DVR camera recorder switching power supply capacitor failure really
    • Jul 2011
    • 6057
    These cheap non brand capacitors at it again
    Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
    Well at least I have the cameras back on line I to try the hard drive tomorrow and see if it got damaged as well
    One note the cameras are on a medical grade switching power supply by themselves because when I first put in this system I continuously had switching power supply failure on the cameras and had to replace several cameras and switching power supply of because of switching power supply failure
    All I can say good about this DVR camera recorder and switching power supply is that this has lasted about 6 years so I guess I really should not complain to much about it
    I will post some pictures of the switching power supply before I put heat shrink tubing on it to keep it together and after I try the hard drive to see if it still work
  • R_J
    • Jun 2012
    • 9578
    Re: DVR camera recorder switching power supply capacitor failure really
    6 years = 52,594.92 Hours, I would say that cap had a full life
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      6 years POH or 6 years sitting in the closet?
        • Jul 2011
        • 6057
        Yeah it even keeps trying to restart which is really weird even with the capacitors being at over 40 ohm ESR reading because the power supply light pulsing very quickly on and off on the DVR camera recorder
          • Jul 2011
          • 6057
          Well is has been running scene last night and so far so good I am supposedly going on vacation next week but not this Monday but next Monday and then I will test the hard drive and if still good will put it all back together and call it repaired
            by sam_sam_sam
            07-01-2024, 06:34 AM
            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
            by sam_sam_sam
            I was working on this CNC machine today found no keyboard functioning no control relay powering on
            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
            Found shorted diodes on main controller relays there are 3 of them that...
            01-07-2023, 05:43 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            DVR recorder Switching power supply Failure
            by sam_sam_sam
            When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
            Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
            This...
            05-27-2023, 03:03 AM
            by sam_sam_sam
            03-31-2024, 02:12 PM
