Sacon FZ revival experiment
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    So after using capacitor bungs to repair the rubber feet on two laptops, shown here:
    https://www.badcaps.net/forum/showpo...&postcount=548
    … and here:
    https://www.badcaps.net/forum/showpo...&postcount=585
    … I was inevitably left with some paper rolls and cans from the Sacon FZ capacitors I “sacrificed”.
    The paper rolls from these Sacon FZ caps looked absolutely bone-dry. The idea then occurred to me: what if I put a few drops of water on there? How (if at all) would that affect these already-failed capacitors?
    So here it goes. First, this is how one of these bad Sacon FZ caps (in this case, rated for 16V and 470 uF) measured on my GM328 tester: no capacitance, infinite ESR… just completely open-circuit as far as the GM328 was concerned.
    But then, after adding a drop of water… ta-da!
    It’s not open-circuit any more!
    Is this magic or what?!
    Sure it still has a super-lousy ESR of 1.4 Ohms and a whopping V_loss of 17%... but it’s not open! As far as the capacity goes, it’s almost in spec… for the next lower capacitance size (330 uF) . Well, better than nothing.
    Now, of course that doesn’t mean you can just add a little water and expect these caps to work again. I already tried that, though not in any device. As soon as I connected a voltage source on the cap (I can’t remember if 12V or 5V… but it was likely the latter), bubbles started oozing from the paper roll, suggesting the water was probably breaking down into Hydrogen and Oxygen (and the latter likely reacting with the aluminum foil to form a thicker oxide layer… or who knows?) In any case, the leakage current was horrendous. I forgot to note down exactly what I measured, but it was something in the range of 10 mA or so. It didn’t seem to go down much over time either, suggesting the water would probably dry out again, leaving the cap open once more.
    And for more giggles, I also connected the cap backwards on my voltage supply for a few moments, just to see what would happen. Strangely enough, almost nothing changed – the cap roll still oozed bubbles / gas, if ever so slightly more. I then connected the supply back the normal way and left it there for a few moments. After this, I tested the cap once again to see if I did any damage:
    Well, looks like I didn’t change anything much with the voltage charging/discharging and reversing. The capacitance did decrease a little… as did the V_loss (leakage.) The ESR, on the other hand, was still sitting at a steady (and lousy) 1.4 Ohms.
    And that was meant to be all I did with this experiment back then. But now come time to post it, I figured why not dig out that particular cap and see how it’s doing. After roughly half a year stored without a bung, this was it:
    So it didn’t go completely open-circuit this time, but lost nearly all of its capacitance again. Seems like V_loss goes with the capacitance hand-in-hand, though, as that has gone down too.
    I then proceeded to add a drop of (hot) water again, and once more this Sacon FZ rose from its grave.
    As you can see, the capacitance was almost back to what it was 6 months ago (just slightly lower), while the V_loss was in the teens %. On the other hand, look what the warm/hot water did for the ESR: 560 mOhms now. -WOW, almost worthy of being general purpose! /sarcansm
    Since I forgot to measure the current draw last time while the cap was connected to a voltage source, I did remember to do it now. With a 9V battery, the leakage current of the cap peaked at around 12-14 mA and then steadily decreased and stayed at 8 mA. After noting down the measurements of the leakage current (~2-3 minutes with the cap connected to the battery), I then checked the cap once again on the GM328.
    It seems like we have fairly repeatable results here… or at least with this particular cap. Both capacitance and V_loss decreased again, like last time. ESR did increase slightly, but that’s probably due to the warm water cooling off. All in all, though, it seems water can revive Sacon FZ caps for a short amount of time. I actually remember now I tried this many years ago, again with Sacon FZ. But I didn’t have an ESR meter back then, so I couldn’t report any results. All I remember is I had a Sacon FZ connected as a coupling capacitor on an audio circuit, and it wouldn’t do anything (which I expected.) Then I added a drop of water and… sound sprung out of the circuit!
    Now this may raise the question: can this method here be used on something like a motherboard or video card with these Sacon FZ caps (if busted/bad) to perform a quick hardware function test on the device (under a minute)? My guess is: MAYBE. At least, with Sacon FZ it seems like it might be possible… though I don’t recommend it. My first such experiment goes even further back with CapXon - they remained dead / unaffected by the water. So YMMV. Of course, this experiment was purely conducted because I can’t let dead things be dead in peace, especially these FZ c[r]aps.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Re: Sacon FZ revival experiment
    I figure most caps that go to 0uF if they dry out, and simply adding water won't mix or restore the electrolyte back to what it was...even if what it was was any good.
    One thing that one might try for fun is instead of water... use a mixture of glycol and water. Not sure if this will help any but would be an interesting experiment. (Glycol is typically used in caps from the start and is usually what gives the smell...) However this will not restore the life of the capacitor either. Perhaps with the glycol the loss might be reduced than with just water alone. BTW: are you using distilled water I hope?
    All trying to restore the magic smoke in capacitors...
      • 31248
      try IPA and water - to thin it down.
      btw, your going to have the chinese "rejuvenating" old caps with syringes with this thread!
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Ah crap, you might be right!
        I only created this thread as a joke, since I haven't seen anything silly like this done before... but now that I think about it... joke might come back on us.
        So hide thread in VIP and block all Chinese IPs from accessing it? (Well, I suppose that might not do anything either, given VPNs nowadays... which Chinese citizens probably have to use anyways to access "Western" parts of the interwebs.)
        Nah, ain't going to waste precious IPA on this stuff, LOL. Would rather use it for cleaning electronics stuff... or even drink it instead.
        Interesting, didn't know that.
        Isn't glycol considered a VOC agent?
        And even if not, I probably shouldn't be snorting gases from Sacon FZ anyways. They honestly smell like cat piss when they sit in my junk box (used salsa container, lol) for a while - probably because they were made with cat piss to begin with.
        Yeah, more than likely it won't indeed.
        On at least half of the caps I see go bad, I think the electrolyte just starts to attack the aluminum foil in the roll, and then from there it's just a downhill... hence the loss in capacitance and increase in ESR eventually to a point of no return.
        Nah, that's too fancy for Sacon FZ caps.
        First time around, I used tap water straight out of my bathrooms sink... which sees some of the worst lime scale build up in the pipes. So I imagine it's was full of contaminants... err... sorry, I meant electrolytes.
        The second time around, I had a pot of hot water near my bench (with a dishwasher heating element inside - my ghetto-rigged humidifier/room heat booster ), so I used water from that. But i get the water from the bathroom again, so that pot of water was probably no better in terms of lime scale and sodium content. Actually, it's probably worse, since I've been evap-ing the water from the pot for a few days. I just changed it out today, as it had a thick layer of white stuff on the sides of the pot and on the heating element. Calgon could make a helluva commercial with the hard water we have here.
        All in the name of science, as Photonicinduction would say.
        I also popped one of these Sacon FZ caps about a year ago and recorded the sound + video. Should probably upload it here someday for laughs. I've actually had a few even more sinister ideas of how to pop these badly.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8703
          Well it doesn't need to attack to the aluminum to reduce capacitance though it certainly helps. Not having any electrolyte will invalidate that bit of foil anyway.
          Having the wrong electrolyte will just leak charge away so probably shouldn't add any additional electrolytes into the solution.
          And please don't drink IPA... unless it really is an ale, then you definitely don't use that on electronics... I'm not even sure you should stick isopropanol into the electrolyte, vapor pressure would increase. Glycol is organic but not a VOC, it's vapor pressure is lower than of IPA.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5069
            • New Zealand
            Sacon FZ are so crap, they probably use fake cat piss.
            -David VanHorn
              • 31248
              but FZ have high quality cans, the top vent ALWAYS works.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Only when they bother to put it!
                Picture taken from my eVGA GeForce 6200 thread here:
                https://www.badcaps.net/forum/showth...highlight=6200
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8703
                  Dang... I was sticking stuff from my bag of cat piss into my avrtransistortester (dang i thought i had a gm328a, guess not, dont have any model printed on mine it seems) and a bunch of them made it go bonkers... hmm hope it didn't go bad or break transistortester. Some made my screen go wonky. Weird.
                  Anyway a lot of them end up being "No, unknown, or damaged part" surprisingly enough. Capacitors were so bad...
                  At least going back to my known or assumed good cap pile things went back to normal.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Hahaha, good one!
                    I'm sure you are aware of it but the component tester can't take more than 5v on its pins.
                    So make sure to completely discharge capacitors before test, even if they have been in a drawer for a long time.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      ^ This!
                      I almost messed up my tester a few times after trying to check caps that I have reformed. Seems they can take a bit of an abuse, though... but certainly not safe to do. The one that scared me was when I put in a 25V cap charged to about 15-ish volts. It was a large cap too (2200 uF.) Tester didn't appreciate it but also luckily didn't die.
                      So now I've made it a habit to always short out the leads on any capacitor prior to inserting it into my tester... and so far so good.
                        • 31248
                        the atmel usually survives, but you short the protection diode pack - i'v done it
                        on the bright side, the chinese sell the diodes on a strip of 10 for a $
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          quick, let's move this to VIP before it is too late
                          Oh, I am late, you already thought of it
                          Let's also stop this experiment before we get zombie cap apocalypse please
                          • AleXis6
                            • Feb 2021
                            • 69
                            • Belarus
                            please advice: "V_loss" corresponds to what parameter in the datasheet?
                            I have a couple different "transistor testers" and can't fully understand what this "V-loss" tells.
                            • AleXis6
                              • Feb 2021
                              • 69
                              • Belarus
                              I did it couple times with 2 different testers (LCR T4 and LCR TC1).
                              It is more or less easy to repair -change the processor and write a new firmware (if it is available for your device).
                              and one time from mentioned 2 I also changed a diode pack.
                              device for flashing firmware is very chip I ordered it from aliexpress
                              available firmware you can find here https://disk.yandex.by/d/yW8xa5NJgUo5z
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8703
                                The v_loss number doesn't quite match any parameters, just that higher is bad. It's related to leakage.
                                I pretty much toss any cap that's more than ~3% but that's just a wet finger guess. Even 3% is not great.
                                Incidentally, it was the capacitors in my refuse capacitor pile, not the pile I keep of "good" or "probably good" capacitors. And yes should always short the capacitors before testing, though I think the wonky behavior was due to me disturbing the display when removing the tester from the case to look for a model number...
                                I reform on my Sencore... and that I don't do very often.
                                • kevin!
                                  recapping PCB.
                                  • Jul 2013
                                  • 195
                                  • España
                                  I did that same experiment with a condenser that shot out the aluminum part, I added water, I put the part of the roll where the plates are located inside the aluminum can, I sealed it, and it maintained the capacity of 300 microfarads of the 400 reais.
                                  But having a water composition much higher than the original formula, it began to lose capacity over time, the plates corrode.
                                  Gaming pc:
                                  nVidia RTX 3080 TI, Corsair RM750I.
                                  Workshop PC:
                                  Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
                                  Server:
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    Not all testers have any protection, mine don't, I didn't kill any of them yet though
                                    Maybe this message by Madires can be of some help, but remember this is still leakage at low voltage, not the same as leakage at full rated voltage...
                                    https://www.eevblog.com/forum/testge...75/#msg1726775
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      That's the thing - I dislike doing any kind of firmware/BIOS programming. Don't know why, but I've never had good luck with messing around with digital circuits, so I stay away from them. The analog/power side of things is where I like to be.
                                      You might be wasting some good caps then.
                                      These cheap meters don't always seem to read the V_loss / leakage current properly. For example, yesterday I was recapping a worthless 15" LCD monitor with spare/leftover crap caps that were pulled during preemptive recaps. I had one CapXon KF read relatively low on V_loss - about 1.5-2%... or within what my meter regularly shows for most "OK" caps. Then I also checked a similarly rated CapXon KM (CapXon's general purpose series) and it showed about 5%. So I figured the KF was in a better shape than the KM. Before installing it into the circuit, I decided to do a quick reform with 12V (both caps were rated for 25V) but without any series resistor - just connected straight to a 12V power adapter. The 12V power adapter I was using likes to whine when it's unloaded and the pitch of the whining will change with very light loads. So when I hooked up the CapXon KF, I could literally hear how it took a few seconds for the cap to reform, given the load it was pulling from the adapter. And to further check on that, I connected a multimeter in series with the cap and measured the current. Eventually, the KF settled to about 8-9 uA of leakage current... but it took a good minute or so to get there. In contrast, the CapXon KM charged up instantly and was only showing about 3-4 uA of leakage.
                                      Then here is where it gets interesting. I had a Teapo SC rated for 35V and 330 uF (just slightly higher than that of the CapXon KM and KF, both of which were 25V, 220 uF parts.) The Teapo SC also showed low V_loss on the GM328 meter - I think 2.5% or thereabouts. But get this - trying to charge that Teapo cap with the same adapter, I could hear it was pulling much higher current, based on the adapter's whining. And sure enough when I checked the current with a multimeter in series, the Teapo SC was drawing about 120-130 uA - roughly 10-20x higher leakage current than the CapXon KM or KF... and didn't want to settle to less than 100 uA even after a few minutes. As soon as I removed the Teapo cap and checked the voltage across it while sitting disconnected from the adapter for ~10 seconds, the voltage across it was only 9V. So it's quite terribly leaky. The KF and KM maintained about 11V for at least a few minutes after being disconnected from the adapter.
                                      So in short: don't trust those cheap meters to measure V_loss correctly - they simply don't test at a high enough voltage to show any potential problems (pun intended.) When in doubt about leakage current, best way is to bring out a PSU, charge the cap and monitor the leakage current after a few minutes. If it's still high, the cap is probably going to go bad at some point sooner rather than later - at least when it comes to crap cap brands. With good Japanese cap brands, you may find high leakage current for the ultra-low ESR series, and that's fairly normal (most of my salvaged Rubycon MCZ stock from Xbox 360 motherboards regularly reads 3-5% V_loss on the GM328... but they've been doing OK for many years now.)
                                      Cool!
                                      So it looks like we are getting to the same results.
                                      • AleXis6
                                        • Feb 2021
                                        • 69
                                        • Belarus
                                        thanks
                                        I have the same opinion
                                          20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                                          by sam_sam_sam
                                          I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                                          At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                                          Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                                          04-09-2023, 08:04 PM
                                        • Ugur87
                                          MacBook Air M4 A3240 Brand New Water Damage no Image
                                          by Ugur87
                                          I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                                          08-28-2025, 01:09 PM
                                        • edugimeno
                                          Stagg sms12p audio amp has water damage
                                          by edugimeno
                                          Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                                          I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                                          There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                                          There is only one signal wire connecting the first boards...
                                          05-24-2025, 06:00 AM
                                        • RetroComputingGrotto
                                          Water Damaged Toshiba 48L1435DB
                                          by RetroComputingGrotto
                                          I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
                                          The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
                                          10-07-2024, 08:23 AM
                                        • x_orange90_x
                                          Samsung UN65AU8000FF fried by water
                                          by x_orange90_x
                                          I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
                                          10-16-2025, 08:40 PM
