Digihome 50551UHDS display sync
  • stav242
    • Jan 2014
    • 61
    • United Kingdom
    50" Digihome 50551UHDS
    Pwb :17IPS72
    Mb: vestel 17MB130S 23592996
    Panel :VES500QNDC-2D-N41
    I've replaced the above mB with a near identical one (best I can find). 17MB130S 23665848, was quoted as being from same model 50".
    Picture is out of sync.
    Could it need reconfiguring to this particular panel? Or is this a tcon/cable fault?
    note: this is the second replacement board i have tried, first one was also same model but slightly different serial. same picture out of sync.
    update : unplugging the tcon > panel cables result in only half the screen with same symptoms - on bothsides - im thinking it tcon or firmware. ..?
  • nomoresonys
    • 12306
    • U.S.
    Re: Digihome 50551UHDS display sync
    Yes does seems like a tcon issue.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Maybe timing issues. Might try blocking clk traces on one side.
      • stav242
        • Jan 2014
        • 61
        • United Kingdom
        I tried removing each of the ribbon cables to the panel, the problem exists which ever cable is plugged in. So points to tcon issue .. have ordered a replacement.
        • dskall
          • Oct 2016
          • 2905
          • usa
          Your right missed that part.
          • stav242
            • Jan 2014
            • 61
            • United Kingdom
            replaced Tcon, no change.
            now have 2x working Mbs and 2x working TCons... but display is still out of sync.
            are there any service menu type setting i need to check/change ?
            • stav242
              • Jan 2014
              • 61
              • United Kingdom
              its a Vestel 17MB130S main board.
              i tried searching on the vestelservice.com - but cant find my 50" Digihome with MB130S model listed ?
              does anyone know where i can get the panel/timing profiles for this model ?
              • Diah
                • Feb 2013
                • 6497
                for me at least Panel damaged .. take out bezel and with loop check a round end the panel sides.. small point breaking to great discharge fault
                • ducky29
                  • Dec 2015
                  • 369
                  • Europe
                  I still think thats its not a faulty screen nor a faulty tcon. Your mainboard replacement its not compatible with the screen.
                  • yokoono
                    • Apr 2010
                    • 510
                    You will need the panel profile. I have for N11 not N41. It deserves a try. Do you know the installation procedure?
                    L.E. Type on the MENU 4725 remote control and see which panel the motherboard worked with.
                    • nomoresonys
                      • 12306
                      • U.S.
                      Had a picture recently that was grainy like that, was one loose tab bond, shimmed it up and got good picture back, the one you have there would be harder and maybe not even possible? since there's practically no bezel to work with, if that is the issue, suppose it could be a component problem on the panel driver board.
                      • nomoresonys
                        • 12306
                        • U.S.
                        So you have exact same issue with either mainboard or tcon? maybe try go around the bezel NOT the screen and give it a squeeze, see if picture changes any.
                        • stav242
                          • Jan 2014
                          • 61
                          • United Kingdom
                          connected only 1 of the panel connection to TCON and still get the same image, and same if i swap over to the other connector. so would imply the signal going to both sides of the screen -independantly is distorted. that would imply that the screen is ok wouldnt it ? as i say, tcon and MNb have been swapped. which leads me down the panel profile route.
                          attached a photo of the service menu and screen product label - its hard to read the menu due to the distortion.
                          panel is VES500QNDC-2D-N41
                          i can make out ....TN41J_2DUHD
                          anyone figure out if these are matching or if it needs an update ?
                          where can i find the panel profile for my N41 model ?
                          • stav242
                            • Jan 2014
                            • 61
                            • United Kingdom
                            can you give me the installation procedure to try ?
                            • yokoono
                              • Apr 2010
                              • 510
                              It is clear that the motherboard purchased worked with a different type of panel. The panel is good. With the correct panel profile the problem can be solved. Unfortunately, I do not have the profile for N41. What I posted above. Installation is done with stick (files placed in PQ folder) / menu / 4725 / usb operations / ok / exit / tv off.
                              L.E.
                              1. Format a stick with FT32 (2,4,8 Gb)
                              2. Create a folder called PQ on the stick
                              3. Unzip the software (#10) and put files (PNL+TMG) in the pq folder
                              4. Turn on the TV and insert the USB stick
                              5. Type Menu, 4725, scroll down to USB Operations, type OK, and wait 5 seconds.
                              6. Exit the menu and turn off the TV
                              7. For safety, unplug the TV until the stby LED goes out
                              8. Remove the stick and turn on the TV. It has to start with the right image.
                              • stav242
                                • Jan 2014
                                • 61
                                • United Kingdom
                                Re: Digihome 50551UHDS display sync (FIXED)
                                L.E.
                                its fixed! your a star. ..thanks so much.
                                was trying with those files on the root and in a profiles folder. never knew about the PQ folder.
                                is there some secret list of what folders and files are needed to update various settings ?
                                • nomoresonys
                                  • 12306
                                  • U.S.
                                  So profile N11 worked for your tv?
                                  • yokoono
                                    • Apr 2010
                                    • 510
                                    On the stick create a folder called downloadprofile.mb130 Follow steps 4,5,6,7,8. On the stick will be saved some files that you can use on another occasion.
                                    To save the panel profile from tv the folder is renamed downloadpq.mb130
                                    Copying is done separately, not with the 2 folders simultaneously.
                                    • stav242
                                      • Jan 2014
                                      • 61
                                      • United Kingdom
                                      fixed it... used the timing file from your download for the 50" and the panel file from the backup i took before i started...
                                      now its working retested onthe same youtube vidoes - all looking good now.
                                      attached the ones im using if this helps anyone in the future.
                                      • kca
                                        by kca
                                        Hello all ~
                                        08-31-2025, 06:38 AM
                                      • x_orange90_x
                                        TCL 50S535 bad tcon or panel issue?
                                        by x_orange90_x
                                        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                        03-29-2025, 11:02 PM
                                      • advant
                                        by advant
                                        02-03-2020, 12:25 AM
                                      • Hakuu
                                        by Hakuu
                                        Hi There,
                                        More Details
                                        TV Model - LG OLED77G1PUA
                                        07-12-2023, 02:37 PM
                                      • netgearnetgear
                                        TCL 43S423 TCON OR PANEL FAULTY???
                                        by netgearnetgear
                                        Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                        08-20-2025, 06:04 PM
