Samsung UE40C6600 problem with power supply
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    Hi to all
    i have the above model of tv
    It has power supply bn44-00355a
    the problem is it burns the two mosfet TK8A50 page 5 of service manual
    I change the two mosfets after measurements I made without being able to find any other problem and again burns the new 2 mosfet
    can any of you help me figure out where these two components can burn?
  • nomoresonys
    • 12307
    • U.S.
    Re: Samsung UE40C6600 problem with power supply
    Can you post the service manual so we can see what you are seeing?
    • R_J
      • Jun 2012
      • 9610
      You likely have damaged gate drive components, check the DT1 to be sure the drive windings are not open, then check the resistors and diodes DM804 & DM805, you may need to lift one end to check them accurately
      You should also check the diodes on the TM801S secondary as one might have shorted.
      • Xristakis795
        • Mar 2021
        • 162
        • Greece
        thanks sir i will check it and i will tell you about
        as about as service manual downloaded free from electrotanya
          by sam_sam_sam
          03-31-2024, 02:12 PM
          by sam_sam_sam
          07-01-2024, 06:34 AM
        • cheeky2
          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
          by cheeky2
          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
          06-15-2025, 05:12 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
