64PN5500 | BN44-00618A Main fuse keeps popping
  • nickgronk
    • Apr 2021
    • 32
    Power supply board BN44-00618A keeps blowing main fuse and nothing plugged in to it.
    I was gifted a 64PN5500AF, picture was amazing, but tv smelled like cigarettes and was dusty AF. I opened it up, blew all the dust out of it, removed PSB & main, and cleaned the metal underneath. Also blew all the dust off all other boards. Put the power supply back in, then mainboard. Soon as I turned it on there was a "pop".
    The main fuse (T12AH250V) blew
    I removed the power supply to be sure nothing underneath, all good. Soldered on a t12ah250v fuse and sure enough it popped again. Unplugged the mainboard and Y board - last fuse, it popped again.
    I've ordered more fuses, but what can be the issue?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: 64PN5500 | BN44-00618A Main fuse keeps popping
    There's usually a sheet of something under the power supply to stop it shorting on the back of the chassis, that's not fell off when you were cleaning has it ?
    Photos will help us to see.
    I think the model number is wrong, is it a PN64F5500AF ?
    • nickgronk
      • Apr 2021
      • 32
      Yes you're right, it is a PN64F5500AF . There wasn't any sheet underneath, the risers are built into the sheet metal. Will take some pics of the PSB and get them posted
      • dskall
        • Oct 2016
        • 2905
        • usa
        Unplugged and with main caps. discharged. Measuring across middle pins on bridge rectifier and across outer pins with multimeter on continuity should read open.
        • nickgronk
          • Apr 2021
          • 32
          Both bridge rectifiers taken out of circuit to be sure. Both are perfect,
          • On a whim, I replaced with another fuse from another PS board (same t12), did not solder in the bridge rectifiers (so none on the board), screwed the board back down, plugged in and turned on. Fuse is ok. ...
          • Soldered the bridge rectifiers back in. Did not mount the board, laid it on rubber mat. Powered on and "zap" went the fuse.
          • dskall
            • Oct 2016
            • 2905
            • usa
            What were the ohms on outside pins?
            • nomoresonys
              • 12283
              • U.S.
              Check, looks like NT801s, I believe it's the mov, it's green, looks like one of those blue ceramic capacitors but it's not a cap, located just right of where you plug the power cord in, check in diode mode, it should be open as in not beep and NOT read 000 which would mean short.
              • nickgronk
                • Apr 2021
                • 32
                diode mode : .011 out of circuit
                took out of circuit - fuse from old board intact. (running out of ceramic fuses... lol)
                • nomoresonys
                  • 12283
                  • U.S.
                  Is it a constant steady beep?
                  • R_J
                    • Jun 2012
                    • 9591
                    NT801s is a NTC thermistor, 11Ω is fine it does not read open.
                    • nomoresonys
                      • 12283
                      • U.S.
                      Ok, thanks RJ, I thought it might be the mov because I didn't see the mov anywhere else, does this tv not have one?
                      • nickgronk
                        • Apr 2021
                        • 32
                        this board has the NT801s . I shlud follow up. unable to read which side is which and dont think it should matter... dunno. but testing the legs of NT801s one side read 11ohm, switched leads read OL
                        EDIT: trying to remove the white goop, chip disintegrated.
                        • R_J
                          • Jun 2012
                          • 9591
                          It will read as a resistor, both ways. it is not the problem, check the mosfets mounted to the heatsinks, like QS802, QS804
                          and the pfc circuit mosfets like QP801c.
                          With no main board connected, it is likely the power supply is turning on all the circuits so a fault in any of them will blow the fuse.
                          • nickgronk
                            • Apr 2021
                            • 32
                            Found another NT801s from a spare board, tested good, soldered in and zapped another fuse. will test fets .
                            Thank you everyone for all of your help! #SundayFunday
                            • R_J
                              • Jun 2012
                              • 9591
                              NT801s is just a current limiter for when the power supply is in standby, It gets shorted out by the relay contacts when the power supply is turned on.
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                Your problem will be on other side of bridge rectifiers. Probably fet.
                                • nickgronk
                                  • Apr 2021
                                  • 32
                                  Was both QS802 and QS804 - set is back online. Thanks a bunch!
                                  • dimis7
                                    LG 37LS5600 blows main fuse
                                    by dimis7
                                    Need some advice to troubleshoot this TV.
                                    PSU blow the main fuse F100, 3.15A.
                                    I replace the fuse with another 3A (but not ceramic) and blows it again after few seconds when i plugged in to the wall, with nothing connected to PSU, just the power cord.
                                    I checked with DMM for dead sorts but didn't found any.
                                    Checked bridge rectifier and seems ok.
                                    Also check main filter cap with transistor / cap / esr tester (the usual cheap transistor testers from ebay) and found ok.
                                    PSU p/n is EAX64405901 (1.6)...
                                    10-28-2022, 05:15 AM
                                  • cheeky2
                                    by cheeky2
                                    05-25-2024, 03:27 AM
                                  • Dani_2024
                                    by Dani_2024
                                    10-28-2024, 05:06 PM
                                  • ygorsan
                                    LG 55NANO77SRA TV – Menu scrolling by itself even after removing button board (Main Board EBU66792103)
                                    by ygorsan
                                    Hi everyone,
                                    I’m looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
                                    🧩 Problem Summary:
                                    • The TV keeps scrolling through the menu or selecting items by itself.
                                    • I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
                                    • The remote control is not in use (batteries removed), and the TV still shows the same behavior.
                                    • I
                                    07-28-2025, 08:34 AM
                                  • Asraf Atb
                                    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                    by Asraf Atb
                                    Hi everyone,
                                    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                    01-27-2025, 05:02 PM
