MSI GTX1070 not recognized on H110 Board, Z490 OK
  • DynaxSC
    • Apr 2021
    • 477
    • Poland
    I have an MSI GTX1070 GAMING X card, which I buyed and repaired. It got wet with something and corroded slightly in an limited area. There were a few resistors and caps around the VRM Controller, which were corroded, and had to be replaced, traces to be tinned, corrosion to be removed. Sof far so good, the card is recognized in BIOS and works perfectly on a modern Z490 board. But when I put the card into a H110 board (tried different) then it is not recognized by the BIOS, and does not show up neither in Windows nor in Mods. Tried all possible Bios settings, updated mobo Bios, to no avail. Very strange
    The area where the board has correded due to some electrolysis effect is quite limited (ca 4 X 6 cm) near the 1V8 buck controller and far away from the PCI connector, GPU, and all the PCI logic. Etherything only on the top side no more then 1-5 cm from the edge farest away from the VGA connectors. It may be possible that I have not identified some corroded resistor (no conduction possible as resistor pads were totally ethed on the other ones) that give some signal necessary to detect the card on older boards.
    I have no clue what could be the reason. Any hints appreciated.
  • DrasticRepairs
    • May 2021
    • 23
    Re: MSI GTX1070 not recognized on H110 Board, Z490 OK
    Could be pcie capacitors. Not sure what else.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5095
      • New Zealand
      Could it be that the card is fine but just incompatible with the other board?
      -David VanHorn
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • DynaxSC
        ASUS STRIX Z490-F GAMING - No POST, stubborn board
        by DynaxSC
        I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
        The situation looks like this:
        After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
        1. RTC oscillates normally (32.768KHz).
        07-08-2022, 05:45 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Junior††
        PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
        by Junior††
        Good Afternoon fellas,
        Issue:
        Disc is showing as not supported when a disc is put in.
        Here's what I've done, you can skip this if you just wanna know the question:
        - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
        - reflowed the disc drive connector
        -reflowed the chip in question (shown on image)
        - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
        Question:
        I...
        02-19-2025, 12:48 PM
