So don't make the tube too long. There are actually softwares that can allow you to calculate the tuning of the port frequency per given box size. For weak drivers, ~40-50 Hz tuning should give a good balance between low-end bass and high dB output.
                          My brother-in-law has a similar "rack" system he got back from his parents's apartment when they moved. He said they had this system since the 80's or so. Philips, as well.. and with the matching speakers. I ghetto-fixed the rotten foam on the speakers this summer, since he didn't want them, but wanted to keep the system and connect it to their TV's soundbar.
                          While these "rack" systems were kind of cheap and certainly nowhere near a marvel of Hi-Fi (or even good lo-fi for that matter), they do look really nice. So I'd say these are worth restoring just for the looks/radio, if nothing else (though I'm sure spending a bit more time with it can restore the other functions too.)
                          LOL at the last sentence!
                          6 Watts is actually not that bad with some efficient speakers. If the speakers posted in this thread are anything like the cheap Philips speakers that came with my brother-inlaw's system, they should be fairly efficient, despite the small motors.
                          No, you won't be demolishing walls with Bass I Love You (Heck, I'd be surprised if these speakers can even react/move to any of the bass notes in that song.)
                          But such speakers can still produce decent enough sound with 0.5-1 Watts input. Mostly suitable for when you have people over and sitting/conversing at the dinner table with some "light" music in the background.
                          You might be able to easily add that.
                          Just see which IC is the "mixer" pre-amp and then pick an input you'd like to "double-over" with the Aux input. For example, let's say you do that over the Tape input. Trace which signals come from the tape pre-amp IC and re-route them to one side of a DPDT switch. On the other side of the DPDT switch, add your Aux input. Depending on which way the DPDT is toggled, you'll have either the tape still playing or the Aux input.
                          This is it:
                          Oh man, that's such a shame that boombox went to waste. Those are really hard to come by anymore.
                          And yeah, I also like watching the VU meters. But I also like my dad's Sony gear (tape deck and TA-F70 amp), which had beautiful LED level bars. Watching those lite up and off as a kid is pretty much how I always listened to music.
                          Give the current speakers a listen. They might have decent efficiency. By the looks of the motor, they have a really shallow magnet and probably 0.75" VC... so they should still be able to make plenty of noise.
                          Signature? What signature?!
                          It's a cheap IC amp. Nothing special about it.
                          Mod it like crazy if you want to retain the looks but get better/updated/modern functionality.
                          Or use as-is for "casual" listening and nostalgia.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8696
                            TBH 2WPC is sufficiently loud for me, more than that gets into the realm of pain.
                            Only thing is that if running at full volume, THD tends to be fairly high for most amplifiers so yes need something with like 20WPC and run at 2W to keep THD down.
                            I'm still pondering whether I should get rid of my Heathkit AR-1219... Works fine but eating space, and feel a better connection with my Realistic STA-64B tuner that I got with a blown final and got it repaired...
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              Noted everything, this is such a great piece of information and advise.
                              I also thought of using the tape input to add an aux input, but your idea of a switch is great. Now I have to google what is a DPDT switch
                              They are really stupid, I try not to think about it because I feel guilty I didn't save it.
                              My cousin also had a hifi system (probably made in Taiwan, nothing really high fidelity) but full with blinking lights. I love this kind of stuff and I really want to be able to live it again someday...
                              I have a graphics equalizer that came for free with the Technics MK2, those have lights, right? I have so many running projects right now I didn't even have time to test it.
                              And I also got for free a rack type cassette deck with VU meters but the unit appears to be totally dead. It's not the belts unfortunately. So many things to fix/test/play with!
                              Already done. Unfortunately the paper is badly torn on the mid frequency woofer and the other speaker that has no visible damage on its woofers also sounds like something went bad.
                              I wont spend any time on those fake speakers. I will revisit thread and let everyone know when I have news about the Philips system though
                                master hoarder
                                • May 2008
                                • 12170
                                • Bulgaria
                                Heh, that reminds me of the first time I saw a JVC Gigatube system in a Sears store (once upon a time, a very respected electronics and appliance store in the USA.) I always thought those JVC systems looked absurdly ridiculous... but when I recently "re-discovered" the name via Youtube videos, its design just hit me in the face and screamed early 2000's all over it. Now when I look at them, not only do I see 2000's vintage, but TBH also something like out of a futuristic Cyberpunk world. I know it's all plastic-fantastic crap... but does look kind of interesting now, simply because it's so ridiculous. And FWIW, at least these JVC Gigatubes weren't actually that bad in terms of audio quality - small ported speaker enclosures with small-ish drivers, but big enough magnets on them to produce decent boom & rumble. They just couldn't get too loud and obviously their PMPO ratings were completely out of this world's reality. But at low-to-medium volume... they did surprisingly OK. Maybe someday I should get one of those JVCs, just for the sake of early 2000's nostalgia and flashing lights, as you mentioned.
                                Maybe the transformer went bad?
                                I'm the same way. Sometimes I wonder if I can even complete a fraction of my started projects in my lifetime, lol.
                                Interesting.
                                Maybe the magnets are starting to rust from the inside out, like with these Panasonic Thrusters speakers? In the case of the Thrusters (what a funny name ), I didn't waste too much time trying anything with them - just saved the magnets from the drivers, the bipolar caps, and the tweeters. The rest went to the bin/trash.
                                • kaboom
                                  "Oh, Grouchy!"
                                  • Jan 2011
                                  • 2507
                                  Sears, now there's something that's fallen...
                                  JVC Kaboomboxes & Gigatubers- early 2000's in their own way!
                                  To think those are "old" or semi retro now...
                                  Futuristic cyberpunk indeed. There was such hope then.
                                  Keep that thought in mind. Specifically the lights.
                                  Interesting.
                                  Those were well & truly finished. "Thrusted" (LOL) into the trash pile!
                                  "pokemon go... to hell!"
                                  EOL it...
                                  All style and no substance.
                                  guilty,guilty,guilty,guilty!
                                  guilty of being cheap-made!
                                  • SolomonMan
                                    Vintage BK Precision 1403 Oscilloscope....
                                    by SolomonMan
                                    All,
                                    Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
                                    Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
                                    I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
                                    12-03-2023, 10:39 PM
                                  • willis6732
                                    LTO PS 4LA Powerred Speakers - Tweeter Audio Low
                                    by willis6732
                                    Hello, I have two of these speakers with the same Prioblem. The tweeter volume is very low. I believe it happened after running them too loud.
                                    There is a lightbulb on the tweeter output i tried shorting and no change.
                                    The tweeters measure 6 ohms and it seems to play loud if i plug them into an alternate amplifier
                                    There are a couple resistors and diode getting really hot in the mute circuit...
                                    At the bottom left of image. R17 gets the hottest. Over 70 deg C
                                    Z1 and R7 next to that get hot as well. Zener tests ok
                                    I measured the...
                                    11-02-2023, 06:14 PM
                                  • abdalla
                                    Surface laptop 4 1979 Bios Fixing.
                                    by abdalla
                                    I have surface laptop 4 1979. I have cloned the bios bin using teensy spi flash and treid to restore it. Unfortunitly the laptop doesn't post any more can someone help with this issue please?...
                                    03-02-2024, 05:00 PM
                                  • edugimeno
                                    Diagnose real-vintage Strong-Hammer arcade machine
                                    by edugimeno
                                    Hi there!
                                    My friend wants me to help him repair his old-real-vintage strong-hammer machine. Well it's only 90% real as the force applied doesn't lift the weight itself but it is measured and it moves a motor that lifts the weight
                                    I am attaching several pictures of the machine.
                                    It basically has 2 sides, left side has
                                    • 2 x 220->12+24v transformers
                                    • 2 relays (1 moves motor UP, other moves motor DOWN)
                                    • IGF and breakers for safety
                                    Right side is shown on pictures. It has 3 boards ( top-down)
                                    • Logic board. Receives 24AC and recitifies it into DC. Contains a uC (M80C85)
                                    02-29-2024, 11:05 AM
                                  • tony359
                                    Acer V58 Vintage Socket 7 Motherboard
                                    by tony359
                                    I'm trying to troubleshoot a vintage Acer V58 motherboard, ALI chipset 1541/1543. Symptoms are: it's very dead.
                                    The CPU in question, a plain Pentium 200, it works on a different board. I have checked the voltages, the clock and the reset lines. All checks out.
                                    However I have ZERO activity on the CPU data/address lines. It's like the CPU is told NOT to start but I cannot figure out how. A post-card shows "--" and there is of course no activity on the BIOS address/data lines.
                                    I checked the HLDA (Hold Acknowledge) line which could indicate...
                                    02-27-2024, 07:07 AM
