Dell Inspiron 3481 (EDI72 LA-G714P) Powers with charger blinking code
  • Umadbro
    • Jul 2018
    • 65
    • Portugal
    Hi, I've been given this laptop which upon plugging the charger it produces a blinking code, and it goes as follows:
    "3 AMBER, 5 WHITE"
    Pressing the Power Button, the machine seems to power up, as the fan spins (at a normal rate), but after a few seconds the power cuts off, and the cycle repeats.
    Searching on Google for the blinking code for this device doesn't return any valuable information. The code is not listed on the service manual. However, I found out that for others or similar models "3 AMBER, 5 WHITE" blinking code means ''POWER RAIL FAILURE". I am going to use a schematic I found to test some power rails, as casual probing for a short didn't show any major problem with the board.
    I also read that the problem may be correlated with an EC power controller issue, so I went ahead and did a few dumps on the W25Q128JV ic, but every dump was different from the previous one once compared using HxD. I cannot tell why this is, I tried different USB ports/laptops always with the same result.
    In the meantime, I found a second ic on the motherboard where I'm sure the EC information is stored. Later today I am going to make a few dumps and add them to the post. The name of the ic is APL5934D.
    I don't believe that the issue is power related, as the machine is not at all old and has very few to no marks of wearing, so I would like an opinion about the dumps I made and the error the machine produces before proceeding deep into motherboard repair. I am attaching the files I have now and later I will try to get the other ic readings. Please let me know of any other information I should provide.
  • Umadbro
    • Jul 2018
    • 65
    • Portugal
    Re: Dell Inspiron 3481 (EDI72 LA-G714P) Powers with charger blinking code
    It seems I am most likely wrong about the other ic. It has nothing to do with the issue.
    I tried to get new dumps on the Winbond ic, with the same result, every reading is different.
      • 21948
      When you get a good bios dump post it in the "Bios Requests ONLY!" section -
      https://www.badcaps.net/forum/forumdisplay.php?f=40
      What bios programmer are you using,and the software version.Are you using a clip .Are you using auto detection or manually choosing it from the part number on top of the chip
      • Umadbro
        • Jul 2018
        • 65
        • Portugal
        Hi. I managed to get multiple dumps that match each other. But to answer your question, my programmer is "CH341A minProgrammer", the software I'm using is "Ch341a Programmer V2.2.0.10". I used auto detection which gave me 3 options, I chose according to the ic I have.
        I solved the issue by removing the cover I put on leg 4 of the programmer. For some reason on my first use, this programmer wouldn't detect the flash, and the solution ended up to be covering leg 4 (gnd), after that, it detected many other ics, so I ust left it there. This times it seems it wasn't letting the reading being done propperly.
        I am happy to post my results on "Bios Requests ONLY!", but as I am not sure if the issue lies here, I thought it would be best to create a new topic to diagnose the issue.
        • Umadbro
          • Jul 2018
          • 65
          • Portugal
          Am I doing it wrong? Should I create a new thread or find one of the same motherboards and issue to post my interest?
          I don't want to place it in the wrong spot or hang to another post when I shouldn't, but I just did that over at:
          https://www.badcaps.net/forum/showth...68#post1100168
          Please let me know the right way so I won't cause problems.
            • 21948
            you have posted it in the right place,don`t worry, someone ill try to fix it for you.
            • Umadbro
              • Jul 2018
              • 65
              • Portugal
              thank you
              • motormayhem
                Lenovo T460 Only Charges on One Charger
                by motormayhem
                Laptop Question
                I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                05-12-2023, 01:46 PM
                DELL Inspiron 3481 Notebook 3000 Specification for Upgrade or Repair
                This specification for the DELL Inspiron 3481 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3481 boardview and 3481 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 3481...
                09-06-2024, 12:36 PM
