Dell 330W AC/DC Adapter XM3C3
  • wrand003
    • Dec 2021
    • 6
    Help!
    I am trying to repair my Alienware M18r1 AC/DC power adapter. It is currently putting out 34V DC when it is supposed to put out 19.5V. This is preventing the battery from charging because it is triggering the safety protection. It is also causing it to throttle the processor performance. The adapter information is as follows:
    Dell P/N: XM3C3
    REF. NO.: ADP-330AB B
    MODEL: DA330PM111
    I believe the problem is with the below pictured regulators. The one with the markings "ZP" I have identified as a Central Semiconductor CMDZ16L but the one located at D136 is burnt so bad I cannot make out the markings. I am trying to locate a schematic for the adapter to confirm this. Any assistance is greatly appreciated.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8286
    Re: Dell 330W AC/DC Adapter XM3C3
    Kinda hard to believe that you are getting 34V out of a 19.5V, 16.9A switching PSU. I doubt the output caps are rated that high. Plus the OV protection circuit should kick in too.
    Let’s say it doesn’t have any protection at all… still it would mean the gate drive circuit to the FET on the primary side is going full bore without any regulation from the feedback. Even then I don’t think you get 34V out of it.
    Check your battery in your DMM and measure your PSU at the barrel connector again.
    • wrand003
      • Dec 2021
      • 6
      Checked it again with new batteries still the same output from 34.85 to 34.88V DC pretty stable at these readings. If there is something else you would like to see just let me know and I will post it here. I am open to checking anything and everything at this point.
      Picture attached.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8286
        Man, that’s interesting!
        Attach some straight shot high resolution pictures from top and bottom of the PSU, so we can see something.
        • petehall347
          • Jan 2015
          • 4429
          • United Kingdom
          if you can find datasheet for ic139 it might have a suggested circuit .
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Concur. That would be a good start. Also remove diode D136 - its case looks cracked and blown. Remove the "ZP" diode too, if it shows shorted. Check if the resistor next to it has gone open-circuit.
            • R_J
              • Jun 2012
              • 9579
              IC139 is just a dual op-amp, D136 is likely a schottky diode of a few amps, I see another spot that has a zener and it is listed as ZD (ZD32), so D136 is not likely to be a zener.
              IC140 looks like a TS391ILT
              It may be helpful to post pictures of both sides of the complete board.
              • wrand003
                • Dec 2021
                • 6
                It took forever to get the white adhesive off the pcb, but here is the photos. There is still more white adhesive on the reverse side but here is photos of what I have so far.
                • wrand003
                  • Dec 2021
                  • 6
                  Also, D136 is OL as well as the ZP diod. The resistor next to the ZP still reads good at 500 ohms.
                  • R_J
                    • Jun 2012
                    • 9579
                    I would guess D136 was a T4 1N4148W, but that is a very complex circuit so there may be more wrong than a couple diodes.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8286
                      Is the power cable from the brick to the laptop in good shape? Maybe worth unsoldering and checking the power again on the brick. To me that brick should shut down. Look at the brown output capacitor rating.
