ASUS RX570 Graphic Card not detected. Please help
  • wkholi
    • Jun 2021
    • 20
    • Egypt
    I have an. ASUS RX570 and an H!110 Gigabyte motherboards with i3 6100 processor.
    The card is not detected in the device manager ( and Hive. Linux-based OS too).
    Hence I can not install the driver.
    I tried it on a friend's computer and it worked right away!
    Any Idea where. could my problem be?
    Thanks in advance.
  • mon2
    • Dec 2019
    • 14499
    Re: ASUS RX570 Graphic Card not detected. Please help
    Do you have a secure boot option in your CMOS Setup ? This is a fancy way of requesting permission from you, the owner, to add any new hardware. If you see this setting, DISABLE it and test again. The more recent motherboards have this setting.
    Next, do you have enough power from your power supply to support this video card ? That could be an issue as well.
    • wkholi
      • Jun 2021
      • 20
      • Egypt
      I tried it on a GIGABYTE H110-D3A with an i3 6100 processor.
      it was not detected on neither hive OS nor windows.
      I am sure that the power is enough.
      I also checked secure boot and it was disabled.
      Any. other ideas?
      • mon2
        • Dec 2019
        • 14499
        https://community.amd.com/t5/drivers...r%20connection.
        • wkholi
          • Jun 2021
          • 20
          • Egypt
          Thanks, I will check it and update you
