Sapphire RX 480 - 8go no power - 0 volts à +VDDC - Help to find why
  • fab13
    • Dec 2021
    • 109
    • France
    Sapphire RX 480 - 8GB no power - 0 volts to +VDC
    Hello to all =D
    I would like to start this card again for my little brother.
    Symptoms :
    No power on , no rgb led , black screen , no rotating fan.
    What I found before disassembly a 22uF capacitor on the +VDDCI line was loose. Before powering up and checking if the component was missing, the capacitor was replaced.
    Then powering up
    +12V ok
    +5 Volts ok
    +1.5 V ok
    + 0.90 ok
    What I found abnormal :
    -No 0 Volt on the +VDDC line of the CPU, value found 0 Ohm, diode mode 0mv and finally 0 Volts on the whole phase row (Which can be seen in grey metal capsules and I circled in yellow.
    The +VDDC seems to be controlled by the power regulator if I am not mistaken.
    What I did:
    1) Removed the synchronous buck gate (IR3553 chip) driver phase 6 and phase 1 and still 0ohm and diode mode 0.01 mV on the phases
    2) Removed then one by one the 4C10N mosfets but before removing everything I found 12 Volts drain on each but still 0 Ohm on the phases.
    Can you look at the diagram I am attaching on page 15 of 26 all the phase lines and the +vddc line and I am attaching the other photos for your convenience.
    and the Buck controller datasheet
    To tell the truth, I may be going the wrong way, no?
    Thank you very much in advance team =D =D
  • DrasticRepairs
    • May 2021
    • 23
    Re: Sapphire RX 480 - 8go no power - 0 volts à +VDDC - Help to find why
    It's normal for vcore vddc to be 0 ohms. The only way to test that is with voltage injection. If it draws more than 5A at 0.8V, the core is probably shorted.
    Don't worry about that, though.
    If a MOSFET is bad, it shows up as a short on the 12V rails.
    You'll want to check enable on the vddc controller. If you don't have EN, then trace that back to it's source. You can also check resistance and voltage on perst_buf. It should have 3.3V and nearly oL resistance.
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      The resistance of Vcore should not be 0 ohms! Don't try to read it in diode mode you need to read it in resistance mode.
      Some GPU have a very low Vcore resistance around 0.6 ohms or less - I measured an RTX 3080 at 0.2 ohms and that powered up though it crashes after drivers load. That is the lowest one I ever found, but even so it should not be 0.00 ohms - that is a shorted GPU or some other component (MLCC capacitor) that is short
      Follow me on YouTube
      Learn Electronics Repair
      • DynaxSC
        • Apr 2021
        • 470
        • Poland
        Hi, there are special so called milliohm meters, which can measure such resistances very accurately (they use a bridge architecture). I use YT2050, you can buy it on a famous chinese portal. It's cheap and quite accurate. And these resistances are even lower, for GP104-200-A1 (GTX1070) I measure it as ca 0,14 ohms. Everything under 0,1 ohms is already a suspect to be damaged, but 0,14 ohms is already OK.
        • fab13
          • Dec 2021
          • 109
          • France
          I would like to thank you for your help really for the moment it is complicated to find the problem
          So to answer you DrasticRepairs
          I injected 0.8 V at +VDDC and consumed 2.40 Ampere and as you said if the core is shorted it should overconsume then about 5 A and nothing heats up on the thermal camera.
          In addition I measured in Ohm to rectify what I said above, I am at 00.4Ohm (Same value when I touch the red and ground on my voltmeter) =S
          For the mosfet IR3550 on VIN on phase 1 to 5 = 0.670Kohm and VIN phase 6 (Located the lowest) measured at 6.01 Komh it seems to me quite high compared to others.perhaps following my withdrawal.
          A VCC = measured all phases at 14Kohm
          What does it mean when a value is high in kOhm on a line for example?
          I can't find what you indicate =D (prest_buf) , do you mean I have to check on the buck controller IR3567B on ENABLE line 21?.
          What I get is 10.36 Kohm and seems to be VDDC_VDDCI_OE_VR which is the 0.8V_PGOOD
          The 0.8V_PGOOD goes to the GS9238-ATQ chip what should I measure on it?
          Am I doing it wrong?
          IN VCC = 0.410kOhm measured (I think I saw 3.3 Volts before removing the mosfets)
          The mosfets 4C01N (which are circled in white and removed) the Q4609 on drain = 6Kohm
          Q4610 AND Q4611 = 17 Ohm
          SEE THE PICTURES TO UNDERSTAND BETTER
          Sorry if I don't know the terms, I'm a beginner since 1 month =D
          Hello dicky96 =D
          Thanks for the little tip really but what does MLCC mean? I can see it on the +PW_MVDD_PHASE line going to GS7256 (a single buck controller)
          On phase 8 (+PW_MVDD_PHASE) = 20 Ohm
          What else should I check because I don't know what to do ^^
          and then I'll reassemble everything I have desoldered.
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            Sorry for using terminology - it means Multi Layer Ceramic Capacitor
            I explain them, and how/why they fail, in this beginners video
            https://www.youtube.com/watch?v=R9slJUqT6Ls
            Also check this out if you didn't already see it - it has 30K views, so I must have done something right. It might help you understand things.
            https://www.youtube.com/watch?v=SmVdl8kew_4
            • fab13
              • Dec 2021
              • 109
              • France
              Hello Dicky96
              You did a great job and I understand better the way a graphic card works and I'm less blocked on some points
              However I will have to look again and take notes on the points I don't understand.
              I'm looking forward to follow other videos on the repair of graphics cards or motherboards.
              For information no short circuit on the VIN of IR3553 but on SW which has two mosfets internally I still fall to 0.06 Ohm despite removal of all controllers and obviously to the coils
              At the end of the video you insist on the subject of PCI-Express not short circuit.
              For the moment I do not know yet where is the problem =S
              • victorioz
                • Jan 2021
                • 16
                • Indonesia
                Originally posted by fab13
                Hello Dicky96
                Did you find the problem?
                • harp
                  • Jun 2022
                  • 616
                  • Planet Earth
                  Hello!
                  First of all, thank you for great video I like it.
                  https://www.youtube.com/embed/SmVdl8kew_4
                  but I am confusing, need some more details on:
                  54:20 coil vs gnd... 0.2 ohm
                  1:00:10 coil vs ground?... 6.5 ohm? what is this reading, please explain why you get difference in reading if is one probe on ground, second on big coil? What reading must be of good working card?
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • zaurus81
                    Asus TUF Gaming F16 (2024) FX607J no power no ACDRV
                    by zaurus81
                    Hi all, I have a Asus TUF Gaming F16 (2024) FX607J motherboard with liquid damage. The oxide on the board was removed before giving it to me. This made it more difficult to repair. Also they did not give me the power supply.
                    When I connect the 20 volts with the bench power supply I get 4.3 volts on the main power line. If I remove the power sensing resistor I get 20 volts on one side (first 2 mosfets are ok) and 4.3 volts on the main power line (see photo). How is this possible?? I thought the 4.3 volts was coming from the battery mosfet so I unsoldered it and tested it. It is ok too. I...
                    11-21-2024, 05:04 AM
                  • danielgerman681
                    ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                    by danielgerman681
                    Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                    08-27-2025, 01:17 PM
                  • MisterAIL
                    PS5 digital / No Power / No Beep / Good power supply
                    by MisterAIL
                    Hi everyone,
                    Brought a non functionnal PS5. Apparently only a bad PSU...
                    No beep, nothing.
                    After some tests i found this :
                    - PSU is fine (12 volts stable)
                    - 12 volts line is shorted
                    - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                    - By the way, nothing change. No signal, no power, no beep.
                    Mesuring all rails with my workbench psu (12 volts input)
                    - 0.00 amp drawing
                    - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                    03-12-2024, 03:24 PM
                  • Mcfeetroy
                    Fishing bite alarm drains battery
                    by Mcfeetroy
                    Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                    08-01-2025, 03:52 AM
