Roister Pb-150 Subwoofer repaired, how to prevent from failing again?
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Before creating thread, searched and found this one:
    https://www.badcaps.net/forum/showth...hlight=Roister
    Looks to be the same model with the one I have, but the issue seems to be totally unrelated.
    I got this subwoofer for 40€, previous owner said that the amplifier broke down again and he doesn't want to fix it again. Said he already fixed it once and the technician he went to fix it told him that those who designed this thing did a lousy job.
    This unit is designed and made in Greece, it claims to output 150W RMS real power and the woofer is large 10" inch and can go very low, down to 20HZ maybe.
    I will attach just some overall pics of the sub for now, due to lack of time and will resume tomorrow posting pics of the different boards and description of the issues.
    I removed one bass reflex port waveguide to be able to insert my hand and take those inside the cabinet pics
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: Roister Pb-150 Subwoofer repaired, how to prevent from failing again?
    First I checked the woofer, hooked it to the speaker output of a cheap Philips Mini Hi-Fi system and verified it is not damaged.
    Then started checking every component on the amplifier board and found 2 bad and 1 that when testing with multi-meter found values slightly off so replaced all 3 of them anyway
    https://www.badcaps.net/forum/attach...1&d=1642457710
    green color means component OK
    yellow = suspicious
    red = bad
    The components that I replaced are 2n5401 and S9014. Total repair cost less than 2€
    I also carefully removed that terrible glue that gets conductive and corrosive.
    Then checked subwoofer and it works!
    But now I have to decide what else needs to be done to help the unit not die again.
    I have noticed on this forum that active subwoofers of different brands and price range are prone to amp failure due to a variety of reasons such as bad caps, overheating because the amp is in an enclosed space with limited airflow.
    I also noticed something absolutely stupid.
    As you can see on the pic attached, they used 50V rated main caps but the transformer outputs 71V AC.
    I tested voltage across the caps with multimeter and each one had around 50.2 to 50.5V
    But this unit has been working for years and the caps tested with my esr/capacitance/leakage testers and were perfectly fine.
    Buying new caps rated more than 50V and keeping original capacitance of 12000uF or even going one size more to 15000uF , will make the total cost too high and getting this subwoofer for 40€ wont be good deal anymore.
    What do you think I should do? Leave them alone? Do you think that the fact that the sub was made in 2009 and the caps lasted all those years means that they will probably be OK?
    Caps are 2x 12000uF 50V Panasonic CE 85C
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8703
      No you don't multiply 35.5V * 2, it's simply 35.5*1.41 and if the max DCV of the capacitors are 50V you have no room for error. With high quality capacitors that 50V is the "working voltage" (instead of "max voltage") this is fine, as long as you don't exhibit long durations of higher than nominal line voltage. If you have cheap underspecced leaky capacitors your capacitors would have exploded already.
      Seems you got it working, congratulations. Unfortunately it's hard to say what design issues there are without a schematic, or at least I have no vested interest in reverse engineering this, sorry.
      (Oh, if you want to reverse engineer it and post the schematic, sure I'll (or anyone else here) will take a look and give suggestions as to how to make it robust!)
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        Thanks for the reply.
        I haven't drawn a schematic of it but I found the amplifier circuit it's based upon.
        https://www.elcircuit.com/2016/09/a1...p-circuit.html
        There is even a circuit diagram on the link above.
        And one can buy it from aliexpress as a module:
        https://www.aliexpress.com/item/3295...34567bdf97a9-1
        https://www.aliexpress.com/item/3300...34567bdf97a9-3
        https://www.aiyima.com/products/ampl..._type=customer
        As you can see:
        " It is recommended to add a horn protection circuit. The horn protection circuit can not only eliminate the impact noise of the power amplifier switch machine, but also avoid the output DC burning the horn when the power amplifier is damaged."
        So, they must have taken this circuit, added some type of protection circuit for the woofer and maybe other stuff, added transformer, main caps, preamplifier board and the subwoofer is ready to sell.
        But on the link above it also says:
        Operating voltage: ± 10V to ± 45V (recommended voltage (+35V) -0-(-35V))
        Rated output power:100W (4Ohm ±35V)
        Maximum output power: 150W (4Ohm ± 45V) is very hot, not recommended.
        This might mean that the people who designed this sub woofer pushed the circuit to its limits to get more Wrms and this might be one of the causes of high failure rate.
        I am no expert in amp circuits, I cannot even tell if this is class A or B unfortunately, I can only tell this is not Class D, please correct me if I am wrong.
        Here is a youtube video with the module:
        https://www.youtube.com/watch?v=YKh2P7PGKqQ
        It can also be used with more components:
        https://320volt.com/en/2sc5200-2sa19...kator-devresi/
        Anyway, I think that the reason of the failures is mainly the fact that all the components that you see here:
        https://www.badcaps.net/forum/attach...4&d=1642457707
        are totally sealed:
        https://www.badcaps.net/forum/attach...2&d=1642379917
        I have seen quite a lot of subwoofers, several cheap plastic pc speaker ones and only a couple of more expensive like this, including Yamaha, Creative, Altec Lansing, Logitech and more. I have never seen a design like this, where the amplifier is air tight sealed.
        Usually the amplifier parts get fresh air through the subwoofer bass reflex port(s) and there is quite a respectable amount of air circulation when the subs are used at moderate to high volume.
        On the contrary, this thing is totally unable to take advantage of the woofer movement.
        Yes, there is the classic metal heatsink that is outside the subwoofer but only 3 components are attached on it: 2SA1943 2sc5200 and 2N5551.
        So the big resistors could be actually cooking nearby caps and the TO-92 transistors.
        Can you please tell me if this is some type of novelty, totally sealing the amplifier parts ,or you've seen it on other subwoofers too?
        I attach pdfs of all the silicon of the amplifier board and the preamplifier board.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8703
          Pretty much all audio power/speaker amplifiers, regardless of manufacturer, are class AB. However surrounding the AB drivers lies the secret sauce, so you need to get the *exact* schematic to analyze, especially if just that one is failing...
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            yellow = suspicious
            red = bad
            Well, if these two transistors burned... and assuming that's what went wrong the first time around... then they must clearly be undersized for the task. The question is, where are they lacking? It could be the power dissipation rating, it could be the current... or maybe even the voltage, despite nothing in the circuit being able to provide a voltage that high.
            So to answer that, check what these two transistors are connected to. I suspect you're going to find these are the "linear droppers" for a complementary +/-12V supply for the op-amps. Since the transformer seems to have only one set of complementary output (the +/-35V AC taps... meaning 50V DC, as you found), then that means somewhere on your main amp board, there will be two transistors that generate the +/-12V (or could be up to +/-15V) rails from the +/-50V DC of the big caps. I only see small TO-92 transistors from the pictures you provided (except for the main output drivers, of course), so that means two of these TO-92 transistors will be tasked with generating those lower voltage rails. And because they would be dropping close to at least 35V DC (well, possibly less if there are any resistors in front of them to "assist" with the power dissipation), then it really wouldn't be too hard for them to overheat and fail.
            Thus, I suggest you find which transistors generate your pre-amp complementary power rails (+/-12V or however much) and see if these are the ones that failed. If yes, switch them out for bigger transistors, like B772/D882... and maybe have them connected on an aluminum piece of heatsink, since they are enclosed in a box with no ventilation.
            **EDIT**
            I had a quick trace around the circuit, and Q56 seems like a possible pre-driver for the big 2SC5200 transistor... so probably a little too week for it.
            /edit
            Typical design of modern-day electronics.
            This is very similar to what I saw in a pair of JBL S412PII active speakers I posted about here:
            https://www.badcaps.net/forum/showthread.php?t=73625
            ^ For those, the main caps were rated at 63V and the transformer was outputting about 42V AC (59-60V DC after rectification.) The speakers were from the early 2000's and I did the repair in early 2018... so they lasted about 15 years - and that's with those main caps being CapXon brand.
            So FWIW, you probably could leave those caps in there, provided your AC line doesn't spike up a lot and too often above 230V. But IMO, it's not a good idea. According to several Panasonic cap data sheets I've read: if you run a cap at or very near its rated voltage, the chances of the cap failing increase a lot more (typically the cap may fail open-circuit.) And in my case above, one of the caps was indeed failed open-circuit. Granted it is CapXon and not a good brand... but I just don't like the idea of caps running that close to their rated voltage. For my repair, I used 80V caps. As for your model, I suggest going up a notch in the voltage to 63V... and if you wish to keep costs lower, perhaps lower the capacity one notch. 10000 uF caps should still be plenty adequate for the 150W RMS of one lone speaker driver.
            Well, if the failure is always those 2-3 small transistors that you replaced, that's probably not due to pushing the design too far, but rather pushing cost-savings too far with using really small transistors.
            Actually, now that I mention this, it may also be worthwhile to check the pre-drivers for those large transistors. Are those TO-92 stuff too? If so, that's just too cheap. Again, I would expect to see transistors with packages more along the lines of TO-126 or bigger.
            It's class AB.
            You won't see Class A used for anything high-power due to it being very inefficient (20-30% at best, IIRC.) Only on pre-amp stages, where power is low.
            Class B, on the other hand, has pretty good efficiency (70-75%... again, IIRC), but has terrible cross-over distortion, so you won't find this used anywhere.
            Then there is Class AB, which is a combination of class A's low distortion and class B's efficiency. Essentially, class AB looks just like class B on the circuit level, but the output transistors are biased to conduct slightly at no-signal so that cross-over distortion is eliminated.
            And then there's Class D - very high efficiency (90% or more typically) and pretty low distortion nowadays (with modern ICs.) But you would indeed recognize a Class D fairly easily, as it will have a toroid/inductor and large PP cap on the output for the speaker for the L-C filter.
            Oh, and there's also Class G and H... which are basically just class AB with enhancements to the delivery of the power rails in order to increase the efficiency. The JBL S412PII are class G/H
            are totally sealed:
            And you're probably right.
            Yeah, I like subwoofers that do this. It's much easier on the electronics, especially if they are indeed located near the port(s).
            Again, have a look at the thread for the JBL S412PII above - it's the same thing with those plastic boxes on the plate amps.
            One reason why the electronics on really high power amps are sometimes enclosed in a box is so to keep air from escaping and making "whistling" noises through various holes on the plate amp (like knobs, switches, input jacks, and etc.) Otherwise, they would have to pot the whole thing in glue. Also, a separate box may reduce resonance noises produced by the plate amp. But yeah... the tradeoff is a box full of hot electronics.
            And again, since I don't see anything but TO-92 transistors anywhere, I imagine it's the linear power supply droppers that are running too hot and dying there. On the JBL S412PII, these ran mad-hot... and they were in TO-126 packages. The heatsinks I added probably barely mattered... but better than nothing!
            Not so much anymore nowadays.
            Good low-distortion class D amps have been going for a good number of years now (at least 10) and are pretty much the only thing used anymore. Only in "high-end" home theater amps you can still find class AB. Otherwise pretty much everything has moved to class D due to smaller size and higher efficiency (and hence possible to use lower-cost power supplies and other parts.)
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8703
              Hmm... indeed a lot of recent discrete amplifiers are class D, definitely not larger, older gear with class D or A, and definitely not B.
              Now I wonder about this small amplifier:
              https:// www.ebay.com / itm / 224789720143
              How to tell if this is AB or D by just looking at the picture?
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Good question. I don't think you can tell just from the picture alone. Class D is supposed to have an L-C filter on the output, but I don't see any on this board. Perhaps there is something integrated inside the IC? I doubt it, but who knows. Or maybe it's really just class AB and mislabeled as class D. OR OR you're supposed to add on your own L-C filter?
                In any case, it's probably best to find a datasheet for the IC (if you can read its part number) and go from there. I never solely trust the listed specs in the listing.
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  I drew a partial schematic of the thing.
                  I focused on the power supply of the pre-amplifier and an auxiliary power supply that I am not sure how it's used. I am sure that the working led light of the unit is powered from this aux psu. It's a 2 color led, red color to show it got power and green light when everything is OK and the relay connnects the amp to the speaker. So, I thought it might also be part of a protection circuit.
                  On the links I posted above with the Chinese boards that use the same main complementary transistors, it is strongly recommended to add some type of protection to avoid damaging speaker in case amp blows.
                  Unfortunately, you will not find on my drawing none of the 2 transistors that failed.
                  It is getting really late here, so I have to go to sleep now, but I promise that I will return to read again your posts and thoroughly reply.
                  I also attach pics with the areas that I was able to reverse engineer marked in circles to help you understand my terrible work.
                  As you can see on the pics and the drawing, based on their role on the circuit, I am thinking to change some cap values with higher to help the audio quality and more importantly lower the stress / overheating of some parts.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8703
                    Most of the schematic you drew is the PSU.
                    As far as I can tell the discolored area is the auxiliary power supply for the anti-thump circuitry to prevent the speakers from bumping when powering up... so none of the known failed transistors are here or is it drawn?
                    Seems this auxiliary PSU will constantly draw power and thus heat up as long as the amp is powered up and after it connects the speaker after the power settles, so I'd expect that 330Ω resistor along with the two transistors in the anti thump circuit would constantly be drawing power and heating up though tough to gauge how much the components would heat up - maybe a little, estimate indicates the semiconductors may be brunting part of the heat while pulling the relay.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8703
                      BTW it would be nice to put component designators like Q45, C3, R6, etc., etc. so we could textually mark which device we're talking about.
                      I don't think any of the capacitors that you query in the schematic - whether increasing capacitance would affect things much. You might improve audio quality if you're hearing hum but this would more be of a PSRR issue of the preamp, otherwise it may increase turn on time.
                      The two transistors drawn in the upper right of the schematics are what I'm slightly concerned about. These will probably heat up. Question next is where does that 10K resistor on the right of the drawing go... to prove that's the anti-thump.
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        Originally posted by momaka
                        **EDIT**
                        I had a quick trace around the circuit, and Q56 seems like a possible pre-driver for the big 2SC5200 transistor... so probably a little too weak for it.
                        /edit
                        Correct, I also checked the traces and they are connected. There is a big resistor R83 56K 1W that could also generate a considerable amount of heat making things worse for Q51 and Q56. What if I unsolder it and solder it from the other side?
                        Or else, solder Q51 and Q56 from the other side of the PCB and make them touch the external heatsink of the subwoofer? Is this crazy enough?
                        The external heatsink I am talking about is this:
                        https://www.badcaps.net/forum/attach...3&d=1642379917
                        Look at this pic:
                        https://www.badcaps.net/forum/attach...5&d=1642457707
                        The transistor in the middle, Q43 2N5551 was originally mounted to the heatsink with thermal paste. They didn't use any enforcing method other than its legs though. If I understood correct, this transistor should be touching the heatsink to provide some type of thermal feedback to the driving circuit for the main transistors to avoid burning them, or something like that.
                        So, why not try to do the same with Q51 and Q56? Solder them on the other side of the PCB, apply some thermal paste, then screw board trying to get them to make contact with the heatsink?
                        Just finished reading the entire thread, thanks for the reference!
                        Teribble design though. If you check the buying trends in audio forum, youtube etc you will see everyone pushing people to buy active speakers/monitors.
                        Active vs powered:
                        Powered is just speaker system with integrated amp while active means different amplifier for twitter and different amp for woofer. And also active crossover before the amps and also heavy tweaking with DSP etc.
                        That way they say that you get the perfect pairing of amps/speakers and the amps are specifically designed for the speakers, taking into acount the cabinet, etc
                        I have no knowledge to question any of the above claims.
                        My view on this though is that this is the perfect plan to turn speakers into comsumer products with expiration date, just as like all the other stuff (TVs, laptops, monitors, Bluetooth speakers, soundbars, smartphones, wireless earpads etc). The integrated amp(s) will last at best a couple of years, long enough to pass warranty period and then randomly die. But a passive speaker from a reputable manufacturer and rubber foam suspension can easily last for 10 years or even more....
                        I found pictures from the internet of the exact same model and the main caps were of lower capacitance, 10000uF. So, I guess that 10.000uF probably would be enough.
                        Checked my caps stock and unfortunately the only caps I have that are 63V are 2x15000uF and 2x18000uF. And those were really expensive, about 8-10€ each. I am not wasting those caps on this unit.
                        edit: Also found 2x Elna Audio caps 7500uF 56V from a Kenwood 90s amp that has blown output transistors. But 7500uF is quite low for 150rms.
                        All transistors are TO-92 except 2 transistors: D667C and B647C, those are TO-92 Mod.
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          Exactly
                          Precisely.
                          Now, we know that 1 of the 2 failed transistors, Q56, is part of the pre-drive circuit of the main large complementary transistors 1943 and 5200.
                          You are right, that was necessary and I failed to do it. I will try to add on the next version of schematic.
                          It goes to the collector pin of both Q45 and Q46 S9014 that one of them was found bad and the other affected too and replaced both. These are the ones with red and yellow color, located near relay:
                          https://www.badcaps.net/forum/attach...0&d=1642457707
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8703
                            At 150W you're passing around 30-odd amps or so during the peaks.
                            The current gain of final transistors passing this much current drops down to around 10, so the base current will be around 2-3 amps.
                            This is way too much for a TO-92, so yes you probably should upgrade to TO-126 or TO-220 transistors, but other mods might be needed upstream.
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              done
                              Please check the new version of schematic attached bellow.
                              Please check schematic, I added the rest of this circuit at last.
                              Now, that we have the circuit of Q45 and Q46 complete, can we expain why Q45 and Q46 failed?
                              The area has no PCB discoloration implying overheating or parts like big wattage resistor next to the failed transistors. So, why they failed? They also don't appear to be connected to the other part that was found failed, Q56...
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8703
                                okay... now that Q44-Q46,Q55 circuit looks more like protection and integrated anti-thump. The two weak/bad transistors appear to be the protection portion but if the schematic is correct they shouldn't be very stressed under normal situations (i.e. if the PO transistors didn't die) ... but what are the values of R92 and R102?
                                • goodpsusearch
                                  • Oct 2009
                                  • 2850
                                  • Greece
                                  R102 1Kohm
                                  R92 27kohm
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8703
                                    Only thing I can think of at this point is voltage rating. Try a mps a43 or something like that...
                                    • goodpsusearch
                                      • Oct 2009
                                      • 2850
                                      • Greece
                                      Finally found the time to finish this!
                                      The subwoofer is perfectly working and can get really loud. It's nothing like the mediocre Yamaha YST-SW030 that I fixed in another thread. This thing can really shake the house
                                      Here is the schematic with some comments about changes I made:
                                      https://www.badcaps.net/forum/attach...1&d=1645390601
                                      Replaced R201 , 2.2kohm, with same value, 1watt resistor.
                                      I could do the same and replace R61 that is 330ohm, 1 watt with 2watt resistor but I just tried to move it far from the nearby caps.
                                      If you check the pics, you might notice that I tried to do this with every component that generates some heat: move it away from capacitors or other hot components that would make it get more hot and even fail.
                                      Changed C67 10uF 50V with 22uF to lower the ripple of the power supply of the anti-thump/protection circuit.
                                      The 2x 25V 47uF caps located on the preamplifier board were upgraded to 2x 100uF Rubycon YXF. This might increase audio quality.
                                      https://www.badcaps.net/forum/attach...7&d=1645390461
                                      https://www.badcaps.net/forum/attach...9&d=1645390461
                                      I left unchanged the 2 transistors S8050 , S8550 that drop down the 50V and -50V voltages for the vcc of the preamplifier board but I bent them to be as far away as possible from PCB.
                                      https://www.badcaps.net/forum/attach...1&d=1645390461
                                      I also upgraded 220uF 35V caps with 470uF 35V on that circuit.
                                      I soldered 2 pre-driver transistors from the other side of the PCB and attached them on the heatsink with generous amount of thermal paste
                                      I think the best fix would be to replace them with equivalent TO-126 parts but I didn't know how to easily find TO-126 transistors with exactly the same characteristics.
                                      D667C and B647C, possibly part of driver circuit of amp normally should have been replaced with TO-126 equivalents too but were left unchanged for the same reason as above.
                                      All the capacitors were replaced with Japanese caps of low ESR series, 105C (hopefully not too low ESR to cause issues).
                                      2x 12000uF 50V were left unchanged due to high cost
                                      I should note that all of the original caps that I removed were tested with ESR micro and Chinese component tester and I found that some of them had started going high ESR and somehow high V leakage.
                                      I also redid every solder connection and I applied large amounts of solder and created ugly solder balls to help with the overheating of the big wattage resistors and transistors.
                                      I also replaced the terribly thin AWG28 cables used to transfer the audio signal from the preamp board to the main amp board and banana plugs board to the preamp board. I used AWG24 speaker cable from some cheap Philips speakers that were part from a 90s mini Hi Fi system from Philips . If I ever need to use those cheap Philips 2 way speakers I will use some heavier wire, because I think AWG24 is too thin for speaker cables, but perfectly fine for interconnect cable.
                                      The AWG28 cables used to power LED and preamplifier board were left unchanged.
                                      Last, I tried to thermally couple the amp heatsink with the metal cover of the sub applying tons of used thermal paste that I recovered from other projects
                                      So, what do you think?
                                      I would love to get your feedback
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        Nice!
                                        Glad to hear you got it working properly now.
                                        No surprise there.
                                        Looking at the magnet of the woofer driver, it has a pretty chunky magnet. That's pretty much the #1 thing needed for a good woofer to go down very low in frequency. The other thing is the box, of course. If tuned properly, it should be able to hit 25-30 Hz easily... which is what would give it that earthquake rumbling sound when it needs to go very low.
                                        Cool, it's great that you made this. Now anyone who may have this subwoofer can actually have a schematic for a reference.
                                        But man... again this reminds me so much of the JBL speakers I pointed to in the previous posts. In particular, it's the circuit around the speaker protection & LED. I'm just trying to "wrap my mind" around it of how it all works. Seems like a lot of questionable decisions were made there.
                                        Was that resistor running hot? It seems like it feeds nothing else except for the LED (when it's ON)... though through doing some very quick & rough calculations, it's possible it may be dissipating up to 0.33 Watts (1/3W) when the sub is On... which if the original resistor was rated for 1/2W, then I can see it getting a bit hot. 1W definitely sounds safer.
                                        I did that to the JBL speakers - replaced the 330 Ohm resistor in series with the relay with same value, but 5W resistor, IIRC. In my case, the relay was 12V, and it was fed from the 30V rail... so the resistor was dropping ~18V, which equates to ~1 Watt of power dissipation. The 2W used originally was getting quite toasty.
                                        As for your Roister PB-150 circuit, I tried to do some calculations, but it doesn't quite add up. Assuming stable 50V DC comes out before R61 and the relay pulls down R61 on the other side to 24V level, then R61 will have approximately 26V across it, dissipating a little over 2 Watts! But I don't think that's the case, though, or you would have seen a charred resistor. I'm thinking more along the lines that perhaps the relay coil is getting a bit "over-driven" - possibly up to 30V. This should leave only 20V across R61, dropping P_d to 1.2 Watts... which honestly is still a lot. So perhaps it could be over-driven even further? Or perhaps the 10 uF capacitor isn't enough to provide a steady 50V DC, and that further lowers the overall DC voltage? Whichever way I look at it, though, it's honestly a mystery/mess to me. There really ought to be better ways to design that circuit and not use many/more/pricier parts.
                                        Good!
                                        That's actually for the relay's coil supply and LED.
                                        Keep an eye on it after running the amp for a while. Higher capacitance could mean more stable (and thus higher) DC voltage... which may or may not increase the heat given off by R61... though at 22 uF, it's probably still not big enough to matter.
                                        These two caps filter the +/-15V rails for the pre-amps... so if anything, this should further decrease any line hum from going to the pre-amps. It may or may not bring noticeable results, depending on if the old 47 uF caps were enough for the filtering task or not (probably OK, given the +/-15V rails are linearly-regulated.) But the extra capacitance doesn't hurt here, so the upgrade is a good thing.
                                        That's fine.
                                        If they're not running hot enough to darken the PCB, then they probably aren't dissipating too much heat. The 1 KOhm 1W resistors before them (R94 and R95) likely help a good deal with voltage drop before the transistors. And probably the pre-amp board doesn't use much power.
                                        Anything helps at this point.
                                        You'd have to draw a schematic of the output stage and pre-driver stage, then maybe compare it with circuits from other amplifiers. It's probably using a Sziklai pair configuration on the output, like many other amps are. So you may be able to copy-pasta the design of another amplifier (or at least use the biasing/resistor values to get an idea of what you might need to modify.)
                                        But hey, if the subwoofer isn't burning out when you're cranking it up hard, then I guess let it be.
                                        Nah, it's an audio amplifier, it won't matter. You can even use polymers and it probably won't care. Just good luck finding any 50V-rated polymers... or at that high of a capacity.
                                        That aside, you may want to glue some of the larger caps down (or ones with very long leads), because the vibration from the subwoofer may eventually damage their seals on the bottom. Probably won't happen in many years if at all, since you used Japanese caps... but generally, it's a good idea to glue down any heavy components in a subwoofer amp, due to the vibration. Regular household/bathroom silicone should be OK to use if kept away from metal pins and parts, due to being slightly corrosive while it cures. For places where you have to glue over metal parts, there are non-corrosive silicones for electronics... or just plain hot glue.
                                        Not surprising. Cheap cap brands are cheap for a reason. :\
                                        Excellent!
                                        That actually should help with the power dissipation quite a bit.
                                        And yes, I -never- throw away recovered thermal paste, unless it's completely dry.
                                        That's what I was thinking as well. If it was a P_d issue, we likely would have seen it in the form of darkened PCB around the transistor... unless it all happens very quickly during the On/Off cycle of the amplifier while the speaker protection is engaged / relay coil dis-engaged.
                                        However, I'm also not quite sure how it can be a voltage issue.
                                        Let's assume worst case here: either the 2SA1943 or 2SC5200 is fully conducting (but not both at the same time) when the output stage is getting biased. This would be / could be sending either full +50V or -50V to one side of R92. But Since R92 forms a voltage divider with R102, that should limit the voltage to about 1.786V (without the transistors in the circuit.) With Q45 Emitter terminal grounded and Base connected to other side of R92, though, really R92 becomes more of a current-limiting resistor for the Base of Q45... and that current should be less than 1.85 mA... which again, I don't think would be enough to cause damage. And the Collectors of the Q45 and Q46 should also be fairly protected, since the 47 uF 63V cap that sets the delay for when the relay turns On, will be discharged. Therefore at power up, Q45 and Q46 Collectors should be at 0V. Perhaps only if the Base voltage of Q44 is somehow allowed to float above 50V, this could then be an issue, given that the Emitter of Q46 is tied to ground with a 150 KOhm resistor (and also a diode or Zener diode to the Base of Q55? )
                                        So I was thinking of another possibility. The PCB construction (particularly the "random" appearance/selection of the resistors) reminds me of ultra-cheap pre-made PCBs/circuits from China (and elsewhere), perhaps the manufacturer just bought the cheapest parts online... so possibly some counterfeit transistors? Now, the outputs may be genuine (or at least decent quality parts), but perhaps these smaller TO-92 transistor were not. That could explain the random failure of Q45 and Q46 without any discoloration around them.
                                        Time should tell, though. Hopefully the amp will stay fixed. If it does, I would honestly just suspect dodgy/fake/counterfeit transistors from China were the culprit.
                                        This is why I prefer to use salvaged parts when not going with verified stuff from Digikey or Mouser. Even cheapo PSUs tend to have somewhat more reliable source of parts (except of course, the really really bottom-dollar garbage PSUs.)
                                        • rustinjust
                                          Please help, subwoofer connected to tv, read description below
                                          by rustinjust
                                          I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                                          Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                          Is there a way of...
                                          10-28-2023, 07:09 AM
                                        • rustinjust
                                          Please help, where can I get a remote for my subwoofer?
                                          by rustinjust
                                          I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                          Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                          Is there...
                                          10-28-2023, 03:43 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • Delicieuxz
                                          I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
                                          by Delicieuxz
                                          I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
                                          Here's an audio clip of the sound coming from my speakers:
                                          https://vocaroo.com/16HaryHwTx78
                                          I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
                                          11-15-2023, 09:50 PM
                                        • Xan03
                                          Klipsch Promedia 2.1 rhythmic subwoofer "pulsing" during standby
                                          by Xan03
                                          I have this 2.1 Klipsch set where the subwoofer emits a constant whine in standby, in addition to a constant rhythmic pulsing/thumping. Only way to make it stop is to cut power. I think this thread mentions the same issue, though my set is not a BT one: https://community.klipsch.com/index....-bt-subwoofer/
                                          I think all this Klipsch gear is using crappy capacitors. Is it worth trying to replace the caps in the subwoofer amp to make this go away?
                                          11-17-2024, 06:54 AM
