Yamaha Amp - strange power issue
  • matticas
    • Jan 2022
    • 4
    • Aus
    Hi all;
    I found this forum from this thread; https://www.badcaps.net/forum/showth...&highlight=PRY
    And I have a unique issue that I hope some experts on here might know about - but with similar 'design' to the thread above.
    My Yamaha RX-V861 will not turn on "once it's flat" (I think a cap discharge?). But if I manually power up the relay on the power PCB, the entire amp comes alive and works perfectly. From there, I can turn it off and on again as much as I like, providing I turn it on within about 3-4 seconds of turning it off. Past this time, it's "flat" and I need to manually trigger that relay.
    Research and poking with a multi has found the PRY signal works fine when the amp "isn't flat", but the PDET signal is the one going flat per say. While it's running normally, turning it on/off that signal changes from 0V to 5.1V no issues, but if I leave it "go flat" that PDET signal drops to ~2-3V and fluctuates a lot, and the amp never comes back on.
    Does anyone know where these PDET and PRY signals come from? (the microprocessor or something else). I have the service manual / circuit diagrams, but I can't work out it's design and behavior off paper.
    Lastly the Config menu I can access, change menus and sub menus, but I can't actually select / change anything? I've pushed every button, nothing actually changes.
    I've downloaded the service manual and it mentions nothing about "selecting" a menu item, just initial access and navigation.
    Thanks, hope to hear from anyone what maybe still familiar with these older amps...
  • R_J
    • Jun 2012
    • 9635
    Re: Yamaha Amp - strange power issue
    You likely have bad capacitors in the power supply, like C2535 (2.2/50); C2534 (2.2/50) and C2538 (1/50)
    • matticas
      • Jan 2022
      • 4
      • Aus
      Hi RJ;
      To test them, do I need to remove them from the PCB and use (my mate's) LCR meter?
      • R_J
        • Jun 2012
        • 9635
        Originally posted by matticas
        Hi RJ;
        I guess you could, I would just replace them.
        • matticas
          • Jan 2022
          • 4
          • Aus
          Hi all;
          I finally brought some replacement caps, and the first one I targeted was the 22nF/630V greencap on the power supply board.
          Yep, worked first try zero issues. Old dead Cap was measured to be 5nF once I took it out.
          Thanks all for the input. Still got me fd how that cap was messing with the 5V signals to/from that power board to the Video board, but hey, half of me is happy my amp is working (painful few weeks with TV speakers), other half of me was looking forward to a new amp....
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • justice171
            Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
            by justice171
            I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
            Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
            1. Verified that all critical voltages are present:
              • 3.3V and 5V are always present if DC is plugged.
              • 1.8V on the BIOS chip is present.
            2. Checked the power button functionality:
              • When pressed, the voltage drops to 0V, indicating the button is functional.
            3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
              • Confirmed connectivity is intact, ruling out issues
            11-26-2024, 12:39 AM
          • claws77
            lenovo flex 5 14itl05 power sequence issue
            by claws77
            hi guys, my motherboard will not start no matter what
            when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
            but rest nothing happens no sign of life.
            this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
            with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
            but now nothing happens no matter how much i wait/ charge/ press and hold power button.
            i have no knowledge of motherboards ....
            10-20-2024, 02:48 PM
          • yaya3gmax
            Laptop Power Issue – Works on Battery, Fails on Adapter Load
            by yaya3gmax
            Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
            Symptoms:
            • Laptop works normally on a pre-charged battery.
            • Battery does not charge when adapter is connected.
            • Without battery:
              • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
              • Speakers “pop” when power cut occurs indicating harsh sutdown.
              • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
            08-21-2025, 07:16 AM
          • SuperJames
            Dell G3 17 3779 Weird power cycling and shutdown/restart issue
            by SuperJames
            This one's a weird one, and still unsolved despite it having gone back to Dell once.
            Specs
            i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
            Backstory
            I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
            10-23-2023, 04:09 PM
