Zyxel NBG-419n v2, hangs during the boot
  • Z419nv2
    • Jan 2022
    • 3
    • Bulgaria
    The router hangs at bootloader stage without any error. This is the log from UART:
    Code:
    U-Boot 1.1.3 (Mar 6 2012 - 17:34:10)
    Board: Ralink APSoC DRAM: 64 MB
    relocate_code Pointer at: 83fb0000
    spi_wait_nsec: 3c
    spi device id: c2 20 17 c2 20 (2017c220)
    find flash: MX25L6405D
    raspi_read: from:30000 len:1000
    .*** Warning - bad CRC, using default environment
    Ralink UBoot Version: 3.6.0.1_a3
    ASIC 3352_MP (Port5<->None)
    DRAM_CONF_FROM: Boot-Strapping
    DRAM_TYPE: DDR2
    DRAM_SIZE: 512 Mbits
    DRAM_WIDTH: 16 bits
    DRAM_TOTAL_WIDTH: 16 bits
    TOTAL_MEMORY_SIZE: 64 MBytes
    Flash component: SPI Flash
    Date:Mar 6 2012 Time:17:34:10
    icache: sets:256, ways:4, linesz:32 ,total:32768
    dcache: sets:128, ways:4, linesz:32 ,total:16384
     ##### The CPU freq = 384 MHZ ####
     estimate memory size =64 Mbytes
     uboot: NBG-419N v2 Power LED...on
    Please choose the operation:
      1: Load system code to SDRAM via TFTP.
      2: Load system code then write to Flash via TFTP.
      3: Boot system code via Flash (default).
      4: Entr boot command line interface.
      6: To emergency.
      7: Load Boot Loader code then write to Flash via Serial.
      9: Load Boot Loader code then write to Flash via TFTP.
      a: Auto load system code then write to Flash via TFTP.
     4
    You choosed 4
     0
    No matter what i choose, the result is the same.
    • 31255
    Re: Zyxel NBG-419n v2, hangs during the boot
    bad crc = you probably need to reflash the bootloader
    • Z419nv2
      • Jan 2022
      • 3
      • Bulgaria
      Thank you for your answer.
      Without a command line interface i can't do anything, so i see two options to reflash bootloader (I'm not a specialist):
      1. Trying with JTAG (I saw 14 holes header in PCB).
      2. Desolder the EEPROM (It's 8 pin), and reflashing it with a programmer (like CH341A).
      Any other options?
        • 31255
        if you can get a full-dump i'd go with desoldering the flash.
        jtag can be a pain in the ass.
          • 31255
          it just got added to openwrt
          https://openwrt.org/toh/zyxel/nbg-419n_v2
          so you may get a dump there.
          • hinisa
            Xiaomi router freezes at boot after re-capping
            by hinisa
            I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
            When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
            After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
            Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
            07-08-2023, 05:58 AM
          • Ihandyrepair
            4 red flash led 65X950G boot Sony and android logo but then black
            by Ihandyrepair
            HI guys
            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
            here is the issue
            I have Sony and android logo. but then 4 led red flash lights front of the tv
            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
            but then I get black screen and 4 red flash light at the front LED
            but I get 3 led flash on the LED driver board.
            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
            so I tried...
            07-11-2024, 01:45 AM
          • praveenramavath
            Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
            by praveenramavath
            Hello All,
            I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
            https://www.hifivision.com/threads/m...-screen.98243/
            Troubleshooting Summary: Majority Internet Radio - Flash Chip
            04-26-2025, 09:08 AM
          • corrize
            Nikon D800 camera - flash don’t work and capacitor don’t charge
            by corrize
            Hello, I'm stuck in troubleshooting…
            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
            10-01-2022, 10:02 AM
          • i19
            Asus UX3402 / Q409Z - No sound, no TPM, Boot issues: Bios flash?
            by i19
            Hi
            I got an Asus UX3402 / Q409Z and after a BSOD I lost sound, tpm 2.0, and if it turns off it can take HOURS before I can boot again.
            Reading here and on reddit I figured its a BIOS issue, and that reflashing it may fix the problem.
            I want to use an CH341A (new model with 3.3v) to flash it.
            My problem is that I'm not sure if the SOIC8/SOP8 clips will attach to the chip and hold properly? (haven't opened my laptop yet, I'm basing this assumption on a picture from the same thread I attached).
            Any tips on how to connect to it? Maybe something...
            08-20-2024, 06:50 AM
