can a flyback transformer for USB charger isolate?
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    can i use a flyback transformer from an usb charger to isolate galvanically a small diy led tester? or it must be an isolated transformer
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Re: can a flyback transformer for USB charger isolate?
    what are you trying to do, what hardware are you assuming?
    A usb charger should be isolated as it is...
    • bohaboha
      • Nov 2012
      • 1017
      • sweden
      I was thinking of a led tester from a led lamp circuit
        • Jul 2011
        • 6070
        I would recommend that you use a medical grade switching power supply most of the time made for quality than your general grade customer devices are if you are going to use it continuously every day type of uses
        For my iPhone and iPad I use a medical grade switch power supply 5 volts at 5 amps switching power supply
        But this is going to depend upon what voltage you plan to use and if you are going to test strings of LEDs lights which you have not mentioned yet or are just testing individual LEDs then a 5 volt switching power supply would work with a LM317 in the current mode
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8703
          Funny, when I near flyback transformers I always think about the second anode transformers for CRTs first and their associated high voltages... because that's where the name came from in the first place.
          Again LED lamp circuit isn't very clear, suspecting a high voltage current limited supply to power long strings of LEDs, which seems a bit inadequate for wall wart 5V transformers...
          • redwire
            • Dec 2010
            • 3912
            The term came from CRT's, AFAIK. When the B-field in the transformer quickly collapses, it made the HV spike and the beam quickly "flies back" (blanked) back to the left edge.
            • bohaboha
              • Nov 2012
              • 1017
              • sweden
              Hi sam sam sam, eccerr0r and redwire and thanks for your answers it is intended for general use also to test black light without disassembling in terms of flyback transformer I thought if it is possible to use one from a usb charger or similar here I am waiting on your proposal to achieve the galvanic isolation and not use a charger as eccerr0r has perceived
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8703
                What "LED tester" are you using?
                The general solution is to just get an isolation transformer. If you can't get one, you could get two identical voltage line frequency transformers and connect them back to back, and you get isolation that way. Of course there are limits to what you can do with this but for very low power it should be acceptable.
                The optimal solution is to design the LED tester such that the isolation is built-in...
                • bohaboha
                  • Nov 2012
                  • 1017
                  • sweden
                  it is a diy tester from a led lamp circuit that needs to be isolated for safety but adding two identical voltage line frequency transformers will be clumsy if they are not small. can you use a small flyback transformer that you can find in a cell charger? or you may be able to refer to two small transformers that can be used.thank you
                  • redwire
                    • Dec 2010
                    • 3912
                    What voltage do you need for the LED string you are testing?
                    In Sweden they have many isolation transformers but developing countries they are too expensive.
                    For high voltage strings like in TV's you can use a 5V charger SMPS transformer connected backwards. They have isolation of course.
                    • bohaboha
                      • Nov 2012
                      • 1017
                      • sweden
                      I have several 5v chargers I will disassemble some take pictures then you help me to choose the right one
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8703
                        clumsy > electrocuted...
                        hmm suppose it is possible though a lot of hack work is needed...hmm...not as simple as back to back line frequency transformers...
                        • bohaboha
                          • Nov 2012
                          • 1017
                          • sweden
                          so you think it's easier with back to back line frequency transformers? what size transformer should be able to have in this case
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8703
                            not sure where people got the idea to use the transformer in switching psus? Doing it with line frequency isolation transformers or back to back identical transformers is much easier.
                            I'd like to see this switch mode transformer idea, it's possible but tricky to pull off...
                              • Jul 2011
                              • 6070
                              This post is getting interesting to follow more closely
                              • bohaboha
                                • Nov 2012
                                • 1017
                                • sweden
                                I have seen several on youtoube but one was very interesting: DIY Backlight / LED Tester from LED tube .Watch it and say what you thought
                                • bohaboha
                                  • Nov 2012
                                  • 1017
                                  • sweden
                                  https://www.youtube.com/watch?v=rhcaMuePo_o
                                    • Jul 2011
                                    • 6070
                                    Originally posted by bohaboha
                                    Nice idea but I would want to be able to to select different current modes I will build one my self but have voltage and a current module so I do not have to have a meter hookup externally hooked up
                                    Thank for sharing your idea I have a backlight tester but I do not like it limitations that they used
                                    I would suggest that you use caution using this testing device and put it on the outside of the device what it is used for
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8703
                                      oh gawd 30 minutes of attention stealing, after breaking an apparently good LED lamp, stealing its driver circuit...
                                      Then draws a schematic of a capacitor dropper circuit and then has some transformers which are uncommitted?
                                      could someone summarize the rest of it in english?
                                      (In other news from the recovery shop I got a 12-24v to 5v dc-dc converter. It was *DEAD*. So I had to open it, unfortunately it was potted in silicone. Yay silicone. Found that the output shunt appears to have fried and shorted out. Replaced it and looks like it's happy again. But this is totally unrelated to this thread, or is it?)
                                        • Jul 2011
                                        • 6070
                                        Yes it is but thanks for the update on your project
                                        • motormayhem
                                          Lenovo T460 Only Charges on One Charger
                                          by motormayhem
                                          Laptop Question
                                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                          05-12-2023, 01:46 PM
                                        • retrotechrestoration
                                          Looking for a flyback transformer for an Eizo TX-C7 MA-791 17" CRT
                                          by retrotechrestoration
                                          I just saved this magnificent RGB input Eizo Flexscan TX-C7 MA-791 from the local e-waste...good news, the tube works and the board looks great...the bad news, it sounds like the flyback is shorted. (Turns on...perfect picture...systemic high voltage crackling heard while the picture flickers...then it blows the 5A fuse in my isolated A/C power supply.)
                                          Anyone have any leads on possibly finding a replacement? (photo shows the flyback model numbers)​...
                                          03-22-2024, 06:50 AM
                                          ISL88739AHRZ ISL88739 Laptop Battery Charger Datasheet
                                          The ISL88739 & ISL88739AHRZ are a highly versatile combo battery charger
                                          configurable for operating as either a Hybrid Power Boost (HPB)
                                          charger or a Narrow VDC (NVDC) charger, supporting 2-, 3-, or
                                          4-cell batteries. Both configurations allow the battery to work with
                                          the adapter together to supply the system load when it exceeds
                                          the adapter capability, referred to as system Turbo mode. HPB
                                          charger configuration reverse-boosts battery energy to the system
                                          bus to help the adapter provide the system power in Turbo mode.
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • flat-earther
                                          how to prevent a connected charger from draining battery when not charging?
                                          by flat-earther
                                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                          So the battery is backfeeding the charger and being drained.
                                          How can I prevent...
                                          08-07-2025, 01:04 PM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
