Sharp LC-70UD1U Half screen Normal half screen is white
  • Megan0
    • Aug 2021
    • 28
    • united state
    My Sharp LC-70UD1U Screen is black and flashing, "I attached the video"
    Well, I opened the back cover and as you can see in the picture, I unplugged 2 L (left) ribbon, TV turned ON, but half of screen (Right) is normal, and the other side (Left) is white. I continued to test...
    Result:
    I swapped the ribbons L<-->R = Blinking 2x power light, 5x timer light
    Unplugged 2 R Plug 2 L = Blinking 2x power light, 5x timer light
    Unplugged 2 L Plug 2 R = Blinking 2x power light, 5x timer light
    Only in the first test, where I did not change the ribbons, when I unplugged 2 ribbons on the left, half of the image is normal, and the other side (unplugged side) is white.
    Does anyone have any solution?
    https://youtu.be/JOXMDMceFhU
    https://flic.kr/p/2mXXbTH
    https://flic.kr/p/2mXWEQ9
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Re: Sharp LC-70UD1U Half screen Normal half screen is white
    Result:
    Usually when we see this we find there are burnt/overheated gate driver ICs on one side of the screen. If by "right" and "left" side you are referring to right and left when looking at the back side of the TV it appears the problem side is upon the right, as in when the right side FFC's are attached and the left side isn't the TV goes in to protection mode and displays the "2-5" error code, but when the left side FFCs are attached a picture appears on that side and the right side is white?
    EDIT/ADD: Look at the terminals on both sides of the FFCS where they plug in to the timing control board and the source driver boards. Are any of the terminals crossed, or have any of them lifted from the substrate?
    They call me......."threadkiller"
    • Megan0
      • Aug 2021
      • 28
      • united state
      Yes, When I attached the [R Ribbons] R side of the screen is normal, but if connect [L Ribbons] it goes to "2-5" error code. even I just attached [L ribbons] alone but it goes to "2-5" error code.
      I checked all of the connector I think these are fine.
      • Megan0
        • Aug 2021
        • 28
        • united state
        Update: I swapped two Flex cables from white side to normal side, and I realized one one the cable has issue, when I attached the screen wasn't normal, screen was like horizontal colorful lines.
        I don't know what I should to do, could it be from Tcon board or flex cable? or something else?
        • nomoresonys
          • 12284
          • U.S.
          Inspect the lvds cable to the tcon and ribbon cable ends going into tcon, make sure there's no damage to the contacts. Make sure they are inserted perfectly even and lined up, can clean them gently with iso alcohol and a qtip. If still no joy, I would try the "tape-cutoff" method, plenty of threads here about it, mostly you block 3 or 4 signals on the end of the ribbon cable going to tcon on bad side of panel with tape.
          • nomoresonys
            • 12284
            • U.S.
            If you have easy access to the long buffer board between tcon and panel, you could check the little ceramic capacitors for shorts or very low ohms, I would expect them to be over 100 ohms.
            • Megan0
              • Aug 2021
              • 28
              • united state
              I will, I found the broken flex cable, but I think it's a little bit tricky and need experience to fix it with "tape-cutoff" method.
              for second test could you tell me which capacitor I should check with ohmmeter.
              https://flic.kr/p/2mYaSsp
              https://flic.kr/p/2mY4ec7
              • nomoresonys
                • 12284
                • U.S.
                Tape method there, he goes into some detail but it's usually just cover 3 or 4 lines on one end or the other: https://www.youtube.com/watch?v=tCknTVbZ3I8
                • nomoresonys
                  • 12284
                  • U.S.
                  Checking caps there, plenty more videos about it on youtube also: https://www.youtube.com/watch?v=jLd6QO7Z7m4
                  • kca
                    by kca
                    Hello all ~
                    08-31-2025, 06:38 AM
                  • EazyBone
                    Sharp LC-65Q620U White Screen
                    by EazyBone
                    Another TV topic!!
                    I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                    The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                    Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                    08-21-2024, 12:56 PM
                  • Raulnn
                    TD Systems K50DLG12US half black and half white screen
                    by Raulnn
                    good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                    By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                    01-20-2024, 04:49 PM
                  • harp
                    White screen repairs
                    by harp
                    To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                    Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                    On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                    05-13-2024, 03:43 AM
                  • odi
                    Sharp E50E41NKFMBXNNX white screen
                    by odi
                    I'm trying to fix this TV that I got from a friend. It displays a white screen only. What is weird though is that when I first turned it on it appeared to work for a few minutes but then got the white screen and I haven't got the picture back even for a second after that initial time. If I plug in an HDMI device, the audio is played through the TV speakers, and the power button turns the TV on and off.
                    I've tested the caps on the power supply with an ESR meter while in circuit they seemed within spec.
                    Tried wiggling the LVDS while on and no change to the white screen. Have removed...
                    01-31-2022, 03:29 PM
