Vizio TV E470VL SMPS Flucuation Output Voltage
  • dholley
    Mr. Blinky
    • Jan 2022
    • 87
    Would someone please help troubleshoot a Vizio 47" TV Switch Mode Power Supply with 5 volt output fluctuating voltage. The voltage fluctuates at 5 the volt output and at the Pulse Switch Modulating IC at VCC. I have the following notes:
    1. The 3 main filter caps all have approximately 167 volts steady
    2. I have replaced 4 mosfets next to what I think is called the inventor transformer (big black transformer) pictures attached
    3. I have replaced Fuse F102 with an equivalent
    4. I have check all diodes and caps and they seem to be ok
    5. I replaced the 431 chip at U201
    Pictures attached for reference
    thank you for your help!!
    • 31265
    Re: Vizio TV SMPS Flucuation Output Voltage
    opto isolator(s)
    feedback sets the output, if the feedback is screwed then the output will be screwed.
    • R_J
      • Jun 2012
      • 9610
      Is F102 the main fuse? was it open (blown)?
      Have you tried replacing C104 & C105?
      • dholley
        Mr. Blinky
        • Jan 2022
        • 87
        F102 is not the main fuse. It was open. It is near one of the big filter capacitors, C809.
        My ESR meter shows C104 & C105 to be ok. Should I test with capacitance meter?
        • nomoresonys
          • 12312
          • U.S.
          Touch up some of those solder joints.
          • R_J
            • Jun 2012
            • 9610
            Ok, I see which fuse it is, What voltage do you get on the 12 volt output? It is supplied by the same transformer so maybe it is loaded down and effecting the +5 volts as well.
            • dholley
              Mr. Blinky
              • Jan 2022
              • 87
              I don’t think it is on. Can you tell me how to jump the pins to turn it on or is there another place I can measure that will accommodate your request?
              • R_J
                • Jun 2012
                • 9610
                It is hard to trace the circuit using pictures, I will guess there is a transistor that switches the +12 volts, likely the to220 next to C201.
                It would seem ic101 is shutting down, what is the number on ic101?
                The pin to turn on the power supply seems to be STANDBY, but I don't know if it needs to be grounded or taken to +5v with a 1k resistor.
                The ON/OFF pin seems to be for the backlight circuit
                • dholley
                  Mr. Blinky
                  • Jan 2022
                  • 87
                  I just measured, there is NO 5 volt or 12 output. The 5 volt was fluctuating from 3 to 4 volts but is now 0 volts. The big capacitors were at 167 volts they are now at 171 volts. I don’t know what happened.
                  • dholley
                    Mr. Blinky
                    • Jan 2022
                    • 87
                    When say Ic101, do you mean U101? If yes that is the pulse modulating chip. 00465R
                    • R_J
                      • Jun 2012
                      • 9610
                      Did that fuse you installed go open again? Yes that should have been U101, I think that is FSQ0465R
                      • dholley
                        Mr. Blinky
                        • Jan 2022
                        • 87
                        The fuse is good. I think you are correct Q0465R
                        • R_J
                          • Jun 2012
                          • 9610
                          If you have 165vdc on u101, pin 1 (drain) I suspect the ic is bad
                          • dholley
                            Mr. Blinky
                            • Jan 2022
                            • 87
                            Using a big cap for negative, red lead of multimeter to pin one of the IC, there is a huge fluctuation anywhere from 34 to 151 volts
                            • dholley
                              Mr. Blinky
                              • Jan 2022
                              • 87
                              I had the multi meter set incorrectly, the voltage is 170.1 volts
                              • R_J
                                • Jun 2012
                                • 9610
                                Check the u101 vcc voltage, if 0 check that zd104 zener diode is not shorted, Also check that R105 is not open
                                • dholley
                                  Mr. Blinky
                                  • Jan 2022
                                  • 87
                                  It is a fuseable resistor at 0.10 ohms. Did You see my previous post 170.1 volts at the drain?
                                  • R_J
                                    • Jun 2012
                                    • 9610
                                    I edited my post after seeing yours
                                    You can check the voltage one each side of R102 (using hot ground, main cap negative) one side will be 165vdc the other side will be the ic's str voltage that supplies the internal vcc startup cell, this needs to be above +12vdc and usually around 20vdc
                                    • dholley
                                      Mr. Blinky
                                      • Jan 2022
                                      • 87
                                      VCC Fluctuates between 9 and 11 volts, zd104 is not shorted, r105 is not open testing in circuit
                                      • R_J
                                        • Jun 2012
                                        • 9610
                                        This tells me the ic is supplying the startup vcc but T201 is not supplying the run voltage.
                                        Check the voltage On D102 cathode, that should be around 20v
                                        • electron_jj
                                          Panasonic TH-L42D25A checking the PSU output voltage
                                          by electron_jj
                                          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                          08-29-2021, 08:13 AM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • David Miteff
                                          NM-D521 rev. 2.0 output voltage on CPU coils seemingly low
                                          by David Miteff
                                          Hello, guys!
                                          As the title says - the board is NM-D521, on the input of the CPU coils I read 1.2-1.3V, which should be normal, but on the output I read around 0.6-0.8V. The laptop bootloops with no picture.
                                          As of right now I don't have a thermal camera, so I can't confirm a shorted or partially shorted CPU chip. Do you have any other suggestions as of why the output voltage might drop like that?...
                                          12-30-2024, 07:02 AM
                                          MT3608 Step-Up Converter IC Datasheet
                                          The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                                          Internal soft-start results in small inrush current and extends battery life.
                                          The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                                          10-07-2024, 05:02 AM
                                        • Ri5ux
                                          Playstation 5 2 Second BLOD, F3501 Voltage Output Question
                                          by Ri5ux
                                          Hi there, just wondering if anyone out there who has a semi-working or working PS5 board could check the output voltage on F3501's buck converter for me, with and without power. I have 12V on the input, fuse not blown, no output voltage on that IC, with or without power, and no shorts present.
                                          Symptom: 2 Second BLOD
                                          Testing: All other rails seem present. APU, SSD, South Bridge, and RAM confirmed to be powering up using a thermal camera. Monitoring the current draw of the 12v rail shows a somewhat normal boot cycle of the south bridge. Jumps up to 300ma, and down to 0....
                                          09-09-2023, 06:57 PM
